Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 02-16-2012, 16:25   #1 (permalink)
Member: 897604
Thanks Meter: 10
help me nokia c2-03 dead
i have nokia c2-03 blank. and i try to reflash it using best tool with usb interfaces .
here is the log:
Connect phone on selected interface...
Core version : 1.36 Rev : 1.3
Selected FlashSettings : Manual
Check FlashFiles, Please, wait...
Files Set for Flashing :
MCU : rm702__07.29.mcusw
PPM : rm702__07.29.ppm_s
CNT : rm702__07.29_001.image_s_ctv_my_9n581
Flashing phone now...
Check files done...
-> SWversion check skipped : Dead mode selected
Dead Mode is Selected
Waiting for USB device...
-> If Windows say "Unrecognized device" - just reinsert battery
-> If flashing freeze - reinsert cable and try again
--- Press phone's power button or insert charger! ---
Connection opened successfully
DBG : F00A1FB300020303010100FF
CPUID : SGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
BL : Quantum_Bootloader_10.46_M1S1
Speed accepted, use 6.500.000
FLASHID : 89008289
FLIC conf set, RST set
Boot done!
===Flashing [MCU]===
File : rm702__07.29.mcusw
Image : rm702__07.29.mcusw_ebl_psi.fls
Cert block found, sending....
Cert sent
Found 5 region(s)
Processing Region 1/5
Erase , Start : 0x40000000 , Len : 0x00020000
Erasing, wait ...
Erase done, time : 00:00:00
Write , Start : 0x40000000 , Len : 0x00020000
Flashing , wait ...
Region flash done, time : 00:00:00
Processing Region 2/5
Erase , Start : 0x40040000 , Len : 0x00020000
Erasing, wait ...
Write , Start : 0x40040000 , Len : 0x00020000
Flashing , wait ...
Processing Region 3/5
Erase , Start : 0x40060000 , Len : 0x00100000
Erasing, wait ...
Erase done, time : 00:00:13
Write , Start : 0x40060000 , Len : 0x00100000
Flashing , wait ...
Region flash done, time : 00:00:01
Processing Region 4/5
Erase , Start : 0x40280000 , Len : 0x01B40000
Erasing, wait ...
Write , Start : 0x40280000 , Len : 0x01AC0000
Flashing , wait ...
Check <!cert <=> flash!> failed! Trying continue...
Region flash done, time : 00:00:23
Processing Region 5/5
Erase , Start : 0x43E20000 , Len : 0x00040000
Erasing, wait ...
No write data, skip
===Flashing [PPM]===
File : rm702__07.29.ppm_s
Image : package_s.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Processing Region 1/1
Erase , Start : 0x41DC0000 , Len : 0x00700000
Erasing, wait ...
Erase done, time : 00:01:05
Write , Start : 0x41DC0000 , Len : 0x005AA278
Flashing , wait ...
Region flash done, time : 00:00:12
===Flashing [CNT]===
File : rm702__07.29_001.image_s_ctv_my_9n581
Image : /0_Release/_projects/rm702_sw_settings/temp/059N581/CONTENT_C
Cert sent
Found 2 region(s)
Processing Region 1/2
Erase , Start : 0x424C0000 , Len : 0x01960000
Erasing, wait ...
Erase done, time : 00:01:25
Write , Start : 0x424C0000 , Len : 0x00D40000
Flashing , wait ...
Region flash done, time : 00:00:32
Processing Region 2/2
Erase , Start : 0x43E60000 , Len : 0x000E0000
Erasing, wait ...
No write data, skip
Flashing done!
Total flash time : 00:03:56
Reboot phone now...
- > AfterFlash Failed! Reason : Downgrade try or HW Error
Anyway - try reinsert battery and PowerUp phone manualy
Done!
Elapsed: 00:06:21
and now my phone dead.
i need some advice how to fix this problem
thank you
The Following User Says Thank You to david_h4ck_u For This Useful Post:
Old 02-16-2012, 16:32   #2 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Hello. Re-download other sw version, not this one. Seems to be strange.
Old 02-16-2012, 18:34   #3 (permalink)
Member: 897604
Thanks Meter: 10
thanks mr dzirt. i follow your advice.and i try to re-download from infinyty best tool support site.but in the best tool support site. i cannot find firmware version rm 702 .07.29 like my first firmware . the higher version on infinyty best tool site is rm 702 .06.98.lower than my first version.
i want to ask you mr dzirt ,if i flash it with lower firmware in this phone.what will happen to my phone. my phone still looking fine or dead ? this phone make me confused.cause this phone dct4 phone or bb5 phone.???
please guide me sir.
thank you
Old 02-16-2012, 18:44   #4 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
This is DCT4 arm, but as I not remember about downgrade, should work. Will check tomorrow.
Old 02-16-2012, 18:50   #5 (permalink)
sweet4hamza's Avatar
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
If you flash low version of firmware then it will kill the phone, better dowload with navifirmware
The Following User Says Thank You to sweet4hamza For This Useful Post:
Old 02-16-2012, 18:53   #6 (permalink)
Member: 897604
Thanks Meter: 10
thank you mr dzirt. if you have information about this phones please confirm me soon.cause ,i am very confused now . would make downgrade i scare my phone dead .
Old 02-16-2012, 18:57   #7 (permalink)
Member: 897604
Thanks Meter: 10
mr sweet4hamza how to fix c2 -03 dead caused downgrade? do you have solution? please guide me
thank you
Old 02-16-2012, 18:58   #8 (permalink)
rabirabi's Avatar
Member: 1061924
Sonork: 100.1612111
Thanks Meter: 95
ok try with these files
mcu-http://nds2.fds-fire.nokia.com/p/d/f...2__07.29.mcusw
ppm-http://nds2.fds-fire.nokia.com/p/d/f..._07.29.ppm_mh1
cnt-http://nds2.fds-fire.nokia.com/p/d/f...1_ctv_in_9k8c0
The Following 2 Users Say Thank You to rabirabi For This Useful Post:
Old 02-16-2012, 19:05   #9 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Thanks Meter: 18,268
Hello
Use Navifirm Is Perfect way here i attach
The Following User Says Thank You to Mohsin-* For This Useful Post:
Old 02-16-2012, 19:17   #10 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
thank you
Just use navifirmware and download latest firmware and flash it with latest firmware. Your phone will be alvie and next time be care fulll bec some time downgrading kill simdate.or imie
Old 02-16-2012, 20:49   #11 (permalink)
Member: 897604
Thanks Meter: 10
thank you mr rabi-rabi.i follow your advice.and i try to flash my phone using your firmware. flashing completed.but my phone shown local mode when i try to turn on my phone.
here is the log:
MCU : 1183BFC7_rm702__07.29.mcusw
PPM : E39349DC_rm702__07.29.ppm_mh1
CNT : 4A59D2AE_rm702__07.29_004.image_mh1_ctv_in_9k8c0
Check files done...
CPUID : SGOLD 213
2nd boot Ok, 01
2nd ready, AA
Sending Algo
Algo sent Ok
FLASHID : 89008289
Boot done!
File : 1183BFC7_rm702__07.29.mcusw
Cert sent
Found 5 region(s)
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:00:06
Flashing , wait ...
Erasing, wait ...
Erase done, time : 00:02:41
Flashing , wait ...
Region flash done, time : 00:01:04
Erasing, wait ...
No write data, skip
File : E39349DC_rm702__07.29.ppm_mh1
Image : package_mh1.ppm_ebl_psi.fls
Cert sent
Found 1 region(s)
Erasing, wait ...
Erase done, time : 00:00:30
Write , Start : 0x41DC0000 , Len : 0x004D0F9C
Flashing , wait ...
Region flash done, time : 00:00:08
File : 4A59D2AE_rm702__07.29_004.image_mh1_ctv_in_9k8c0
Image : package_mh1_ctv_in.image.fls
Cert sent
Found 2 region(s)
Erasing, wait ...
Erase done, time : 00:00:51
Write , Start : 0x424C0000 , Len : 0x00D80000
Flashing , wait ...
Region flash done, time : 00:00:26
Erasing, wait ...
Erase done, time : 00:00:05
No write data, skip
Flashing done!
Total flash time : 00:05:58
Reboot phone now...
Reading Phone Info....
Connected phone - C2-03
Software Info: V 07.29 29-11-11 RM-702 (c) Nokia
IMEI: 12345610654321?
PPM version : V 07.29 29-11-11 RM-702 (c) Nokia MH1
Product code: 059L5S7
Checking...
SimLock status : SimLock is Ok
Security status : Security Damaged!!!!!
Read Info Done!
Checking User Certificates...
Total - 42 certs
Data exist, skip certificate repair...
AfterFlash operations done ;D
Done!
Elapsed: 00:06:29
Phone found!
Series 40 Device detected!
read info... - Ok
Phone disconected!
that log say my imei and securyty damage. i know no solution for imei damage absolutely must buy nokia rpl.but when i want to read ask file using best tool it cannot be read the ask file????
Old 02-16-2012, 21:10   #12 (permalink)
Mohsin-*'s Avatar
Member: 417298
Sonork: 100.1578269
Hello
What was Problem before Flash ?
and Check Backup folder have Backup ? if Yes write backup
Old 02-16-2012, 21:30   #13 (permalink)
Member: 897604
Thanks Meter: 10
Originally Posted by Mohsin-* View Post
Hello
if no back up sir.what should i do to fix this phone.cause i cannot buy rpl without ask.? how to read ask file of this phone.
Old 02-17-2012, 08:15   #14 (permalink)
Member: 1434736
Sonork: 100.1607275
Thanks Meter: 5,377
check imie back side of phone and search on backup folder, if you take backup or on your luck you found there and just write imie and phone will me ok again , other wise i already you about downgrading, now try connect nokia care center for cheap imie
Old 02-17-2012, 08:33   #15 (permalink)
Dzirt's Avatar
Member: 1157320
Thanks Meter: 6,192
Phone have security damaged. What was with this before?
Page generated in 0.22358 seconds with 10 queries
