10-05-2015, 07:34 | #1 (permalink) |
Freak Poster Join Date: May 2013
Member: 1939490 Status: Offline Sonork: 100.1638723 Thanks Meter: 22 | infinity Best Dongle error. ---------- Process started: 10/5/2015 12:01:16 PM ---------- DongleManager [Infinity-Box] v1.58 [10/5/2015 12:01:16 PM] PC HWID: 97DAF430E37D4378ECFA1108E98536F1 Card-Reader: FT SCR2000 0 HWID: 01097E8024881292 Type: [BEST] S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0010] Dongle authentication failed. Retry upgrade. 1) i tried to activate Chinese Miracle-2 (Test Version) software activation for Infinity. 2) then i tried to update dongle 3) i got stuck dongle manager 4) then i tried again update i got this error, [0392637E80] |
10-05-2015, 09:46 | #2 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | - Update your Card-Reader Drivers: Drivers - http://server1.infinity-box.com/down...Fetian_FT2K.7z Instruction - http://server1.infinity-box.com/down...er_drivers.pdf Also you can insert Smart-Card into another Card-Reader. Update Dongle again ONLY ONE TIME !!! |
10-06-2015, 02:56 | #3 (permalink) |
Member: 1939490 Status: Offline Sonork: 100.1638723 Thanks Meter: 22 | Again Error Box/Dongle type selected: [BEST] ---------- Process started: 10/6/2015 7:25:47 AM ---------- DongleManager [Infinity-Box] v1.58 [10/6/2015 7:25:47 AM] PC HWID: 2057BC0CA370A6EAAC7B1F5EC27AE35E Card-Reader: Alcor Micro USB Smart Card Reader 0 HWID: 00048F7203EF1292 Type: [BEST] S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0010] Dongle authentication failed. Retry upgrade. |
10-06-2015, 21:51 | #5 (permalink) | |
Disconnect all Dongles. Connect to PC only BEST Dongle and try again. | |
12-12-2015, 13:34 | #6 (permalink) |
Insane Poster Join Date: Nov 2011 Age: 42
Member: 1683660 Status: Offline Thanks Meter: 14 | i have same problem please help me Box/Dongle type selected: [BEST] ---------- Process started: 12-Dec-15 2:21:53 PM ---------- DongleManager [Infinity-Box] v1.60 [12-Dec-15 2:21:53 PM] PC HWID: 02ABAACA5E145DABDF856F8632D27893 Card-Reader: DITS CCID Smart Card Reader 0 HWID: 0104AA7908B51292 Type: [BEST] S/N: -------- Version: Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server reported error:[0010] Dongle authentication failed. Contact to [email protected] |
12-12-2015, 19:45 | #7 (permalink) | |
12-15-2015, 14:35 | #9 (permalink) | |
2. DITS card-reader gives a lot of problms with Dongle update 3. I am sad to see that you have trid to repeat this operation many times instead of send an e-mail. You can contact us in 3 days. Code: - Server lock account automatically for a 3 days after 3 usless tries (attacks) | |
06-05-2017, 08:31 | #10 (permalink) |
No Life Poster Join Date: Apr 2008 Location: jammu
Member: 750118 Status: Offline Sonork: [email protected] Thanks Meter: 51 | == DongleManager [Infinity] v1.70 [05-06-2017 12:58:29] === Box/Dongle type selected: Infinity-Box/Dongle Card-Reader: Gemalto e-gate Smart Card 0 HWID: 0001DAD600001942 === Process started: 05-06-2017 12:58:29 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected. Contact to http://www.infinity-box.com/support/?r=2 |
06-05-2017, 09:50 | #11 (permalink) | |
Member: 148515 Status: Offline Thanks Meter: 19,534 | Quote:
06-03-2020, 17:46 | #12 (permalink) |
Junior Member Join Date: Dec 2010 Location: Nairobi
Member: 1467656 Status: Offline Thanks Meter: 1 | I got this problem, was upgrading my best dongle test Chinese miracle-2(Test Version) "=== DongleManager [Infinity] v1.80 [6/3/2020 19:38:41] === Box/Dongle type selected: [BEST] Card-Reader: FT SCR2000 0 HWID: 00079E6520281292 === Process started: 6/3/2020 19:38:42 === Connecting to server Server connection successfully established Checking DongleManager version... Your DongleManager is up-to-date Checking Dongle Identification... Authenticating on server... Authentication stage error: Server answer:[0010] Dongle Authentication fail. Probably last attempt was interrupted or wrong Smart-Card connected." |
06-04-2020, 11:13 | #13 (permalink) | |
Install required Card-Reader Drivers: - File with Drivers: CardReader_Fetian_FT2K.7z - File with Instruction: Infinity-Box_How_to_update_FT_SCR2000_CardReader_drivers.pd f Drivers version after installation should be 2.5.6.0823 or 2.5.9.1202 Download files - https://www.infinity-box.com/support/?r=6 OR Insert Smart-Card into another Card-Reader (good result for today is with Alcor Card-Reader) The next steps are: - run DongleManager - update Dongle firmware IMPORTANT: only ONE update try is allowed so in case of problem DO NOT try to update card again ! | |
