10-22-2020, 11:29 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: in your hert
Member: 618615 Status: Offline Thanks Meter: 85 | ta 1139 connectivity problem 1. nokia mtk sp phone conected here is log ; Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM12) MODE : BOOTROM PORT : 12 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT0000 , SBID : 0x0000 , HWVR : 0x0000 , SWVR : 0x0000 TYPE : LEGACY MTK Info : Device is not supported yet! Reconnect Power/Cable! 2. nokia mtk fp log Operation : Identify [ v1.20 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... not connet MediaTek USB Port i m use alll types of driver but same plz tell me any driver or other advice |
10-22-2020, 11:40 | #2 (permalink) | |
No Life Poster Join Date: Apr 2015 Location: LOOLCANO Taba Day.
Member: 2385819 Status: Offline Sonork: No More Used Thanks Meter: 826 | Quote:
Mabye This Is Clone Mobile . Once Try With CM2 1.58 Version . | |
10-22-2020, 14:13 | #4 (permalink) |
No Life Poster Join Date: Mar 2015 Location: Islam Age: 35
Member: 2371500 Status: Offline Thanks Meter: 5,792 | bro Nokia 110 DS TA-1192 original one has SPD CPU CLONE IS MTK DONT TRUST SELLER BECAUSE EITHER CHEATER OR HE NOT RECOGNIZE CLONE FROM ORIGINAL |
The Following User Says Thank You to profkefah For This Useful Post: |
10-23-2020, 07:49 | #5 (permalink) |
Member: 618615 Status: Offline Thanks Meter: 85 | bro nokia 210 and 110 different this is nokia 210 ta 1139 [QUOTE=profkefah;14247961]bro Nokia 110 DS TA-1192 original one has SPD CPU CLONE IS MTK DONT TRUST SELLER BECAUSE EITHER CHEATER OR HE NOT RECOGNIZE CLONE FROM ORIGINAL[/QUOTE this is nokia 210 ta 1139 |
10-24-2020, 12:17 | #8 (permalink) | |
Member: 618615 Status: Offline Thanks Meter: 85 | but this one is orignal if clone then conect on chines tools Quote:
infinity team is worlds most sleeping team when team awake then solution ready | |
10-24-2020, 23:04 | #10 (permalink) | |||
Member: 163 Status: Offline Thanks Meter: 7,772 | [QUOTE=raza ahmad;14248344] Quote:
is it original or not, until connected to BEST and about ta-1139 ... it's MTK in original, but boot info will easy show, if original or clone ... Quote:
b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |||
10-28-2020, 07:10 | #11 (permalink) | |
Member: 618615 Status: Offline Thanks Meter: 85 | bro nokia 210 and 110 different this is nokia 210 ta 1139 [QUOTE=Brka;14249569] Quote:
2 . a new box packed nokia 210 ta 1139 not connect this is driver problam this will show mediatek driver adn not connect with best software 3 . cm2 connect but not have boot files miracle box connect but not have boot files | |
02-25-2021, 14:05 | #12 (permalink) | |
No Life Poster Join Date: Oct 2015 Location: Pakistan
Member: 2478233 Status: Offline Thanks Meter: 596 | [QUOTE=raza ahmad;14252123] Quote:
10-19-2022, 10:54 | #14 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Egypt Age: 41
Member: 153397 Status: Offline Sonork: 113032 Thanks Meter: 372 | its done on 1.58 Card found : S/N : xxxxxxx , v0153 Chinese Miracle II [MTK module] v 1.58 Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:12 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Device boot not done Check Drivers Try again Boot Error! Operation Failed Elapsed: 00:00:09 Reconnect Power/Cable! Operation : Read Flash [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 8819A0FB121714D2D66ECFC20BE1DFB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Reading Flash Content now ... Read Flash now Read Ok , 16777216 bytes read Check and collect compile info File_Info : J021_5_60A_CTC_PCB01_gprs_MT6260_S00.J021_5_60A_ST 7789S_JD9851_CTC_V01.bin FileVersion : J021_5_60A_ST7789S_JD9851_CTC_V01 [ScatCFG] : MT6260 / J021_5_60A_ST7789S_JD9851_CTC_V01 / NOR , SF Firmware saved to : C:\InfinityBox\CM2MTK\Read_out\J021_5_60A_CTC_PCB0 1_gprs_MT6260_S00\ Done! Elapsed: 00:00:50 Reconnect Power/Cable! Operation : Read UserCode [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 8819A0FB121714D2D66ECFC20BE1DFB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Read ExtData Sorting ExtData Reading UserCode Active : Yes , Code : 1561561 PLock|MobTrack : Not active Done! Elapsed: 00:00:15 Reconnect Power/Cable! Operation : Format FileSystem [ v1.58 ] 1. Power Off Phone , Remove battery , Insert back 2. Insert USB cable. In some cases require hold BootKey ( '*' ) Wait for phone... Phone found! [ 33 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0000 BB_CPU_SN : 8819A0FB121714D2D66ECFC20BE1DFB9 BROM Protocol Version : 05 Setting... Setting done , result code 0x000E BROM stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... InitRes : 00000000 DEV[0] : C800 6000 1800 0000 DEV[1] : 0000 0000 0000 0000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F4 , [GigaDevice] GD25LQ128 [0] : FLASH_DIE : 00C8 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 INT_RAM : 0x0000D000 EXT_RAM : 0x00800000 Backup done Executing FFS FORMAT now... FAT_RANGE : 0x00E00000-0x00FFFFFF , LEN : 0x00200000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Done! Elapsed: 00:00:22 Reconnect Power/Cable! |
