01-07-2016, 20:57 | #1 (permalink) |
Junior Member Join Date: Aug 2010
Member: 1374163 Status: Offline Thanks Meter: 8 | i need driver nokia 105 rm 1133 my windows is 7 64bit plasea help me i need this driver. |
The Following 2 Users Say Thank You to hamanm For This Useful Post: |
01-07-2016, 21:15 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. All drivers on support. FlashMode : NokiaSerialDriver Service : WinUSB There is one package with all need drivers. |
01-07-2016, 21:48 | #4 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Index of pub/software/Drivers/ All is here. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
01-08-2016, 12:28 | #8 (permalink) |
Member: 1374163 Status: Offline Thanks Meter: 8 | I DO EVERY THING BUT Card found: S/N : E492796E , v0122 Registered to: haman Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Connect phone on selected interface... |
12-23-2016, 00:16 | #11 (permalink) | |
Insane Poster Join Date: Mar 2011 Location: Bubong, Ramain ditsa-an
Member: 1540244 Status: Offline Sonork: 100.1613798 Thanks Meter: 13 | Quote:
The Following User Says Thank You to aljuhanie For This Useful Post: |
01-23-2017, 13:42 | #12 (permalink) | |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | Quote:
thanks. | |
The Following User Says Thank You to aydin.gsm1 For This Useful Post: |
12-17-2018, 17:22 | #15 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Rawalpindi
Member: 2628591 Status: Offline Sonork: 100.1582347 Thanks Meter: 85 | Hi to all, I always have this problem...after fresh windows. try and try some time again fresh windows.... no pet solution that do this and all will be OK only hit and trial method work. No bla bla from any one....... i am here waiting do it from online...... waiting Thanks Br Raja |
