11-15-2018, 10:47 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: City of Temples
Member: 729381 Status: Offline Thanks Meter: 248 | [how to] ta-1032 frp Code: Operation : Identify [ v1.07 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM10) MODE : BOOTROM PORT : 10 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : 0x00007017 : DA SEND ERROR! ERROR : SECURE BOOT : SLA REQUIRED IN BROM MODE! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
11-15-2018, 12:49 | #3 (permalink) |
Member: 729381 Status: Offline Thanks Meter: 248 | without pressing volume keys i get this error Code: Operation : Reset Settings [ v1.08 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM27) MODE : PRELOADER PORT PORT : 27 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! Reconnect Power/Cable! |
11-16-2018, 07:53 | #5 (permalink) |
Member: 729381 Status: Offline Thanks Meter: 248 | hello, battery is charged about 75% unable to identify phone in best i used mtk[SP] tab phone not connect in mtk[FP] tab info in base tab Code: Card found : 6CF1FE78 , v0122 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.08 Operation : Identify [FTM] [ v1.08 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : NE1 SW version : NE1-3380-0-00WW-B01 SW serialnm : NE1GAM4790902145 Bootloader type : SERVICE Security Version : 0004 Done! Elapsed: 00:00:26 Reconnect Power/Cable! |
11-16-2018, 20:55 | #7 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just updated my device to latest version. Strange. Code: Operation : Write FW [ v1.09 ] Setting : UserData preserve : False Setting : Bootloader update : True 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirm FAIL! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A484147346132A54FE7BA95A5DB DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A54FE7BA9564DB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3D60CF0054FC873B8B037xxxxx STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E [FL] : HW verification passed! Erase : 0x0000000001C80000 : 0x0000000005680000 Erase : 0x0000000007320000 : 0x0000000002000000 Erase : 0x0000000009B20000 : 0x000000017D4E0000 PMT Update : Skip Flashing now ... PROCESS : PRELOADER Unpack : NE1-0-3380-preloader_NE1.bin Flash : NE1-0-3380-preloader_NE1.bin Update bootloader code ... Update bootloader Ok! PROCESS : LK Unpack : NE1-0-3380-lk.img Flash : NE1-0-3380-lk.img PROCESS : BOOT Unpack : NE1-0-3380-00WW-boot.img Flash : NE1-0-3380-00WW-boot.img PROCESS : RECOVERY Unpack : NE1-0-3380-00WW-recovery.img Flash : NE1-0-3380-00WW-recovery.img PROCESS : LOGO Unpack : NE1-0-3380-logo.bin Flash : NE1-0-3380-logo.bin PROCESS : SECRO Unpack : NE1-0-3380-secro.img Flash : NE1-0-3380-secro.img PROCESS : TEE1 Unpack : NE1-0-3380-tee.img Flash : NE1-0-3380-tee.img PROCESS : TEE2 Unpack : NE1-0-3380-tee.img Flash : NE1-0-3380-tee.img PROCESS : SYS_INFO Unpack : fver Flash : fver PROCESS : SUTINFO Unpack : NE1-00WW-001-sutinfo.img Flash : NE1-00WW-001-sutinfo.img PROCESS : CDA Unpack : NE1-00WW-010-cda.img Flash : NE1-00WW-010-cda.img PROCESS : SYSTEM Unpack : NE1-0-3380-00WW-system.img Flash : NE1-0-3380-00WW-system.img PROCESS : CACHE Unpack : cache.img Flash : cache.img PROCESS : USERDATA Unpack : userdata.img Flash : userdata.img PMT Update : Skip SEC_DL : False (CUST) SEC_ID : 0x67887C7972766E6888787678777B796E Flashing finished! Done! Elapsed: 00:06:49 Reconnect Power/Cable! Operation : Identify [ v1.09 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek PreLoader USB VCOM (Android) (COM8) MODE : PRELOADER PORT PORT : 8 Waiting BOOT ack ... PRELOADER : ACK confirmed! BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY+DEV_CRT BROM : PRELOADER PORT AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 90014A484147346132A54FE7BA95A5DB DAInf: 4 : 2 : 155 DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 90014A484147346132A54FE7BA9564DB EMMC: VEN : HYNIX | OEM : 4A01 | DEV : HAG4a2 EMMC: BOOT1 : 0x00400000 [ 4,00 MB ] BOOT2 : 0x00400000 [ 4,00 MB ] RPMB : 0x00400000 [ 4,00 MB ] USER : 0x3AB400000 [ 14,68 GB ] SRAM: 0x00020000 [ 128,00 KB ] DRAM: 0x80000000 [ 2,00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 3D60CF0054FC873B8B0xxxxx STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : HIGH-SPEED Boot done! --- SysInfoSub : Patch Level : O00623 Display ID : 00WW_3_380 Ver. CodeName : REL Ver. Release : 8.0.0 Sec. Patch : 2018-07-05 Build Time : 1530275861 Product Model : NE1 Product Brand : alps Product Name : NE1_00WW_FIH Product Device : NE1 Product Manfct : alps Product Info : NE1 Board Platform : mt6737m --- SecuritySub : IMEI[0] : 35339xxxx IMEI[1] : 35339xxxx NVRAM check : Passed! Done! Elapsed: 00:00:30 Reconnect Power/Cable! Operation : Identify [FTM] [ v1.09 ] -> Power Off Phone, wait 5-10 seconds, Insert USB cable Wait for phone... Connect Ok! Device Found! Initialize ... Initialize Ok! Dev Model : NE1 SW version : NE1-3380-0-00WW-B01 SW serialnm : NE1GAM07604xxxxx Bootloader type : SERVICE Security Version : 0004 Done! Elapsed: 00:00:16 Reconnect Power/Cable! |
The Following 7 Users Say Thank You to JayDi For This Useful Post: |
