11-23-2018, 06:00 | #46 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
NaviManager exists in BESTv1 line. QCN for Nokia QLM NOT need at all. | |
11-24-2018, 07:23 | #53 (permalink) |
Freak Poster Join Date: Jan 2018
Member: 2798902 Status: Offline Thanks Meter: 11 | 1. Hi, is there support here for the RM-975 model? 2. I have recently acquired the Infinity Box Dongle and I am new to the issue, if I want to add NOKIA repairs, should I only buy the "Activation BEST Dongle for Infinity Box/Dongle" license to activate this software? Explain a little to me what profound differences this Software has with NTool, if you are kind! 3. Confirm me something, I heard that they were in project and support of you for a more complete update as competition to the Ntool, is that true? Or is it the same Infinity BEST Reloaded in the future? Regards… |
11-25-2018, 08:27 | #54 (permalink) |
Freak Poster Join Date: Mar 2008
Member: 738146 Status: Offline Thanks Meter: 18 | Nokia Ta-1017 flashing error Open VPLfile : TA1017_059Z1Z3_11.02.11.vpl Description : TA-1017 NDT MEA IJ BLACK URDU PK DeviceType : TA-1017 ProductCode : 059Z1Z3 SoftwareVer : 11.02.11 PPM LangPack : [1] : Urdu (Islamic Republic of Pakistan) [2] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : False Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM16) MODE : NOKIA USB SERIAL PORT : 16 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B2BED2ABFC28B04F9EA1B35BAC04DD63 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.11.02.11.p1 BOOT : SWR : 11.02.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.11.02.11.p1 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 11.02.11 SWInfo compare result : SAME Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_IJ_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IJ_MEA_PK_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IJ_MEA_PK_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
11-25-2018, 08:41 | #55 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 130 Write Firmware Done :) Code: Connect phone on selected interface... Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DBEE8716DFF6CCA07500884A1B336456 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Configure RAMINIT Ok Reading flash now ... Done! Control Block Validation (Security Test) : CBR is Ok, match with BB SN. Phone Security is Alive :) Mobile Info IMEI : 353631062700120 BBUID : DBEE8716DFF6CCA07500884A1B336456 PCCode: 059W037 SimLock Info : STATE : OPENED ( NOT LOCKED ) RPL Saved to : 353631062700120_MTKx.mtsec Read Done! Connect phone on selected interface... Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1035_ROM_eMP_10.01.11 VIVA : RM-1035_VIVA_eMP_10.01.11 LANG : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 CUST : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 JMPT : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 37 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : DBEE8716DFF6CCA07500884A1B336456 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_ROM_eMP_10.01.11 SecureDecrypt : RM-1035_VIVA_eMP_10.01.11 SecureDecrypt : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_ROM_eMP_10.01.11 Write : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 Write : RM-1035_VIVA_eMP_10.01.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_ROM_eMP_10.01.11 [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IJ_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IJ_MEA_AF_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IJ_MEA_AF_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_VIVA_eMP_10.01.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:06 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds Wait, when phone will be ready ... Reading Phone Info.... Software Info: 10.01.11 00-00-00 RM-1035 IMEI: 353631062700120 Ape Version: NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM version : IJ Product code: 059W037 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
11-25-2018, 09:27 | #56 (permalink) | |
11-25-2018, 09:31 | #57 (permalink) | |
V1 and V2 lines exists. First one for legacy nokia and lumia 2. One time activation need. If you check supported models list and features you find all, what difference. 3. I have no idea about "competition" or whatever else. BEST were made by Infinity Team in year 2011. It supported by peoples, who made it from beginning. | |
11-26-2018, 00:53 | #60 (permalink) |
Member: 2798902 Status: Offline Thanks Meter: 11 | [CITA = JayDi; 13434969] 1. V1 y V2 líneas existe. Primero para Nokia Lumia legado y 2. necesidad de activación de un tiempo. Si marca la lista de los modelos soportados y las características que usted encontrará de todo, ¿qué diferencia. 3. No tengo ni idea acerca de la "competencia" o cualquier otra cosa. MEJOR fueron hechas por Infinity equipo en el año 2011. Es el apoyo de los pueblos, que lo hizo desde el principio. [/ Quote] Hi, thanks for answering, I asked if this model was supported by Infinity BEST because it is not in the list, skip the model number. But I imagine that if it supports it and you confirm it. OK, I'm on my way to activate the BEST on my Infinity Dongle then 👍. When I asked you about the differences, I was not referring to the versions exactly, but to the support for the new versions, including the latest ones. I ask why (X) staff of GSMserver recommended me more to subscribe to Ntool than to acquire this BEST license or any other line of Infinity with NOKIA, I know that you are the first (pioneers) in this Software so I miss that answer, the first thing that I thought that you had left behind the support for this tool and the future ones, in a few words I wanted a recommendation from you. The other question (simple curiosity), was that I was informed (but I do not know if it is true) is that the people of Infinity Dongle are in the process of enabling a tool that superior & better to Ntool competence and that they will integrate it into this Infinity Dongle line, I wanted to know if you knew any of this? Of course I imagine that they will incorporate it with the new future NOKIA models, NOT the old ones. Excuse my english & Thanks ok. Last edited by GabrielCh; 11-26-2018 at 01:01. |
