11-01-2014, 17:56 | #1 (permalink) |
No Life Poster Join Date: Jun 2010 Location: Pakistan TDM
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | I need help about nokia 5230 then this after flash handset give nokia logo then blue lcd and then off . after that i flash the handset with latest flash file 51.9.002 then set become completely dead and give only vibrate then i download same product code flash file but that file had diffrent RM-593 handset also have same rm on the back of handset i also flash the handset with that file RM-593_40.8.003 but set is still same only vibrate i also flash the handset with fbus cable with both flash files RM-588 latest and RM-593 latest but no luck only vibrate please help me how to solve the handset thanks in Advance |
11-02-2014, 07:16 | #4 (permalink) | |
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | Quote:
i accept Best not allow such fun with phone killing. but can u tell me BEST can repair such problem i m searching for the solution that's why i m asking for the help plz help me sir | |
11-02-2014, 09:57 | #5 (permalink) |
No Life Poster Join Date: Aug 2013 Location: CHENNAI, TAMILNADU,INDIA
Member: 2001848 Status: Offline Sonork: 100.1658212 Thanks Meter: 581 | flash with same product code latest flash file...... if the previous version u installed in phone is higher than product code flash file........ do downgrade,,,,, before every thing...... take all backups like rpl,pm, all certificates... |
The Following User Says Thank You to mubarak2344 For This Useful Post: |
11-02-2014, 11:04 | #7 (permalink) |
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | before flash set was alive i got the handset just for flash before flash i chack it's software info and imei all was ok phone had low version then this 51.6.002 i forgate which version phone had plz sir help me to solve th problem |
11-02-2014, 11:41 | #9 (permalink) |
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | On RM-588_51.0.002 give this errror again and again ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... === SW Version Check === - > REFLASHING or UPGRADE === SW Version Check === ADL : ASIC CMT select Ok ===Flashing [MCU]=== Erase : Processing RM-588_51.0.002_prd.core.C00 Found 5 areas to erase Erasing area 0x00040000 - 0x00082FFF, NAND, CMT Result: 0000 Erasing area 0x00083400 - 0x003FFFFF, NAND, CMT Result: 0000 Erasing area 0x00400000 - 0x007FFFFF, NAND, CMT Result: 0000 Erasing area 0x00800000 - 0x00D5FFFF, NAND, CMT Result: 0000 Erasing area 0x00D60000 - 0x09E5FFFF, NAND, CMT Result: 0000 Erase partition 0x0A Partition erase Ok Partitioning : Ok [5] TIME : Erase time : 00:00:00 Write : Processing RM-588_51.0.002_prd.core.C00 Total 461 [461/0/0] blocks to write, writing... CMT : Writing Hash CERT [ADA] CMT : Writing Hash CERT [KEYS] CMT : Writing Hash CERT [PRIMAPP] CMT : Writing Hash CERT [RAP3NAND] CMT : Writing Hash CERT [PASUBTOC] CMT : Writing Hash CERT [PAPUBKEYS] CMT : Writing Hash CERT [SOS*UPDAPP] CMT : Writing Hash CERT [SOS*ENO] CMT : Writing Hash CERT [SOS*DSP0] CMT : Writing Hash CERT [SOS*ISASW] CMT : Writing Hash CERT [SOS+CORE] CMT : Writing Hash CERT [SOS+ROFS1] Error: Write Failed, ERR0 : Connecttion lost, at 06080400:00040000 Connect phone on selected interface... Elapsed: 00:00:41 Connect phone on selected interface... |
11-02-2014, 11:47 | #10 (permalink) |
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | and on RM-588_51.9.002 give error Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-588_51.9.002_prd.core.C00 PPM : RM-588_51.9.002_prd.rofs2.V25 PPM2 : RM-588_51.9.002_C01_prd.rofs3.fpsx CNT : RM-588_51.0.002_000_001_U002.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 01400114148C0052656D18A97FF657BE33A30D39 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... === SW Version Check === - > DOWNGRADE DETECTED!!! |
11-02-2014, 11:49 | #11 (permalink) |
Member: 1330570 Status: Offline Sonork: 100.1611533 Thanks Meter: 408 | And on RM-593_40.8.003 give this error Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : RM-593_40.8.003_prd.core.C00 PPM : RM-593_40.8.003_prd.rofs2.V17 PPM2 : RM-593_40.8.003_C02_prd.rofs3.fpsx CNT : RM593_40.8.003_001_002_U005.uda.fpsx Flashing phone now... [Gen] Rules accepted for : RAPIDO Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Press phone's power button or insert cable & charger! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000010000022600010006400C192101051103 CPU ID : RAPIDOv11 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00000296 EM1 ID: 00000B22 PUBLIC ID: 01400114148C0052656D18A97FF657BE33A30D39 ASIC MODE ID: 00 ROOT KEY HASH: 479C6DDE3942E12C429C1D6ADED80371 ROM ID: 4B9B75103E691FF8 PatchRAWLoader: Patched OK Processing RAWLOADER... Processing RAP3NAND ... Processing PASUBTOC ... Processing PAPUBKEYS... Processing UPDAPP ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 Waiting for response: 29 ADL -> [2nd] changing... ADL Server confirm flashmode! ADL : Auth done... === SW Version Check === - > DOWNGRADE DETECTED!!! - > Download latest Flash Files version and try again! - > Stop killing phone, break flashing! === SW Version Check === ================= ADL : End flashing ADL : Finalize... Durring the flashing handset give only whiite lcd |
11-03-2014, 05:03 | #14 (permalink) |
No Life Poster Join Date: Jul 2013 Location: kpk Pakistan
Member: 1985156 Status: Offline Sonork: 100.1652265 Thanks Meter: 313 | 1st step : RPL backup, PM backup, PP backup 2nd step : Erase FLASH 3rd step : Flash needed FW version 4th step : RPL restore 5th step : Repair SDD if needed, do Local SX4 + Upload PM 6th step : Factory sets, edit production data, run phone result c7 rm-675 111.040.1414 nokia hang and of downgrad working v25 Reading Phone Info.... Connected phone - Nokia C7-00 Software ver : V 92_11w37 14-09-11 RM-675 (c) Nokia IMEI : 355379041033449 XappVer : 000007BC Ape Ver : 025.007 APE Var : 025.007025.007.10.01025.007.00.01 APE ADSP: 256 DSP Ver : 92_11w36 APE Test: rm675_ENO_v_0.0491 PPM : CNT : Product SN : 0 Product code : 059B662 Long Prod.SN : 0 Hardware info======= HWID : Retu : 40 Tahvo : 00 Batery: 3685 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 355379041033449 IMEI spNet : 3A 55 73 09 14 30 43 04 IMEI svNet : 33 55 73 09 14 30 43 24 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= LOCKS : All Open ============================= CRT308 Backup Created SDD key status : Ok CMLA Key status : Not Present SimLock status : Ok Security status : Damaged!!!!! PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 User code : Crypted UserDataExLevel : Low [Gallery] , FullFlash method Done! Checking StartUp data ... ----------------------- SDD Key status : SDData is Ok CMLA Key status : CMLA key Not exist SimLock status : SimLock is Ok Security status : Security Damaged!!!!! - > Do Local SX4 or Server SX4 , Upload Tune ( checkbox or manual ) ----------------------- PA_SimLock Version : PA_SL3 phone , SP_CODE_LEN : 15 Done! Local SX4 procedure started... Check SD : Key is Ok Phone Imei: 355379041033449 Use custom key... Step 1... Step 2... Step 3... SX4 Auth - Ok Upload PM checked Uploading RF/Battery tune to phone... Using : RM-675.pm Setting to : 059B662 Operating mode is OK, no need change... Check ST_SECURITY now... Security status : ST_SECURITY => OK Done! Elapsed: 00:00:01 Upload done Reading Phone Info.... Connected phone - Nokia C7-00 Software ver : V 92_11w37 14-09-11 RM-675 (c) Nokia IMEI : 355379041033449 XappVer : 000007BC Ape Ver : 025.007 APE Var : 025.007025.007.10.01025.007.00.01 APE ADSP: 256 DSP Ver : 92_11w36 APE Test: rm675_ENO_v_0.0491 PPM : CNT : Product SN : 0 Product code : 059B662 Long Prod.SN : 0 Hardware info======= HWID : Retu : 40 Tahvo : 00 Batery: 3684 mV APE BT: HCI Version 4 (rev. 0). LMP Version 4 (rev. 7455). Manufacturer 13. APE HW: 256 Lock info =========== IMEI : 355379041033449 IMEI spNet : 3A 55 73 09 14 30 43 04 IMEI svNet : 33 55 73 09 14 30 43 24 F1 Conf key : 0000000000000000 Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Counters : Key 0 [3] , Fbus 0 [10] Blocks : 7 LOCK STATUS : ============================= BLK : 1 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 2 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 3 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 4 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 5 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 6 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open BLK : 7 Lock1:Open Lock2:Open Lock3:Open Lock4:Open Lock5:Open ============================= |
