01-03-2015, 06:05 | #1 (permalink) |
Freak Poster Join Date: May 2009 Location: DHAKA GAZIPUR Age: 51
Member: 1033768 Status: Offline Sonork: sonork_id=100.1603335 Thanks Meter: 81 | help nokia 1030 flash rep.. Core : v2.00a , NXP FlashEngine : v4.0 Flash Mode : Full Update (System, User, Boot) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W292_PWBASSY_RM-1030_LIGHT_SWAP_ENGINE_PH_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img Ok, Set : RM1030_V2_1.2.3.21_udisk.bin Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : CC00C847 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_059W292_PWBASSY_RM-1030_LIGHT_SWAP_ENGINE_PH_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:05:37 Reboot phone Ok |
01-03-2015, 08:35 | #2 (permalink) | |
No Life Poster Join Date: Mar 2007 Location: Factory Reset Protection (FRP) Age: 13
Member: 459784 Status: Offline Sonork: +91-9179403087 Thanks Meter: 1,543 | Quote:
