02-16-2012, 16:25 | #1 (permalink) |
Freak Poster Join Date: Nov 2008
Member: 897604 Status: Offline Thanks Meter: 10 | help me nokia c2-03 dead here is the log: Connect phone on selected interface... Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm702__07.29.mcusw PPM : rm702__07.29.ppm_s CNT : rm702__07.29_001.image_s_ctv_my_9n581 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm702__07.29.mcusw Image : rm702__07.29.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:13 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Check <!cert <=> flash!> failed! Trying continue... Region flash done, time : 00:00:23 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm702__07.29.ppm_s Image : package_s.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:01:05 Write , Start : 0x41DC0000 , Len : 0x005AA278 Flashing , wait ... Region flash done, time : 00:00:12 ===Flashing [CNT]=== File : rm702__07.29_001.image_s_ctv_my_9n581 Image : /0_Release/_projects/rm702_sw_settings/temp/059N581/CONTENT_C Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:01:25 Write , Start : 0x424C0000 , Len : 0x00D40000 Flashing , wait ... Region flash done, time : 00:00:32 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip Flashing done! Total flash time : 00:03:56 Reboot phone now... - > AfterFlash Failed! Reason : Downgrade try or HW Error Anyway - try reinsert battery and PowerUp phone manualy Connect phone on selected interface... Done! Connect phone on selected interface... Elapsed: 00:06:21 Connect phone on selected interface... and now my phone dead. i need some advice how to fix this problem thank you |
The Following User Says Thank You to david_h4ck_u For This Useful Post: |
02-16-2012, 18:34 | #3 (permalink) | |
Member: 897604 Status: Offline Thanks Meter: 10 | Quote:
i want to ask you mr dzirt ,if i flash it with lower firmware in this phone.what will happen to my phone. my phone still looking fine or dead ? this phone make me confused.cause this phone dct4 phone or bb5 phone.??? please guide me sir. thank you | |
02-16-2012, 18:50 | #5 (permalink) |
No Life Poster Join Date: Nov 2010 Location: Atif mobile,goal, faisalabad
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | If you flash low version of firmware then it will kill the phone, better dowload with navifirmware |
The Following User Says Thank You to sweet4hamza For This Useful Post: |
02-16-2012, 19:05 | #9 (permalink) |
No Life Poster Join Date: Dec 2006 Location: Pakistan/UAE/WorldWide
Member: 417298 Status: Offline Sonork: 100.1578269 Thanks Meter: 18,268 | Hello Use Navifirm Is Perfect way here i attach |
The Following User Says Thank You to Mohsin-* For This Useful Post: |
02-16-2012, 19:17 | #10 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | Just use navifirmware and download latest firmware and flash it with latest firmware. Your phone will be alvie and next time be care fulll bec some time downgrading kill simdate.or imie |
02-16-2012, 20:49 | #11 (permalink) | |
Member: 897604 Status: Offline Thanks Meter: 10 | Quote: here is the log: Connect phone on selected interface... Core version : 1.36 Rev : 1.3 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : 1183BFC7_rm702__07.29.mcusw PPM : E39349DC_rm702__07.29.ppm_mh1 CNT : 4A59D2AE_rm702__07.29_004.image_mh1_ctv_in_9k8c0 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : SGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : 1183BFC7_rm702__07.29.mcusw Image : rm702__07.29.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:06 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01B40000 Erasing, wait ... Erase done, time : 00:02:41 Write , Start : 0x40280000 , Len : 0x01AC0000 Flashing , wait ... Region flash done, time : 00:01:04 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : E39349DC_rm702__07.29.ppm_mh1 Image : package_mh1.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41DC0000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:30 Write , Start : 0x41DC0000 , Len : 0x004D0F9C Flashing , wait ... Region flash done, time : 00:00:08 ===Flashing [CNT]=== File : 4A59D2AE_rm702__07.29_004.image_mh1_ctv_in_9k8c0 Image : package_mh1_ctv_in.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x424C0000 , Len : 0x01960000 Erasing, wait ... Erase done, time : 00:00:51 Write , Start : 0x424C0000 , Len : 0x00D80000 Flashing , wait ... Region flash done, time : 00:00:26 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:05 No write data, skip Flashing done! Total flash time : 00:05:58 Reboot phone now... Reading Phone Info.... Connected phone - C2-03 Software Info: V 07.29 29-11-11 RM-702 (c) Nokia IMEI: 12345610654321? PPM version : V 07.29 29-11-11 RM-702 (c) Nokia MH1 Product code: 059L5S7 Checking... SimLock status : SimLock is Ok Security status : Security Damaged!!!!! Read Info Done! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:06:29 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... that log say my imei and securyty damage. i know no solution for imei damage absolutely must buy nokia rpl.but when i want to read ask file using best tool it cannot be read the ask file???? | |
02-17-2012, 08:15 | #14 (permalink) |
Member: 1434736 Status: Offline Sonork: 100.1607275 Thanks Meter: 5,377 | check imie back side of phone and search on backup folder, if you take backup or on your luck you found there and just write imie and phone will me ok again , other wise i already you about downgrading, now try connect nokia care center for cheap imie |
