Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-20-2012, 07:39   #1 (permalink)
bimes's Avatar
Member: 729381
how to fix it
how to fix it?
Connect phone on selected interface...
UFS S/N 38442 boot - Ok
Phone found!
Series 40 Device detected!
read info...  - Ok
Repair SL procedure started...
Phone Imei: 353183037824692
Key file exists, no need to read...
Operating mode is OK, no need change...
Writing SimLock Data...   Ok
Writing SimLock Key...   Error
Repair fail...! ( SL3 phone? )
Reading Phone Info....
Connected phone -    Nokia 3110c
Software ver : V 07.21 05-11-08 RM-237 (c) Nokia.
IMEI    :      353183037824692
DSP Ver :     ICPR61_08w10
PPM     :      V 07.21
05-11-08
RM-237
(c) Nokia.
MR
CNT     :
Product SN   :     MYL658846
Product code :     0581522
Base Prd.code:     0553909
Module code  :     0203291
Hardware info=======
HWID  : 5008
Retu  : 32
Tahvo : 53
Batery: 4528 mV
CMT BT: Error
APE BT: 06cc-P9.1
APE HW: Error
LCDVer: Error
RF ic : 17211721
Lock info ===========
IMEI spNet :
IMEI svNet :
Conf key     : 0000000000000000
Provider key : 2440700000000000
Country      : Finland
Operator     : NOKIA (Open)
Counters     : Key 0  [3] , Fbus 0  [10]
Blocks       : 7
LOCK STATUS :
BLK : 1
 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open
BLK : 2
BLK : 3
BLK : 4
BLK : 5
BLK : 6
BLK : 7
LOCKS :  All Open
User Code : 9846223773
MMC pwd  : Backup saved
UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery]
Done!
Checking StartUp data ...
SDD Key status : SDData Damaged!!!!! :(
 - > Do REPAIR SDD , Local SX4 if needed
SimLock status : SimLock is Ok
Security status : Security is Ok
PA_SimLock Version :
PA_SL phone detected
Done!
Repair SD procedure started...
Writing Super Dongle Key...   Error
Repair fail...!
Done!
Old 07-20-2012, 07:52   #2 (permalink)
bimes's Avatar
Member: 729381
hello,
cannot write with other tools as well
Old 07-20-2012, 08:53   #3 (permalink)
Member: 1666696
hi...
try to repaired SDD first, then sx4 and write pm
good luck
Old 07-20-2012, 09:00   #4 (permalink)
andyvikas's Avatar
Member: 449069
Easy way,
1. Backup RPL(NPC Must)
2. Full Erase
3. Full Flash
4. Write RPL(Only NPC)
5. Restore CCC/HWC
6. Write PM using local Sx4
7. Repair SDD & SL as required.
Done
The Following 2 Users Say Thank You to andyvikas For This Useful Post:
Old 07-20-2012, 10:54   #5 (permalink)
bimes's Avatar
Member: 729381
hello,
still no luck
Phone found!
read info...  - Ok
User ACCEPTED FULL ERASE
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT ASICID   : 000000010000022600010006010C192101001101
CMT EM0 ID  : 00000232
CMT EM1 ID  : 00000353
CMT PUB ID  : 254000138E9B7E56E91F6E778D687E543A851FC7
CMT MODE ID : 00
CMT R_HASH  : BAF3A9C3DBFA8454937DB77F2B8852B1
CMT ROM ID  : 191EC665DFAAF68F
CMT : Sending 2nd loader...
Use : RAP3Gv3_2nd.fg  ,  Rev : 0.0  Ver : 10.42.0
CMT Loader sent, Boot Ok
MCU Configuration
MCU Cfg Ok , 03
FLASHID : 89810089 , CMT , NOR
CMT Flash ID : 89810089 < INTEL => NU48F256
FLCNT   : 00000000000000000000000000000000000000
FLASHID : 0000FFFF , CMT , MMC , EXT
CMT Flash ID : 0000FFFF < Bad Flash Type , if MMC - It Ok
Sending ALGO....
Use : RAP3Gv3_algo_v1331.fg  ,  Rev : 0.0  Ver : 1.33.1
CMT Algo sent
CMT PAPUB : C0E691EA16A7593A9BB28832D7312A39F7ED668D05
Transmission mode :  Dual (Ddr, TX2)
Boot Done!
CMT : Read NPC certificate...
Cert size : 12288 byte(s)
CMT : Read CCC certificate...
Cert size : 8192 byte(s)
CMT : Read HWC certificate...
CMT : Read VARIANT certificate...
Cert size : 20480 byte(s)
Cert Read done!
NPC Certificate saved...
CCC Certificate saved...
HWC Certificate saved...
RPL saved : c:\InfinityBox\BEST\Backup\Cert\353183037824692_CRT.rpl
Full Erase started...
Asic : CMT , Sub : NOR
Erase Area 0x00000000-0x01FFFFFF
Using TimeOut : 10 min ( 600 sec )
Erasing, wait.....
CMT : Erase Ok
Done
Phone disconected!
Core : v1.48 , FlashEngine : v1.7
Selected FlashSettings : Manual
Files Set for Flashing :
MCU : rm237__07.21.mcusw
PPM : rm237__07.21.ppm_mr
CNT : rm237__07.21.image_mr
Check FlashFiles, Please, wait...
-> SWversion check skipped : Dead mode selected
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
FLCNT   : 000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
Sending ALGO....
CMT Algo sent
PAPUBkeys blank (erased or HW failure)
Boot Done!
Erase : Processing rm237__07.21.mcusw
Found 9 areas to erase, erase group
CMT , NOR , Area : 0x00000000 - 0x000006BF
CMT , NOR , Area : 0x000006C0 - 0x0001FFFF
CMT , NOR , Area : 0x00020000 - 0x0007FFFF
CMT , NOR , Area : 0x00080000 - 0x000DFFFF
CMT , NOR , Area : 0x00100000 - 0x001FFFFF
CMT , NOR , Area : 0x00200000 - 0x0031FFFF
CMT , NOR , Area : 0x00320000 - 0x0105FFFF
CMT , NOR , Area : 0x01060000 - 0x01067FFF
CMT , NOR , Area : 0x01068000 - 0x0107FFFF
Using TimeOut : 7 min ( 430 sec )
Erasing, wait.....
CMT : Group erase Ok
TIME : Erase time : 00:00:04
PrReq : NOR , 00
Write : Processing rm237__07.21.mcusw
CMT: Writing Hash CERT [NOLO]
CMT: Writing Hash CERT [KEYS]
CMT: Writing Hash CERT [PRIMAPP]
CMT: Writing Hash CERT [PASUBTOC]
CMT: Writing Hash CERT [PAPUBKEYS]
CMT: Writing Hash CERT [UPDAPP]
CMT: Writing Hash CERT [DSP0]
CMT: Writing Hash CERT [MCUSW]
CMT: Writing Hash CERT [PMM_CONF]
CMT: Writing Hash CERT [SBIF_CONF]
Total writen 942 blocks
TIME : Write time : 00:02:09
PrReq : NOR , 00
Erase : Processing rm237__07.21.ppm_mr
Found 1 areas to erase, erase group
CMT , NOR , Area : 0x01080000 - 0x0151FFFF
Erasing, wait.....
TIME : Erase time : 00:00:01
PrReq : NOR , 00
Write : Processing rm237__07.21.ppm_mr
Total writen 227 blocks
TIME : Write time : 00:00:29
PrReq : NOR , 00
CNT : Converted to 128k page data exist
Erase : Processing rm237__07.21.image_mr_128
CMT , NOR , Area : 0x01520000 - 0x01FDFFFF
Erasing, wait.....
TIME : Erase time : 00:00:02
PrReq : NOR , 00
Write : Processing rm237__07.21.image_mr_128
Total writen 256 blocks
TIME : Write time : 00:00:32
PrReq : NOR , 00
Init Service mode... Wait...
Software Info:     V 07.21
05-11-08
RM-237
(c) Nokia.
IMEI:  12345610654321?
Product code:  0581522
Checking...
Read Info Done!
Checking User Certificates...
Total - 0 certs
Uploading certificates...
Writen 21 certs!
AfterFlash operations done ;D
Phone found!
read info...  - Ok
Phone found!
read info...  - Ok
Phone found!
read info...  - Ok
Will Write RPL keys now...
Check RPL file...
NPC Data found! (CMT)
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
Preparing for write certificates...
Switching to CMT...
CMT : NPC erase Ok
Writing NPC... Ok
Done!
PPM     :      V 07.21
05-11-08
RM-237
(c) Nokia.
MR
CNT     :      Content: mr
V 07.21
05-11-08
RM-237
(c) Nokia.
HWID  : 5008
Retu  : 32
Tahvo : 53
Batery: 4452 mV
CMT BT: Error
APE BT: Error
APE HW: Error
RF ic : 17211721
IMEI spNet :
IMEI svNet :
Unable to read Lock table... :(
MMC pwd  : no any record found
Done!
Phone found!
read info...  - Ok
Will Write CCC/HWC keys now...
Using : RM-237.rpl
CCC Data found!
HWC Data found!
Setting FlashMode
FlashMode set Ok
1st boot Ok, C0
CMT part info :
CMT MODE ID : 00
MCU Configuration
MCU Cfg Ok , 03
Sending ALGO....
CMT Algo sent
Boot Done!
CMT : CCC erase Ok
Writing CCC... Ok
CMT : HWC erase Ok
Writing HWC... Ok
Done!
Elapsed: 00:00:17
Phone found!
read info...  - Ok
PPM     :      V 07.21
05-11-08
RM-237
(c) Nokia.
MR
CNT     :      Content: mr
V 07.21
05-11-08
RM-237
(c) Nokia.
HWID  : 5008
Retu  : 32
Tahvo : 53
Batery: 4565 mV
CMT BT: Error
APE BT: Error
APE HW: Error
RF ic : 17211721
IMEI spNet :
IMEI svNet :
Done!
Local SX4 procedure started...
Check SD : Key Damaged!!!
SX4 Auth error :(
Repair fail...!
Old 07-20-2012, 11:02   #6 (permalink)
Dzirt's Avatar
Member: 1157320
Sonork: 100.1616907
Hello.
Open BEST/Special/
Delete file : special.log
Repeat repair procedures again.
The Following User Says Thank You to Dzirt For This Useful Post:
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 8 05-21-2013 19:20
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 28 08-30-2012 03:40
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 7 07-18-2012 07:57
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 06-10-1999 22:36
Page generated in 0.27827 seconds with 11 queries
