Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 09-21-2018, 10:48   #1 (permalink)
Member: 1043909
Thanks Meter: 49,412
Infinity-Box [BEST] NK2 v1.05 - Nokia 3310(2G), Nokia 5.1 and other models support
Infinity-Box [BEST] NK2 v1.05 - Nokia 3310(2G), Nokia 5.1 and other models support activated
Nokia 3310(2G), Nokia 5.1 and other models support activated !
- Nokia MTK Feature line support activated
- Nokia 3310(2G) line support activated !
Next revision of 3310 (2G) are supported:
Nokia 3310 : RETRO : TA-1008/TA-1030
For now the next features are supported:
> Firmware flashing ( Factory/BEST firmware packages )
> Firmware reading
> Format FS / Reset Settings
> Identify ( read complete device info & check/verify security area )
Other models support enabled ( supported in BEST v1.xx line ) :
Nokia 108: RM-944, RM-945, RM-1124
Nokia 220: RM-969, RM-970, RM-971, RM-1125
Nokia 225: RM-1011, RM-1012, RM-1043
Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122
Nokia 215: RM-1110, RM-1111, RM-1112
Nokia 105: RM-1133, RM-1134, RM-1135
Nokia 222: RM-1136, RM-1137
Nokia 230: RM-1172, RM-1173
Nokia 216: RM-1187, RM-1188
Nokia 150: RM-1189, RM-1190
> Firmware reading
Changes from v1.xx line:
Complete protocol rebuild - faster, safer, more stable
FW read/make now direct, do not need additional read/convert operations
FW read now more faster
Devices not stuck in flash mode after some operations
- Nokia 5.1 : CO2 : TA-1061/TA-1075/TA-1076/TA-1081/TA-1088
> Flashing ( Factory/BEST NB0 files )
> Reset Settings / FileSystem
> Reset FRP
> Identify
> Repair Security
> SP Unlock
Support is standalone, no server and/or credits required !
- Changes/Fixes
> MTK SP line
Nokia 1: FRT : FRONTIER : TA-1047/TA-1060/TA-1056/TA-1079/TA-1066
Fixed BROM mode support
Fixed dead mode flashing
Fixed SP unlock
Nokia 3.1: ES2 : ESSENTIAL2 : TA-1049/TA-1057/TA-1063/TA-1070/TA-1074
Improved flashing in MTK mode
Fixed issues with FOTA after flashing
> QLM SP line
Removed legacy servicing methods
Flashing engine updated
- Other
Settings Tab activated
> Setup FeaturePhones DataPackage path
> Setup SmartPhones DataPackage path
> Setup IOS user credentials ( for use server-based operations )
Lot of fixes and global changes at all
- Support
Hundreds of firmwares for Nokia 3310 (2G) are in support area
> Check out for need region packages or language packages on support area first! Or read from any well working device which you have.
Nokia 230: RM-1172, RM-1173 - HMD and MS LEGACY different firmwares are in support area
Nokia 216: RM-1187, RM-1188 - HMD and MS LEGACY different firmwares are in support area
Nokia 150: RM-1189, RM-1190 - HMD and MS LEGACY different firmwares are in support area
Download link
Subscribe to Telegram channel and get news faster !
How to upload files to support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 80 Users Say Thank You to YellowBoss For This Useful Post:
Old 09-21-2018, 10:58   #2 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 488
Nokia 3310 TA-1030 Format Done
Operation : Reset Settings [ v1.05 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Care Suite USB Serial Port (COM45)
MODE : NOKIA USB SERIAL
PORT : 45
BROM : Init BROM
BROM init passed!
CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 9A48DA85EE231131194DCB2C186E4A16
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : RETRO.11.02.11.p1
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6260
AGENT : RETRO.11.02.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8B
NOR: 00C2 : 0025 : 0038 : 0000
NOR: [MXIC] MX25U12835FZNI_10G
NOR:
TSIZE : 0x01000000 [ 16.00 MB ]
PSIZE : 0x01000000 [ 16.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
FFS Info exists in MAUI : 0x00CD0000 : 0x00324000
FFS Format ...
FFS Format Ok!
Done!
Elapsed: 00:00:37
Reconnect Power/Cable!
The Following 10 Users Say Thank You to nahidroman For This Useful Post:
Old 09-21-2018, 11:13   #3 (permalink)
Member: 1352268
Not showing in support
Old 09-21-2018, 11:18   #4 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 488
Download link
The Following 8 Users Say Thank You to nahidroman For This Useful Post:
Old 09-21-2018, 11:30   #5 (permalink)
Member: 1354113
Thanks Meter: 556
plz add frmware download tab
firmware download tab next up date for easy downloading
The Following 2 Users Say Thank You to kumar008 For This Useful Post:
Old 09-21-2018, 11:43   #6 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,253
Hello,
Support download area via IOS
Login here https://user.infinity-box.com/
RESET PASSWORD Here https://user.infinity-box.com/?do=passwordreset
The Following User Says Thank You to Kirumira For This Useful Post:
Old 09-21-2018, 11:54   #7 (permalink)
Member: 1354113
Thanks Meter: 556
Originally Posted by Kirumira View Post
Hello,
i ask download tab in flashtool such best version 1, don"t ask firmware site
Old 09-21-2018, 12:24   #8 (permalink)
.:Sanjh Phoenix:.'s Avatar
Member: 1728736
Sonork: 100.1615042
Thanks Meter: 1,079
"InfinityBox_install_BEST2_v1.05.7z "
Old 09-21-2018, 12:58   #9 (permalink)
Member: 61559
Thanks Meter: 7
please add firmware write ta-1006 sir
Old 09-21-2018, 13:15   #10 (permalink)
Member: 203747
Thanks Meter: 65
hi
good update how about nokia 105 TA-1034 flashing
Old 09-21-2018, 13:27   #11 (permalink)
Member: 770503
Thanks Meter: 989
> QLM SP line
What does it mean ?
Dear Coder please elaborate
Now which way connect this type of phone fastboot or old edl mode ?
Old 09-21-2018, 14:34   #12 (permalink)
srinibas's Avatar
Member: 492222
Sonork: 100.1594126
Thanks Meter: 10,271
> Firmware reading
> Firmware reading
> Reset FRP
> Identify
> Repair Security
> SP Unlock
- Changes/Fixes
> MTK SP line
Fixed SP unlock
> QLM SP line
- Other
- Support
Download link
Please put BEST download link U have put CM2 link
Br - srinibas
The Following 2 Users Say Thank You to srinibas For This Useful Post:
Old 09-21-2018, 15:04   #13 (permalink)
kojote's Avatar
Member: 33472
Thanks Meter: 15
change lang pack nok 3310 ta-1030
Operation : Write FirmWare [ v1.05 ]
Setting : UserData erase : True
PTFN : Nokia USB Serial Port (COM32)
PORT : 32
BROM : Init BROM
BROM init passed!
BROM : MEID : A5CD1FD27FF056DDEB2BB13C0BAC52AB
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : DA sent
NOR:
STYPE : 0x00000000
STATUS : OK
Boot done!
Load FlashSet :
MROM : TA-1030_ROM_eMP_11.02.11
LANG : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001
CUST : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001
JUMP : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001
VIVA : TA-1030_VIVA_eMP_11.02.11
Prepare FlashSet :
DCR : TA-1030_ROM_eMP_11.02.11
DCR : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001
DCR : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001
DCR : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001
DCR : TA-1030_VIVA_eMP_11.02.11
Prepare Target
SDS : OK : 0x00FF4000 : 0x0000C000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1030_ROM_eMP_11.02.11
Write : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001
Write : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001
Write : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001
Write : TA-1030_VIVA_eMP_11.02.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1030_ROM_eMP_11.02.11
Verify : TA-1030_LANG_PACK_ROM_ED_eMP_11.02.11_001
Verify : TA-1030_CUSTPACK_ROM_ED_EURO_HR_eMP_11.02.11_001
Verify : TA-1030_JUMP_TABLE_ED_EURO_HR_eMP_11.02.11_001
Verify : TA-1030_VIVA_eMP_11.02.11
Done!
Elapsed: 00:03:03
The Following 4 Users Say Thank You to kojote For This Useful Post:
Old 09-21-2018, 15:16   #14 (permalink)
Member: 704044
Thanks Meter: 172
WHERE TO DOWNLOAD LATEST NOKIA FILES IN BEST 2 ?
There is no navi manager
The Following User Says Thank You to sekarrajan For This Useful Post:
Old 09-21-2018, 16:01   #15 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,253
Already on support if you use IOS check my post #6
If you understand what is IOS you will not ask again & again for download Link check & use my post #6
Page generated in 0.21546 seconds with 8 queries
