09-28-2018, 08:05 | #50 (permalink) |
Freak Poster Join Date: Feb 2017 Location: Alipur
Member: 2683134 Status: Offline Thanks Meter: 59 | Please Add Full support for Ta-1030 and other new HMD phones. Nokia 3310 TA-1030 Read failed Infinity Best2 Nk 1.06 version. Phone is working 100%. i need this file but can't read.Please Fix this error. Here is log Operation : Read FirmWare [ v1.06 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM27) MODE : NOKIA USB SERIAL PORT : 27 BROM : Init BROM BROM init passed! CHIP : MT6260 , SBID : 0xCB00 , HWVR : 0x8000 , SWVR : 0x0000 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 91F447F28317AB2195745A5E4883F216 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : RETRO.11.02.11.p1 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : RETRO.11.02.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 CODE : 0x00CD0000 Reading Flash ... Error : Failed to read data! Unexpected end of data! Check cable, connection and drivers! Reconnect Power/Cable! |
09-28-2018, 08:27 | #52 (permalink) |
Member: 2683134 Status: Offline Thanks Meter: 59 | Just update your winrar programm https://www.win-rar.com/download.html?&L=0 |
09-28-2018, 17:00 | #55 (permalink) |
No Life Poster Join Date: May 2008
Member: 770503 Status: Offline Thanks Meter: 1,215 | Nokia 220 RM-969 Code: Infinity-Box BEST Nokia [HMD] Module [NK2] v1.06 Operation : Reset Settings [ v1.06 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM42) MODE : NOKIA USB SERIAL PORT : 42 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9CE25C6A257FCE61B8E0803A566D91C1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Rivendell.20.14.11.p1 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT625A AGENT : Rivendell.20.14.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x88 NOR: 00C2 : 0025 : 0038 : 0000 NOR: [MXIC] MX25U12835FZNI_10G NOR: TSIZE : 0x01000000 [ 16.00 MB ] PSIZE : 0x01000000 [ 16.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! FFS Info exists in MAUI : 0x00A60000 : 0x00594000 FFS Format ... FFS Format Ok! Done! Elapsed: 00:00:59 Reconnect Power/Cable! Operation : Identify [ v1.06 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM42) MODE : NOKIA USB SERIAL PORT : 42 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9CE25C6A257FCE61B8E0803A566D91C1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Rivendell.20.14.11.p1 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : Rivendell.20.14.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 BBSN : 9CE25C6A257FCE61B8E0803A566D91C1 PRDC : 059V1Z0 IMEI[1] : IMEI[2] : Done! Elapsed: 00:01:23 Reconnect Power/Cable! Operation : Read FirmWare [ v1.06 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Nokia USB Serial Port (COM42) MODE : NOKIA USB SERIAL PORT : 42 BROM : Init BROM BROM init passed! CHIP : MT625A , SBID : 0xCA01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 9CE25C6A257FCE61B8E0803A566D91C1 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : Rivendell.20.14.11.p1 BOOT : BDDS : 30 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : Rivendell.20.14.11.p1 FLASH : 00EF : 0060 : 0018 : 0000 CODE : 0x00A60000 Reading Flash ... TDSN : RM-969 PRDC : 059V1Z0 PPM : IC BUILD : RM-969 _ROM_eMP_20.14.11 BUILD : RM-969 _LANG_PACK_ROM_IC_eMP_20.14.11_001 BUILD : RM-969 _CUSTPACK_ROM_IC_eMP_20.14.11_001 BUILD : RM-969 _JUMP_TABLE_IC_eMP_20.14.11_001 BUILD : RM-969 _VIVA_eMP_20.14.11 Make VPL definition Save Path : C:\Users\mess\Desktop\RM-969 \ Save Name : RM-969 _059V1Z0_20.14.11.vpl Build Finished! Done! Elapsed: 00:23:31 Reconnect Power/Cable! |
09-28-2018, 19:19 | #56 (permalink) | ||
Insane Poster Join Date: Aug 2018
Member: 2855925 Status: Offline Thanks Meter: 62 | Quote:
Showing done but phone is still pin locked | ||
09-29-2018, 08:53 | #60 (permalink) |
Major Poster Join Date: Jul 2013
Member: 1973611 Status: Offline Thanks Meter: 5 | missing the tab imei. specifically not on the tab nokia qlm. on version 1.4 everything worked !!! uk off is in the manager all too included |
The Following User Says Thank You to Kubik696 For This Useful Post: |
