06-05-2013, 13:47 | #1 (permalink) |
Major Poster Join Date: Apr 2008 Location: Russia, Karelia Age: 46
Member: 756429 Status: Offline Thanks Meter: 3 | How to get Local/Test mode on RM-704 (C2-00) Here the dead mode logs: Connect phone on selected interface... Core : v1.63 , BB5XG FlashEngine : v4.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.99.mcusw PPM : rm704__03.99.ppm_i CNT : rm704__03.99.image_i_jblack_059C833 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully -> Read initial data failed : phone not in boot mode.. -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core : v1.63 , BB5XG FlashEngine : v4.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.99.mcusw PPM : rm704__03.99.ppm_i CNT : rm704__03.99.image_i_jblack_059C833 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully -> Read initial data failed : phone not in boot mode.. -> Boot fail... Flashing failed... Phone disconected! Connect phone on selected interface... Core : v1.63 , BB5XG FlashEngine : v4.1 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm704__03.99.mcusw PPM : rm704__03.99.ppm_i CNT : rm704__03.99.image_i_jblack_059C833 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.44_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! ===Flashing [MCU]=== File : rm704__03.99.mcusw Image : rm704__03.99.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01940000 Erasing, wait ... Erase done, time : 00:00:45 Write , Start : 0x40280000 , Len : 0x018C0000 Flashing , wait ... Region flash done, time : 00:01:12 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm704__03.99.ppm_i Image : package_i.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41BC0000 , Len : 0x00600000 Erasing, wait ... Erase done, time : 00:00:07 Write , Start : 0x41BC0000 , Len : 0x0037593C Flashing , wait ... Region flash done, time : 00:00:05 ===Flashing [CNT]=== File : rm704__03.99.image_i_jblack_059C833 Image : package_i_jblack_059C833.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x421C0000 , Len : 0x01C60000 Erasing, wait ... Erase done, time : 00:01:03 Write , Start : 0x421C0000 , Len : 0x00A80000 Flashing , wait ... Region flash done, time : 00:00:20 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:03:43 Reboot phone now... |
06-06-2013, 08:16 | #3 (permalink) |
Member: 756429 Status: Offline Thanks Meter: 3 | I tried to write a full pm file from the same model (rm-704) , and than it lost local\test mode, i was sure that it would be easy to restore have a back up. |
06-07-2013, 13:35 | #6 (permalink) |
Member: 756429 Status: Offline Thanks Meter: 3 | Thank you for the answer Br. I'd like to try any possibility of restore this Nokia. how to make full erase, does not work ERASE Button? it's writing not supported. Could you kick me to the right way. |
06-08-2013, 05:02 | #8 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | I not sure about CRT re-write will help. It possible kill certs via writing wrong XG213 rpl inside phone. P.S. I add erase, but not yet. On 17 of june I should pass diploma project to finish my study. After it will be much new things, now I'm rush with study. |
06-20-2013, 07:45 | #9 (permalink) |
Member: 756429 Status: Offline Thanks Meter: 3 | Yes, it is not possible to re-write CRT. I will wait news from your team about this question. I wish you to get a BEST mark on your exams. Thank you for the help. |
