03-11-2015, 13:46 | #1 (permalink) |
Freak Poster Join Date: Aug 2008 Location: kenya
Member: 839673 Status: Offline Sonork: pastorshaggy Thanks Meter: 66 | how do you reset pass word after flash even after hard reset password is still on Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 23A5C0D9 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_udisk.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_059W293_RM-1030_GLOBAL_SWAP_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:54 Reboot phone Ok Connect phone on selected interface... Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : Wipe (Reset/Erase UserData and Settings) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : Wipe (Reset/Erase UserData and Settings) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 23A5C0D9 Processing : RM1030_V2_1.2.3.21_persist.img Partition Init Not Done Flash Error Break flashing! Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : Wipe (Reset/Erase UserData and Settings) Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_userdata.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 23A5C0D9 Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_userdata.img Erase Partition : USERDATA Partition Erase Done Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:00:09 Reboot phone Ok Connect phone on selected interface... Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : System Update (System , Boot) : Not Touch UserData Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W293_RM-1030_GLOBAL_SWAP_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : System Update (System , Boot) : Not Touch UserData Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W293_RM-1030_GLOBAL_SWAP_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Device boot not done Check Drivers Try again Core : v2.04 , NXP FlashEngine : v4.7 Flash Mode : System Update (System , Boot) : Not Touch UserData Check and select files according selected FlashMode Ok, Set : RM1030_V2_1.2.3.21_059W293_RM-1030_GLOBAL_SWAP_V2_variant.img Ok, Set : RM1030_V2_1.2.3.21_boot.img Ok, Set : RM1030_V2_1.2.3.21_cache.img Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Ok, Set : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Ok, Set : RM1030_V2_1.2.3.21_fat.bin Ok, Set : RM1030_V2_1.2.3.21_oemsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_oemsblhd.mbn Ok, Set : RM1030_V2_1.2.3.21_persist.img Ok, Set : RM1030_V2_1.2.3.21_preload.img Ok, Set : RM1030_V2_1.2.3.21_qcsbl.mbn Ok, Set : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Ok, Set : RM1030_V2_1.2.3.21_recovery.img Ok, Set : RM1030_V2_1.2.3.21_system.img File HW revision is : HW Revision V2 HW Revision V2 files flashing accepted by user Dead Mode is Selected 1. Phone should be Off! 2. Press and hold 'Volume Down' button 3. Insert USB cable and hold button, until phone will be detected Connect Ok Get Phone Initial Info Product : MSM7627A Version : 0.5 Serial : 23A5C0D9 Processing : RM1030_V2_1.2.3.21_qcsblhd_cfgdata.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_qcsbl.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsblhd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_oemsbl.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboothd.mbn Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_emmc_appsboot.mbn Init Ok, send data ... Data sent, start flashing [Info] : INFOhasHead == true! Region Flash Done Processing : RM1030_V2_1.2.3.21_boot.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_recovery.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_persist.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_fat.bin Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_system.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_cache.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_preload.img Init Ok, send data ... Data sent, start flashing Region Flash Done Processing : RM1030_V2_1.2.3.21_059W293_RM-1030_GLOBAL_SWAP_V2_variant.img Init Ok, send data ... Data sent, start flashing Region Flash Done Rebooting phone now Flashing done! Total flash time : 00:03:37 Reboot phone Ok Connect phone on selected interface... |
