08-20-2013, 08:39 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: bagmati pradesh
Member: 1626780 Status: Offline Thanks Meter: 1,275 | help mr Dzirt.error writing recover pm. Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: D0630004FFFB3C404685941E8E9494478E94F11C ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: phone is in flash mode Reading NPC certificate... IMEI : 351680054063247 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... Cert Read done! NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\InfinityBox\BEST\Backup\Cert\351680054063247_CR T.rpl Trying read spr block , wait ... Get phone data... Get flash data... SPR Read Ok! Spr saved to : 351680054063247.spr ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Processing SimLock extraction.... Checking readed data, wait few seconds ID_INFO : 79u_sr1_12w20.1.2/30-07-12/RM-750 Initial data found, start fun... SimLock RPL saved : D:\InfinityBox\BEST\Backup\Cert\351680054063247_SI M.rpl SimLock PM saved : D:\InfinityBox\BEST\Backup\Cert\351680054063247_SI M.pm Done! ===== INFO ===== - > Seems , unlock code found inside - > If phone will be locked after repair - write recovered PM - > After write make factory sets ===== INFO ===== Elapsed: 00:00:23 .................................................. ............................................... Will Write RPL keys now... Check RPL file... SimLock Data found! SimLock key found! Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001040 EM1 ID: 00001060 PUBLIC ID: D0630004FFFB3C404685941E8E9494478E94F11C ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 005000EC Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:02 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : F4C2F0A6BA76F178E59EBE710A8E1C85F3E122C0 ADL: Preparing for write certificates... ADL: Writing Flash certs done! ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Wait, reconneting... Writing SimLock Key... Error! Writing SimLock Data... Error! SDD Key status : SDData Damaged!!!!! SimLock status : SimLock Damaged!!!!! Security status : Security is Ok Done! Please Connect Phone Phone found! Series 60 Device detected! read info... - Ok Operating mode is OK, no need change... Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Done! Elapsed: 00:00:00 Reading Phone Info.... Connected phone - Nokia N00 Software ver : V 79u_sr1_12w20.1.2 30-07-12 RM-750 (c) Nokia IMEI : 351680054063247 Ape Ver : 111.021.0028 APE Var : 111.021.0028111.021.0028.02.01111.021.0028.246.05 APE ADSP: 256 DSP Ver : 79u_sr1_12w20_1 APE Test: RM-750_011.010v0.017 PPM : CNT : Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 40 Tahvo : 00 Batery: 3643 mV APE BT: HCI Version 4 (rev. 192). LMP Version 4 (rev. 16651). Manufacturer 15. APE HW: 256 Lock info =========== IMEI : 351680054063247 IMEI spNet : 3A 15 86 00 45 60 23 04 IMEI svNet : 33 15 86 00 45 60 23 34 F2 Unable to read Lock table... CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SL30 phone , SP_CODE_LEN : 20 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Operating mode is OK, no need change... Field 120 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 3 write - Ok Done! Elapsed: 00:00:00 Elapsed: 00:00:00 Reading Phone Info.... Connected phone - Nokia N00 Software ver : V 79u_sr1_12w20.1.2 30-07-12 RM-750 (c) Nokia IMEI : 351680054063247 Ape Ver : 111.021.0028 APE Var : 111.021.0028111.021.0028.02.01111.021.0028.246.05 APE ADSP: 256 DSP Ver : 79u_sr1_12w20_1 APE Test: RM-750_011.010v0.017 PPM : CNT : Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 40 Tahvo : 00 Batery: 3643 mV APE BT: HCI Version 4 (rev. 192). LMP Version 4 (rev. 16651). Manufacturer 15. APE HW: 256 Lock info =========== IMEI : 351680054063247 IMEI spNet : 3A 15 86 00 45 60 23 04 IMEI svNet : 33 15 86 00 45 60 23 34 F2 Unable to read Lock table... CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SL30 phone , SP_CODE_LEN : 20 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! |
