04-15-2019, 14:05 | #1 (permalink) |
Freak Poster Join Date: Aug 2015 Location: Choubara(Layyah Pakistan..)
Member: 2451856 Status: Offline Thanks Meter: 247 | Nokia 105 ta1034 hang on logo fixed with infinity best nk2... Nokia 105 ta1034 hang on logo fixed with infinity best nk2... Operation : Write FirmWare [ v1.13 ] Setting : UserData erase : True Setting : LangPack Only : True 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM18) MODE : NOKIA USB SERIAL PORT : 18 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 6E29B279E3F4F81DC6C5E395D43F2D65 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : SWR : 10.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : N103.10.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Sync Passed! DA : Authentification pass! DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0020 : 0016 : 0000 NOR: [MXIC] MX25L3291FWJI_09 NOR: TSIZE : 0x00400000 [ 4.00 MB ] PSIZE : 0x00400000 [ 4.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.00.11 [TA-1034] DEV SoftwareVersion : 10.02.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : LANG : TA-1034_LANG_PACK_ROM_IM_eMP_11.00.11_001 CUST : TA-1034_CUSTPACK_ROM_IM_eMP_11.00.11_001 JUMP : TA-1034_JUMP_TABLE_IM_eMP_11.00.11_001 Prepare FlashSet : DCR : TA-1034_LANG_PACK_ROM_IM_eMP_11.00.11_001 DCR : TA-1034_CUSTPACK_ROM_IM_eMP_11.00.11_001 DCR : TA-1034_JUMP_TABLE_IM_eMP_11.00.11_001 Prepare Target SDS : OK : 0x003F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1034_LANG_PACK_ROM_IM_eMP_11.00.11_001 Write : TA-1034_CUSTPACK_ROM_IM_eMP_11.00.11_001 Write : TA-1034_JUMP_TABLE_IM_eMP_11.00.11_001 Write done, waiting target response ... Write flash done! Verify Target FlashContent Verify : TA-1034_LANG_PACK_ROM_IM_eMP_11.00.11_001 Verify : TA-1034_CUSTPACK_ROM_IM_eMP_11.00.11_001 Verify : TA-1034_JUMP_TABLE_IM_eMP_11.00.11_001 Done! Elapsed: 00:00:38 Reconnect Power/Cable! |
The Following 3 Users Say Thank You to sanwal malik For This Useful Post: |
06-23-2019, 14:47 | #3 (permalink) |
Insane Poster Join Date: May 2013 Location: Port Harcourt
Member: 1933270 Status: Offline Thanks Meter: 18 | having issues flashing this phone... when reading info, it shows USB not recognised here is LOG Operation : Write FirmWare [ v1.16 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM51) MODE : NOKIA USB SERIAL PORT : 51 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : E4139171B66870D6481F1B54D716E24F BROM : Run BootLoader ... BROM : BootLoader start Failed! Check device Battery and BSI line! Error : Fail to init protocol! Remove battery, cable. Check cable and connection. Repeat operation! |
The Following User Says Thank You to ebemka For This Useful Post: |
06-23-2019, 16:07 | #5 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
