07-15-2013, 09:57 | #1 (permalink) |
Freak Poster Join Date: Dec 2004 Location: POLAND Age: 43
Member: 99605 Status: Offline Thanks Meter: 70 | how to write PM 1 and 309 card found: S/N xxxx registered to: me Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07A000014F880052AC5EB4AFE81B72BB8C8E4106 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:00 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : F2B05364E563A348608C1C3C9E54FE42AAAA1ACF CFL : Reading flash certs.... CFL : Reading NPC IMEI : 358307036994363 CFL : Reading CCC CFL : Reading HWC CFL: Close_Session Content: 000300000000040000000300000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\GSM\BEST165\Backup\Cert\358307036994363_2nd.rpl All done, Disconnecting Elapsed: 00:00:24 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Restore ccc/hwc not working |
07-15-2013, 12:03 | #3 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358307036994363 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358307036994363 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Phone disconected! |
07-15-2013, 12:28 | #4 (permalink) |
Member: 99605 Status: Offline Thanks Meter: 70 | Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358307036994363 Use custom key... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" disabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358307036994363 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358307036994363 Key file exists, no need to read... Step 1... Step 2... SX4 Auth fail... - > "Custom Keys" enabled, try again now - > If SDD original - "Use Server Sx4" Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 358307036994363 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Done! Operating mode is OK, no need change... Field 1 Record 0 write - Ok Record 2 write - Ok Record 4 write - Ok Record 6 write - Ok Record 8 write - Ok Record 13 write - Ok Record 16 write - Ok Record 18 write - Ok Record 20 write - Ok Record 24 write - Ok Record 25 write - Ok Record 26 write - Ok Record 28 write - Ok Record 29 write - Ok Record 31 write - Ok Record 34 write - Ok Field 309 Record 0 write - Ok Record 1 write - Ok Record 2 write - Ok Record 4 write - Ok Record 5 write - Ok Record 7 write - Ok Record 8 write - Ok Record 17 write - Ok Done! Elapsed: 00:00:03 Phone disconected! Connect phone on selected interface... Backup Certificates now... Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051105 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 07A000014F880052AC5EB4AFE81B72BB8C8E4106 ASIC MODE ID: 00 ROOT KEY HASH: B8C3ADECFC997FCD8081D3DEAF870B8C ROM ID: 4B9B75103E691FF8 Use URAPIDOv11_2nd.fg , Rev : 2.0 Ver : 12.8.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.5 Use URAPIDOv11_XSR15_alg.fg , Rev : 2.0 Ver : 12.8.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:00 CFL: Wait for Loader take control ... CFL: Check mode Phone ready, boot Ok TransReq set Ok PAPUBkeys : F2B05364E563A348608C1C3C9E54FE42AAAA1ACF CFL : Reading flash certs.... CFL : Reading NPC IMEI : 358307036994363 CFL : Reading CCC CFL : Reading HWC CFL: Close_Session Content: 000300000000040000000300000000 CFL: Reboot Wait, reconneting... SLx Simlock Data read ... Ok SL3 Simlock Sign read ... Ok WMDRM read ... Ok CRT308 Backup Created NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... SimLock Data saved... SimLock Key saved... WMDRM_PD Data saved... RPL saved : D:\GSM\BEST165\Backup\Cert\358307036994363_2nd.rpl All done, Disconnecting Elapsed: 00:00:17 Connect phone on selected interface... Phone found! Series 60 Device detected! read info... - Ok Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key is Ok SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Phone disconected! Connect phone on selected interface... Any solution for this phone ? |
07-16-2013, 06:58 | #7 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Restore original CCC/HWC from your rpl backup, try do again - SX4, without upload ticked. After select write PM, select, for example - RM-356 file, write it. |
