09-22-2018, 09:38 | #31 (permalink) |
Freak Poster Join Date: Jun 2010 Location: South Azerbaycan Age: 40
Member: 1333047 Status: Offline Sonork: 100.1618775 Thanks Meter: 278 | uk off option in dongle manager selected and uk.off file copied already, but problem not solved. |
09-22-2018, 11:13 | #36 (permalink) | |
No Life Poster Join Date: Aug 2011 Location: Afghanistan
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | Quote:
Same problem here in reading 3310 TA-1030 firmware WBR | |
09-22-2018, 11:27 | #38 (permalink) |
Member: 1646177 Status: Offline Sonork: 100.1604654 Thanks Meter: 369 | PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 786876FD59B0552A466ABA830CA6D69F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.11.02.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 786876FD59B0552A466ABA830CA6D69F PRDC : 059X9S4 IMEI[1] : 355810094370916 IMEI[2] : 355810095370915 Done! Elapsed: 00:00:38 Reconnect Power/Cable! Operation : Read FirmWare [ v1.05 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM7) MODE : NOKIA USB SERIAL PORT : 7 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 786876FD59B0552A466ABA830CA6D69F BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.11.02.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 CODE : 0x00CD0000 Reading Flash ... Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! |
09-22-2018, 12:13 | #39 (permalink) |
No Life Poster Join Date: Sep 2006 Location: ---> Hope
Member: 355782 Status: Offline Thanks Meter: 1,265 | Waiting for COM (Rx , Tx) integration for FP phones. will be very helpful if team add the feature. Last edited by Nasir Mobiles; 09-22-2018 at 12:21. |
09-22-2018, 14:04 | #40 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Some users use different name and pwd and etc. There will be no such option. Login option not need also. | |
09-22-2018, 14:12 | #45 (permalink) | ||
We uploading firmwares for them on support right now. When all will be ready - we will make new update and announce it. | ||
The Following 4 Users Say Thank You to JayDi For This Useful Post: |
