10-06-2014, 21:12 | #1 (permalink) |
No Life Poster Join Date: Feb 2003 Location: africa Age: 54
Member: 22284 Status: Offline Thanks Meter: 81 | How can i remove Nokia RM-970 security |
10-07-2014, 03:20 | #2 (permalink) | |
Cheater -Don't Deal with him- Join Date: Jul 2011 Location: KANCHEEPURAM, VANDAVASI
Member: 1618492 Status: Offline Sonork: 100.1619678 QQ 2483222717 Thanks Meter: 488 | Quote:
just follow the procedure Press "Reset UserCode" button in MediaTek tab. Follow software instructions. After operation done - code will be default (12345). | |
10-07-2014, 19:46 | #3 (permalink) |
Member: 22284 Status: Offline Thanks Meter: 81 | its not able to connect in win7 ultimate but you can read Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... WHEN FONE IS ON THEN YOU READ BELOW Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.03.11 00-00-00 RM-970 IMEI 1 : 351709060712040 IMEI 2 : 123456789012345 XappVer : 000007B2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : ID CNT : Rivendell.10.03.11.p1 Product SN : 59AE0CBBH Product code : 059V207 Base Prd.code: 059T729 Module code : 0205840 Hardware info======= HWID : 1200 LCDVer: TPO Lock info =========== IMEI : 351709060712040 IMEI spNet : 3A 15 07 09 06 17 02 04 Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! |
01-28-2016, 14:29 | #5 (permalink) |
No Life Poster Join Date: Jul 2014 Location: EARTH
Member: 2221849 Status: Offline Sonork: offline Thanks Meter: 279 | NOKIA 220 RM0-970 SECURITY CODE REMOVED BY FORMAT NOKIA BB5 SERVICE TOOL [IMG]http://imagizer.imageshack.us/v2/1600x1200q90/911/hZ0Awp.png[/IMG |
