03-10-2013, 06:10 | #2 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. What reason for it? If you want backup rpl and dara from it - Tick XG213 , Code/Rpl , Press Read Flash. for user data - untick code/rpl, read full, Open it via Data extraction from flash (Select Xg213 and needed data types for extract) If you want just kill phone - read rpl from it, write rpl from other XG213 phone. |
03-10-2013, 06:23 | #5 (permalink) |
Crazy Poster Join Date: Jan 2012 Location: KARACHI
Member: 1712648 Status: Offline Thanks Meter: 4,294,967,289 | Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - X2-05 Software ver : V 08.60 21-12-11 RM-772 (c) Nokia IMEI : 357406049409806 PPM : V 08.60 21-12-11 RM-772 (c) Nokia M_A CNT : Content: m_a_059H126 V 08.60 21-12-11 RM-772 (c) Nokia Product SN : 85049B4AH Product code : 059H126 Base Prd.code: 059F6M7 Module code : 0204959 Long Prod.SN : 0 Hardware info======= HWID : 1001 Batery: 3970 mV CMT BT: 19b5-22012 LCDVer: TPO Lock info =========== IMEI : 357406049409806 IMEI spNet : 3A 75 04 06 94 04 89 00 IMEI svNet : 33 75 04 06 94 04 89 00 F6 Sl Conf : 001-01-00000000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : A623DE02B59E42BB Country : Test SIM (Open) Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; CRT308 Backup Created INFINEON : SuperDongle not exist (It is Ok) CMLA Key status : Not Present SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! |
03-10-2013, 09:22 | #9 (permalink) |
Member: 1712648 Status: Offline Thanks Meter: 4,294,967,289 | Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Initializing Tests... IMEI : 357406049409806 , Phone : RM-772 X2-05 Get keys... PASSED | ST_SIM_LOCK_TEST PASSED | ST_SECURITY_TEST PASSED | ST_PWR_KEY_TEST PASSED | ST_CURRENT_CONS_TEST PASSED | ST_SIM_CLK_LOOP_TEST PASSED | ST_LCD_TEST PASSED | ST_LPRF_AUDIO_LINES_TEST PASSED | ST_LPRF_IF_TEST PASSED | ST_KEYBOARD_STUCK_TEST PASSED | ST_CAMERA_IF_TEST PASSED | ST_BT_WAKEUP_TEST PASSED | ST_HOOKINT_TEST PASSED | ST_BTEMP_TEST PASSED | ST_CDSP_PA_TX_POWER_TEST PASSED | ST_SLEEP_CLOCK_FREQ_TEST PASSED | ST_KEYB_LINE_TEST PASSED | ST_ADC_IF_TEST PASSED | ST_MEMORY_CARD_IF_TEST PASSED | ST_RF_PLL_TEST NOT EXECUTED | ST_FEM_CURRENT_TEST PASSED | ST_SECURITY_FUSE_TEST SelfTests end Done! Elapsed: 00:06:39 |
03-10-2013, 15:50 | #11 (permalink) |
Member: 1712648 Status: Offline Thanks Meter: 4,294,967,289 | Connect phone on selected interface... Core : v1.61 , BB5XG FlashEngine : v4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm618__08.35.mcusw PPM : rm618__08.35.ppm_meac CNT : rm618__08.35.image_meac_0595304 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000000000000022000509200C0000 CPU ID : BroadCom 21351 , Features : Dead-Test, USBRPL, FullUSB EM0 ID: 00005361 PUBLIC ID: 000000000099BB4D403D21E63ECB959AC0B11FE4 ASIC MODE ID: 00 ROOT KEY HASH: 1B0D74C532CA1C6133940C740E8C786E ROM ID: DE56D582BDDE7A3A Use BCM21351_usb2nd.fg , Rev : 2.1 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00300020 Req : XSR 1.6 Use BCM21351_XSR16_usbalg.fg , Rev : 2.1 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:01 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL: Check mode Select ASIC [C900] PAPUBkeys : E9700989029D9E899915F781B1582048E042A738 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354854048223699 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354854048223699_CR T.rpl === SW Version Check === - > UPGRADE === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm618__08.35.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [UPDAPP] Total writen 511 blocks TIME : Write time : 00:00:05 MCU Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [PPM]=== Erase : Processing rm618__08.35.ppm_meac Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm618__08.35.ppm_meac Total writen 100 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ===Flashing [CNT]=== Erase : Processing rm618__08.35.image_meac_0595304 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:01 Write : Processing rm618__08.35.image_meac_0595304 Total writen 341 blocks TIME : Write time : 00:00:03 CNT Write done ADL: Request programm status NAND status : 00000001 / 00000001 / 00000000 ADL: Close_Session Content: 000300000000010000000100000000 ADL: Reboot Flashing done! Total flash time : 00:00:12 Reboot phone now... Reading Phone Info.... Connected phone - Nokia X2-00 Software Info: V 08.35 09-01-12 RM-618 (c) Nokia IMEI: 354854048223699 PPM version : V 08.35 09-01-12 RM-618 (c) Nokia MEC Product code: 0595304 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 39 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Elapsed: 00:02:08 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Set phone in Normal mode... Restarting... Done! Connect phone on selected interface... Core : v1.61 , BB5XG FlashEngine : v4.0 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm772__08.35.mcusw PPM : rm772__08.35.ppm_m_c CNT : rm772__08.35.image_m_c_059H129 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" - just reinsert battery -> If flashing freeze - reinsert cable and try again --- Press phone's power button or insert charger! --- Connection opened successfully DBG : F00A1FB300020303010100FF CPUID : XGOLD 213 2nd boot Ok, 01 2nd ready, AA Sending Algo Algo sent Ok BL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI : 357406049409806 PCcode : 059H126 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\357406049409806_XG 213_CRT.rpl ===Flashing [MCU]=== File : rm772__08.35.mcusw Image : rm772__08.35.mcusw_ebl_psi.fls Cert block found, sending.... Cert sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x018C0000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x01840000 Flashing , wait ... Region flash done, time : 00:00:36 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip ===Flashing [PPM]=== File : rm772__08.35.ppm_m_c Image : package_m_c.ppm_ebl_psi.fls Cert block found, sending.... Cert sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41B40000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:09 Write , Start : 0x41B40000 , Len : 0x00591AE4 Flashing , wait ... Region flash done, time : 00:00:06 ===Flashing [CNT]=== File : rm772__08.35.image_m_c_059H129 Image : package_m_c_059H129.image.fls Cert block found, sending.... Cert sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42240000 , Len : 0x01BE0000 Erasing, wait ... Erase done, time : 00:01:04 Write , Start : 0x42240000 , Len : 0x00CC0000 Flashing , wait ... Region flash done, time : 00:00:16 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip Flashing done! Total flash time : 00:03:11 Reboot phone now... Reading Phone Info.... Connected phone - X2-05 Software Info: V 08.35 26-10-11 RM-772 (c) Nokia IMEI: 357406049409806 PPM version : V 08.35 26-10-11 RM-772 (c) Nokia M_C Product code: 059H126 Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Processing After Flash Defaults... FullFactorySet... Ok! UserDataDefaultsSet...OK! ServiceDefaultsSet... Ok! LeaveDefaultsSet... Ok! ProductTuneSet...OK! SwUpgradeSet...OK! Checking User Certificates... Total - 42 certs Data exist, skip certificate repair... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:53 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok |
03-11-2013, 05:25 | #13 (permalink) |
Member: 1712648 Status: Offline Thanks Meter: 4,294,967,289 | This is stolen imei when i erase imei then aal sim accepted but i dont know how to erase i know when rpl erase then set rester every 5mint but coustmor agree with this |
03-11-2013, 06:32 | #15 (permalink) |
Registered User Join Date: Mar 2008 Location: @ blacksheep digital
Member: 731353 Status: Offline Thanks Meter: 254 | sir dzirt sorry am offtopic but my question ...does best dongle support 5130,2700 simlock xtrction/repair..infact what type of interface do u use to read flash |
