10-16-2018, 13:14 | #31 (permalink) | ||
No Life Poster Join Date: Apr 2009 Location: Inside Infinity
Member: 1010626 Status: Offline Sonork: using fb Thanks Meter: 735 | Quote:
U can download files from IOS for more info check here https://www.infinity-box.com/support/?s=4 | ||
The Following 3 Users Say Thank You to princesaddam For This Useful Post: |
10-17-2018, 07:26 | #33 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: gsmhosting Age: 29
Member: 1876736 Status: Offline Thanks Meter: 735 | Quote:
Code: tested on 10.02.11 and working peration : Read FirmWare [ v1.08 ] 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM503) MODE : NOKIA USB SERIAL PORT : 503 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : 45F69924A454EA22A9773FA786BDCDB4 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : N103.10.02.11.p1 BOOT : BDDS : 20 BOOT : PSRM : Init BOOT : PSRM : 0003 Boot done! SWVer : N103.10.02.11.p1 FLASH : 00C2 : 0025 : 0036 : 0000 CODE : 0x00370000 Reading Flash ... TDSN : TA-1034 PRDC : 059Z0Z0 PPM : IJ LANG : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) BUILD : TA-1034_ROM_eMP_10.02.11 BUILD : TA-1034_LANG_PACK_ROM_IJ_eMP_10.02.11_001 BUILD : TA-1034_CUSTPACK_ROM_IJ_eMP_10.02.11_001 BUILD : TA-1034_JUMP_TABLE_IJ_eMP_10.02.11_001 BUILD : TA-1034_VIVA_eMP_10.02.11 Make VPL definition Save Path : E:\111\best\best2\TA-1034\ Save Name : TA-1034_059Z0Z0_10.02.11.vpl Build Finished! | |
10-18-2018, 01:57 | #34 (permalink) | |
Major Poster Join Date: Jun 2016
Member: 2586632 Status: Offline Thanks Meter: 7 | Quote:
can someone help me re-upload this file... it faild to extract after downloading it... | |
10-18-2018, 04:08 | #36 (permalink) | |
Freak Poster Join Date: Nov 2008 Age: 37
Member: 906256 Status: Offline Thanks Meter: 40 | Quote:
i problem to download new nokia flash file from download support in InfinityBox BEST2. | |
10-19-2018, 06:25 | #39 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Need complete info about used OS, x64/86 type and installed AV software + Defender settings. | |
10-20-2018, 13:37 | #45 (permalink) |
Freak Poster Join Date: Sep 2010 Location: searching Age: 39
Member: 1404229 Status: Offline Sonork: 100.1612419 Thanks Meter: 44 | nokia 1060 Infinity-Box BEST Nokia [HMD] Module [NK2] v1.08 Operation : Reset Settings [ v1.08 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM312) MODE : BOOTROM PORT : 312 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 TYPE : LEGACY MTK BROM : DSLevel : DEV_KEY BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6735 AGENT : Nokia_All_InOne_DA_v02.2018.1809 Fail to disable Dog! BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! NAND : DEVICE NOT FOUND eMMC : OK eMMC : 150100464E36324D42032116D350D4FD DAInf: 4 : 2 : 155 eMMC : OK eMMC : 460001154D32364E16210342FDD450D3 DRAM : DRAM: 0x40000000 [ 1.00 GB ] DA : DRAM ready! DA : BOOT to 2nd DA ... DA : Receiving HW info EMMC: 150100464E36324D42032116D35045FD EMMC: VEN : SAMSUNG | OEM : 01 | DEV : FN62MB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00080000 [ 512.00 KB ] USER : 0x1D2000000 [ 7.28 GB ] SRAM: 0x00020000 [ 128.00 KB ] DRAM: 0x40000000 [ 1.00 GB ] CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 53BC56FBABC1BDA8BCEA800EF7D36F18 STATUS : BLANK FLASH BSTYLE : EMMC FLASH BOOT DA : USB : FULL-SPEED DA : USB : Change Port Speed PTFN : MediaTek DA USB VCOM (Android) (COM74) MODE : PRELOADER PORT PORT : 74 Boot done! Format Ok : USERDATA Format Ok : CACHE Format Ok : RESET PROTECTION Done! Elapsed: 00:00:32 Reconnect Power/Cable! |
The Following 2 Users Say Thank You to Bilal1984 For This Useful Post: |
