08-06-2014, 12:43 | #31 (permalink) | |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Check that post about connect and install drivers : http://forum.gsmhosting.com/vbb/10478458-post5.html Here about drivers: http://forum.gsmhosting.com/vbb/10478957-post30.html It is OK completely, when phone "dead" and go to QC mode. After divers will be installed - you can flash it without problems. By the way : Market problem - do you used Built in BEST package? Because I tested it few times ( full reflash , install, check, run few games/apps , check built-in app buy and rest things ) and it seems to working. Few times it has write about need install some services, but after back to app - it continue work as should. If problems will be - let me know and we will check it more deep. @All Note : Before Install Emergency driver - make sure you have installed full driver set : http://bb5tool.com/download/index-1...._MTKx_Asha.rar But it MUST installed anyway, cos consist all need drivers for Service and most Flash mode operations. | |
08-25-2014, 11:21 | #33 (permalink) | |
No Life Poster Join Date: Oct 2007 Location: chennai Age: 38
Member: 616909 Status: Offline Sonork: 1672125 Thanks Meter: 648 | Quote:
(nokia bootmgr ) so i need driver pls help me | |
08-25-2014, 22:09 | #35 (permalink) |
Insane Poster Join Date: May 2014 Location: Nigeria Age: 36
Member: 2194412 Status: Offline Sonork: ****uy Thanks Meter: 1 | i need help for my nokia 1013 flash process hello pls i need help if i wan to flash this is the info that is showing me pls i need help pls help me? Connect phone on selected interface... Core : v1.95 , NXP FlashEngine : v3.2 Flash Mode : System Update (System , Boot) : Not Touch UserData Check and select files according selected FlashMode Ok, Set : rm1013_2.0.0.11_059V782_001_01_rawprogram_unsparse _ui.xml Ok, Set : rm1013_2.0.0.11_prog_emmc_firehose_8x10.mbn Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Press and hold 'Volume Down' and 'Power' buttons 3. When feel short vibra - release 'Power' button, but keep hold 'Volume Down' button 4. Insert USB cable and hold button, until phone will be detected Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed Prepare Init Failed [FireHorse_Error] : Phone not detected in any supported mode. Check Drivers, Cable, Battery Flash Error Break flashing! Connect phone on selected interface... |
08-26-2014, 03:01 | #36 (permalink) | |
Close ALL other software, which can use ports. ALL. Install drivers from support area. Reboot PC. Close ALL sw again. Try. | |
08-28-2014, 13:08 | #38 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | http://forum.gsmhosting.com/vbb/f641...-made-1846300/ Check update log. Go on support and download X2 flash driver for WINXP. |
09-09-2014, 02:40 | #42 (permalink) | |
12-13-2014, 11:50 | #43 (permalink) |
No Life Poster Join Date: Sep 2005 Location: Morocco in my shop Age: 40
Member: 179651 Status: Offline Thanks Meter: 92 | Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 10.01.11 00-00-00 RM-1011 IMEI 1 : 35364xxxxxxxxxx IMEI 2 : 35364xxxxxxxxxx XappVer : 00000794 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : AE CNT : PEARL.10.01.11.p3 Product SN : 286579FAU Product code : 059W0V9 Base Prd.code: 059V3X9 Module code : 0206023 Hardware info======= HWID : 3001 LCDVer: TPO Lock info =========== IMEI : 35364xxxxxxxxxx IMEI spNet : 3A 35 46 xx xx xx xx xx Lock info: Block 1 L1:Close; SimLock status : Ok Security status : Ok Done! Unlock procedure started... Using F-bus count... Sending code 399529478253436 Level : 7 to SimLock Server... Simlock Server Answer: Error Done! |
12-13-2014, 14:07 | #45 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | MTKx : Use manual method ( keyboard ) P.S. : opps, with my inet I very slow to answers Last edited by Dzirt; 12-13-2014 at 14:15. |
The Following User Says Thank You to Dzirt For This Useful Post: |
