03-22-2017, 19:22 | #1 (permalink) |
Freak Poster Join Date: Sep 2012
Member: 1808452 Status: Offline Thanks Meter: 21 | How to write xxxxxxx.pm backup file I made reset counter with a tool after phone goes to contact service mode how to write back the 35826004xxxxxxxx.pm file or get away from contact service? nokia asha 201 Thanks |
03-23-2017, 09:36 | #3 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | File is not a flash file Its a backup from phone and in this format 355186059032019_22-03-2017_05.30.47.pm How to write back to phone? |
03-23-2017, 14:00 | #8 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | There is named by same name buttons in repair tab. And PM tool in service tab. |
03-23-2017, 14:59 | #11 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Seems as you have no idea at all how Nokia devices can be and should be serviced. Force device to local mode first by READ RPL button with Xgold ticked. |
03-23-2017, 15:28 | #12 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Thanks. contact service mode fixed but problem with unlocking Using F-bus count... Sending code 514855587938082 Level : 1 to SimLock Server... Simlock Server Answer: Phone already unlocked! Done! Reading Phone Info.... Connected phone - Nokia 201 Software ver : V 11.56 26-03-12 RM-799 (c) Nokia IMEI : 355186059032019 XappVer : 000008D4 PPM : V 11.56 26-03-12 RM-799 (c) Nokia C1 CNT : Content: tesco GB SL v2 V 11.56 26-03-12 RM-799 (c) Nokia Product SN : E01375DAH Product code : 059N6K9 Base Prd.code: 059P8Q0 Module code : 0205325 Long Prod.SN : 0 Hardware info======= HWID : 1202 Battery: 3798 mV CMT BT: 19e2-47026 LCDVer: TPO Lock info =========== IMEI : 355186059032019 IMEI spNet : 3A 55 81 06 95 30 02 01 IMEI svNet : 33 55 81 06 95 30 02 01 F4 Sl Conf : 234-00-00300000000 Sl Prof : 800000000003000-B Sl Aux : 000B0000 Hw Sig : 59E15A15D910A9D9 Country : United Kingdom Operator : Unknown Lock info: Block 1 L1:Open; L2:Close; Error collect lock info, try again CRT308 Backup Created CMLA Key status : Ok SimLock status : Ok Security status : Ok PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Writing same firmware with Product code : 059N6K9 will fix 'unknown operator'? or whaat should I do? Last edited by busfield; 03-23-2017 at 15:33. |
03-23-2017, 16:12 | #14 (permalink) |
Member: 1808452 Status: Offline Thanks Meter: 21 | Using F-bus count... Sending code 514855587938082 Level : 7 to SimLock Server... Simlock Server Answer: Bad Code... Done! Using F-bus count... Sending code 514855587938082 Level : 2 to SimLock Server... Simlock Server Answer: Bad Code... Done! |
