04-24-2016, 22:04 | #1 (permalink) |
No Life Poster Join Date: Oct 2011 Location: gsmsection
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | help nokia 215 RM-1110 need lb fils for repaire Core : v2.21 , MTKx FlashEngine : v9.8 Verify files ... MAUI : RM-1110_ROM_eMP_12.03.11 VIVA : RM-1110_VIVA_eMP_12.03.11 LANG : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 CUST : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 JMPT : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 225 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2995CE0877AA84DDB3B68419D6BFF568 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_12.03.11 SecureDecrypt : RM-1110_VIVA_eMP_12.03.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 SecureDecrypt : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 SecureDecrypt : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 OVRLP : 000069B900000001 PHPID : JET.12.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_12.03.11 Write : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 Write : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 Write : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 Write : RM-1110_VIVA_eMP_12.03.11 [ERROR] : DA_UART_RX_BUF_FULL Error While flash area!!! Flashing failed! i cant find in support area |
04-25-2016, 00:11 | #2 (permalink) |
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | Service Operations improved - MTKx : Full Nokia 215 ( RM-1110 , RM-1111 , RM-1112) support RPL operations : Read/Write/Verify Flash Read activated MAUI Repair Activated (Files uploaded to support area) Counter Reset activated ( reset wrong SP unlock code attempts ) SP-Unlock (via BF) operation activated HOW to find ??? |
04-25-2016, 11:02 | #6 (permalink) |
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | Befor flash phone working fine just i need to change language phone deade do repaire mode not success just i need MAUI Repair fils thanks for help |
04-25-2016, 11:05 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Again and again : http://forum.gsmhosting.com/vbb/11777330-post5.html |
04-25-2016, 12:30 | #8 (permalink) | |
Member: 1678945 Status: Offline Sonork: 100.1620753 Thanks Meter: 107 | Quote:
repair mode not working with all nokia MTK Verify files ... MAUI : RM-1110_ROM_eMP_12.03.11 VIVA : RM-1110_VIVA_eMP_12.03.11 LANG : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 CUST : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 JMPT : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 - > MODE : FullFlash Repair Mode is On Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 325 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 2995CE0877AA84DDB3B68419D6BFF568 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : JET.12.03.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Jet.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00EF , [MXIC] MX25U12835FZNI_10G [0] : FLASH_DIE : 00C2 0025 0038 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00E80000-0x00FF3FFF , LEN : 0x00174000 SecureDecrypt : RM-1110_ROM_eMP_12.03.11 SecureDecrypt : RM-1110_VIVA_eMP_12.03.11 SecureDecrypt : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 SecureDecrypt : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 SecureDecrypt : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 OVRLP : 000069B900000001 PHPID : JET.12.03.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1110_ROM_eMP_12.03.11 Write : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 Write : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 Write : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 Write : RM-1110_VIVA_eMP_12.03.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1110_ROM_eMP_12.03.11 [VERIFY] DONE : RM-1110_LANG_PACK_ROM_IC_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_CUSTPACK_ROM_IC_MEA_OM_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_JUMP_TABLE_IC_MEA_OM_eMP_12.03.11_001 [VERIFY] DONE : RM-1110_VIVA_eMP_12.03.11 CODE_VERIFY : Ok FORMAT FFS : skipped Rebooting phone now Flashing done! Total flash time : 00:02:40 Reboot phone Ok | |
04-26-2016, 14:59 | #12 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Quote:
03-29-2017, 05:26 | #13 (permalink) | |
No Life Poster Join Date: Mar 2008 Location: Pakistan
Member: 720264 Status: Offline Sonork: 100.1649278 Thanks Meter: 192 | Quote:
08-23-2017, 19:46 | #14 (permalink) | |
Crazy Poster Join Date: Oct 2013
Member: 2043919 Status: Offline Thanks Meter: 19 | i need this files please Quote:
i need this files please | |
