09-11-2012, 13:17 | #3 (permalink) |
Freak Poster Join Date: Dec 2007 Location: sukabumi
Member: 649553 Status: Offline Thanks Meter: 45 | rm-607 after flash n factory setting Phone found! Series 40 Device detected! read info... - Ok Checking StartUp data ... ----------------------- INFINEON : SDData is not present (It is Ok) CMLA Key status : read data error SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! |
09-11-2012, 13:28 | #4 (permalink) |
Member: 649553 Status: Offline Thanks Meter: 45 | and i flash again -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_2.5_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357009045832946 PCcode : 059F0V3 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : D:\hwk\infi\InfinityBox_FREE_BEST_v1.51_2\Backup\C ert\357009045832946_2nd_XG213_CRT.rpl ===Flashing [MCU]=== File : rm607__06.15.mcusw Image : rm607__06.15.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00040000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40080000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40080000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 4/5 Erase , Start : 0x400A0000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x400A0000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 5/5 Erase , Start : 0x40400000 , Len : 0x01800000 Erasing, wait ... Erase done, time : 00:00:48 Write , Start : 0x40400000 , Len : 0x01780000 Flashing , wait ... Region flash done, time : 00:00:29 ===Flashing [PPM]=== File : rm607__06.15.ppm_x Image : package_x.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:08 Write , Start : 0x41C00000 , Len : 0x0041A488 Flashing , wait ... Region flash done, time : 00:00:04 ===Flashing [CNT]=== File : rm607__06.15.image_x_0596685 Image : package_x_0596685.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42200000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:05 Write , Start : 0x42200000 , Len : 0x00DC0000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:03:00 Reboot phone now... Reading Phone Info.... Connected phone - C1-01 Software Info: V 06.15 25-11-11 RM-607 (c) Nokia IMEI: 357009045832946 PPM version : V 06.15 25-11-11 RM-607 (c) Nokia X Product code: 0596685 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Settings After Flash Defaults... ProductTuneSet...OK! SwUpgradeSet...OK! Product code update... Resetting LifeTimer Reset Done! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:34 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Read and Check phone data... ---------------------- RAP_BOOT: 0000000000000000 RAP_PUB: 0000000000000000000000000000000000000000 CMT_ROOT: 00000000000000000000000000000000 RAP_PAPUB: 0000000000000000000000000000000000000000 ---------------------- Live Test Ok! ---------------------- CNT sector : 128 kb ------------------------ INFINEON : SDData is not present (It is Ok) CMLA Key status : read data error SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 |
09-11-2012, 13:41 | #5 (permalink) |
Member: 649553 Status: Offline Thanks Meter: 45 | rm-702 after flash Read and Check phone data... ---------------------- RAP_BOOT: 0000000000000000 RAP_PUB: 0000000000000000000000000000000000000000 CMT_ROOT: 00000000000000000000000000000000 RAP_PAPUB: 0000000000000000000000000000000000000000 ---------------------- Live Test Ok! ---------------------- CNT sector : 128 kb ------------------------ INFINEON : SDData is not present (It is Ok) CMLA Key status : read data error SimLock status : SimLock is Ok Security status : Security is Ok ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 |
09-11-2012, 13:43 | #6 (permalink) |
Member: 649553 Status: Offline Thanks Meter: 45 | rm-702 can't read full flash via usb Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : Verify Error Try again... -> Error answer from BootRom Boot error #1, break Phone disconected! |
09-11-2012, 15:49 | #7 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Sure, and will not read it. It is XG213 phone. About Old Models - C1-01 and same - they not have CMLA at all, so, no anything can be inside. |
The Following 3 Users Say Thank You to Dzirt For This Useful Post: |
11-22-2015, 06:04 | #9 (permalink) |
Insane Poster Join Date: Oct 2008
Member: 879723 Status: Offline Thanks Meter: 6 | x2-05, CMLA Key status : Not Present . Plz hlep Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-05 Software ver : V 08.60a 27-12-11 RM-772 (c) Nokia IMEI : 35740604941xxxx XappVer : 00000848 PPM : V 08.60a 27-12-11 RM-772 (c) Nokia D CNT : Content: tele2 HR V 08.60a 27-12-11 RM-772 (c) Nokia Product SN : 84F1AADAH Product code : 059N8G1 Base Prd.code: 059F6M7 Module code : 0204959 Long Prod.SN : 0 Hardware info======= HWID : 1001 Battery: 3750 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 357406049415001 IMEI spNet : 3A 75 04 06 94 14 05 00 IMEI svNet : 33 75 04 06 94 14 05 00 F7 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 8E65C761940F4ED4 Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
11-22-2015, 13:56 | #10 (permalink) |
Member: 879723 Status: Offline Thanks Meter: 6 | Nokia X2-05 RM-772 after flash n factory setting CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 how to solve CMLA Key status : Not Present |
