Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 11-20-2018, 18:23   #1 (permalink)
Member: 1043909
Thanks Meter: 60,926
Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features
- Forensic engine for MTK feature line devices rebuild from scratch
Allow extract phonebook memory from alive/dead/semi-dead devices
From now allow extract phonebook from memory dump ( made by external prommer or older BEST versions )
> Press and hold SHIFT key before press "Extract PhoneBook" button for enable File mode
Extraction is direct (from device) and from dump
Support unicode
All existing MTK FP models are supported now for PhoneBook extraction:
Nokia 108: RM-944, RM-945, RM-1124
Nokia 220: RM-969, RM-970, RM-971, RM-1125
Nokia 225: RM-1011, RM-1012, RM-1043
Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122
Nokia 215: RM-1110, RM-1111, RM-1112
Nokia 105: RM-1133, RM-1134, RM-1135
Nokia 222: RM-1136, RM-1137
Nokia 230: RM-1172, RM-1173
Nokia 216: RM-1187, RM-1188
Nokia 150: RM-1189, RM-1190
Nokia 3310(2G): TA-1008, TA-1030
Nokia 105(2017) : TA-1010, TA-1034, TA-1037
Nokia 130(2017) : TA-1017, TA-1019
- Changes/Fixes
> MTK FP line
Fix/Change: Flash engine revised
New feature: SW version check during flashing activated. SW will verify data between phone and VPL.
> In case of device dead ( no SW version data available ) - SW will warn about it.
New feature: Complete language info during FlashFile selection ( will show all existing languages without need of manual flashing and verify )
> MTK SP line
Fix/Change : Flash engine revised
Fix/Change : Repartition may fail during NK1 flashing, fixed
Download link
Subscribe to Telegram channel and get news faster !
How to upload files to support
Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News
Twitter - Facebook - Telegram
The Following 80 Users Say Thank You to YellowBoss For This Useful Post:
Old 11-20-2018, 20:24   #2 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,420
Good update,waiting Nokia SPD line activated.
Old 11-20-2018, 22:55   #3 (permalink)
Member: 2156783
Thanks Meter: 95
Add write backed up .bin firmware mtk
Old 11-21-2018, 05:03   #4 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Good update now add nokia 3310 3G please
Old 11-21-2018, 05:41   #5 (permalink)
Member: 738146
Thanks Meter: 18
TA-1017 dead in old version by flashing now same error in this version kindly fix it thanks
Open VPLfile : TA1017_059Z209_11.02.11.vpl
Description : TA-1017 NDT MEA IF BLACK LATIN BW
DeviceType : TA-1017
ProductCode : 059Z209
SoftwareVer : 11.02.11
PPM LangPack :
[1] : Portuguese (Portugal)
[2] : French (France)
[3] : Spanish (Castilian/Spain)
[4] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.09 ]
Setting : UserData erase : True
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Care Suite USB Serial Port (COM24)
MODE : NOKIA USB SERIAL
PORT : 24
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : B2BED2ABFC28B04F9EA1B35BAC04DD63
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : KESA61A.10.00.11.p2
BOOT : SWR : 10.00.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : KESA61A.10.00.11.p2
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00C2 : 0025 : 0037 : 0000
NOR: [MX] MX25U6435E
NOR:
TSIZE : 0x00800000 [ 8.00 MB ]
PSIZE : 0x00800000 [ 8.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 11.02.11 [TA-1017]
DEV SoftwareVersion : 10.00.11
SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL!
Load FlashSet :
MROM : TA-1017_ROM_eMP_11.02.11
LANG : TA-1017_LANG_PACK_ROM_IF_eMP_11.02.11_001
CUST : TA-1017_CUSTPACK_ROM_IF_MEA_BW_eMP_11.02.11_001
JUMP : TA-1017_JUMP_TABLE_IF_MEA_BW_eMP_11.02.11_001
VIVA : TA-1017_VIVA_eMP_11.02.11
Prepare FlashSet :
DCR : TA-1017_ROM_eMP_11.02.11
DCR : TA-1017_LANG_PACK_ROM_IF_eMP_11.02.11_001
DCR : TA-1017_CUSTPACK_ROM_IF_MEA_BW_eMP_11.02.11_001
DCR : TA-1017_JUMP_TABLE_IF_MEA_BW_eMP_11.02.11_001
DCR : TA-1017_VIVA_eMP_11.02.11
Prepare Target
SDS : OK : 0x007F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1017_ROM_eMP_11.02.11
Write : TA-1017_LANG_PACK_ROM_IF_eMP_11.02.11_001
Write : TA-1017_CUSTPACK_ROM_IF_MEA_BW_eMP_11.02.11_001
Write : TA-1017_JUMP_TABLE_IF_MEA_BW_eMP_11.02.11_001
Write : TA-1017_VIVA_eMP_11.02.11
Flash_Write ERROR : DA_CBR_NOT_FOUND
Error : Flashing failed!
Make sure device HW is in normal condition, check battery and cable!
Reconnect Power/Cable!
Old 11-21-2018, 20:41   #6 (permalink)
louka's Avatar
Member: 198016
Sonork: 100.1602918
Thanks Meter: 408
We always see in you the best and the more good work
Old 11-21-2018, 21:18   #7 (permalink)
mouhane's Avatar
Member: 2178934
Thanks Meter: 1,288
Any solution for CONTACT SERVICE .... thanks for great update
Old 11-21-2018, 21:30   #8 (permalink)
Member: 1810703
Sonork: epacific
Please help my beat nk2 don't detect Qualcomm phones .how do I install drivers.
Old 11-21-2018, 21:35   #9 (permalink)
Member: 1810703
Sonork: epacific
Driver
Please my infinity best nk2 is not detecting Qualcomm phones. How do I go about it. I have installed the driver from support and no solution.
Old 11-21-2018, 21:43   #10 (permalink)
Member: 1043909
What is your windows version ?
The Following User Says Thank You to YellowBoss For This Useful Post:
Old 11-21-2018, 21:43   #11 (permalink)
Member: 1043909
What is the history of this unit ?
Old 11-21-2018, 22:09   #12 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
15:00:11 version after flash
RM-1134 Contact service any solution please
I try with 13:00:11 and 10. But sam problem
Yellow boss please help link please
Sent from my SM-G615F using Tapatalk
Old 11-21-2018, 22:13   #13 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Old 11-21-2018, 22:15   #14 (permalink)
kundicom's Avatar
Member: 2650777
Sonork: 100.650600
Thanks Meter: 161
Old 11-21-2018, 23:24   #15 (permalink)
Member: 2552533
Thanks Meter: 93
Great works good team thnx
The Following User Says Thank You to blushi For This Useful Post:
Page generated in 0.21090 seconds with 8 queries
