Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features Infinity-Box [BEST] NK2 v1.09 - FP Forensic and other features - Forensic engine for MTK feature line devices rebuild from scratch Allow extract phonebook memory from alive/dead/semi-dead devices From now allow extract phonebook from memory dump ( made by external prommer or older BEST versions ) > Press and hold SHIFT key before press "Extract PhoneBook" button for enable File mode Extraction is direct (from device) and from dump Support unicode All existing MTK FP models are supported now for PhoneBook extraction: Nokia 108: RM-944, RM-945, RM-1124 Nokia 220: RM-969, RM-970, RM-971, RM-1125 Nokia 225: RM-1011, RM-1012, RM-1043 Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122 Nokia 215: RM-1110, RM-1111, RM-1112 Nokia 105: RM-1133, RM-1134, RM-1135 Nokia 222: RM-1136, RM-1137 Nokia 230: RM-1172, RM-1173 Nokia 216: RM-1187, RM-1188 Nokia 150: RM-1189, RM-1190 Nokia 3310(2G): TA-1008, TA-1030 Nokia 105(2017) : TA-1010, TA-1034, TA-1037 Nokia 130(2017) : TA-1017, TA-1019 - Changes/Fixes > MTK FP line Fix/Change: Flash engine revised New feature: SW version check during flashing activated. SW will verify data between phone and VPL. > In case of device dead ( no SW version data available ) - SW will warn about it. New feature: Complete language info during FlashFile selection ( will show all existing languages without need of manual flashing and verify ) > MTK SP line Fix/Change : Flash engine revised Fix/Change : Repartition may fail during NK1 flashing, fixed Download link Subscribe to Telegram channel and get news faster ! How to upload files to support Infinity-Box 13 years (2005 - 2018) updates and support as nobody else - News Twitter - Facebook - Telegram |
Good update,waiting Nokia SPD line activated. |
Add write backed up .bin firmware mtk |
Good update now add nokia 3310 3G please |
TA-1017 dead in old version by flashing now same error in this version kindly fix it thanks Open VPLfile : TA1017_059Z209_11.02.11.vpl Description : TA-1017 NDT MEA IF BLACK LATIN BW DeviceType : TA-1017 ProductCode : 059Z209 SoftwareVer : 11.02.11 PPM LangPack : [1] : Portuguese (Portugal) [2] : French (France) [3] : Spanish (Castilian/Spain) [4] : English (United Kingdom) Load Ok! Operation : Write FirmWare [ v1.09 ] Setting : UserData erase : True Setting : LangPack Only : False 1. Make sure device is powered off. Power off, if need. Wait 10 seconds after 2. Insert USB cable in phone Waiting for device connection ... PTFN : Care Suite USB Serial Port (COM24) MODE : NOKIA USB SERIAL PORT : 24 BROM : Init BROM BROM init passed! CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001 BROM : SECCFG : 0x00000007 BROM : NOKIA USB SERIAL BROM : 0x05 BL : 0x00 BROM : MEID : B2BED2ABFC28B04F9EA1B35BAC04DD63 BROM : Run BootLoader ... BOOT : Run BL ver. 01 BOOT : 0x05 BL : 0x01 BOOT : WD : 0005 BOOT : RTC : Setup ... BOOT : RTC : 000E BOOT : PRJ : KESA61A.10.00.11.p2 BOOT : SWR : 10.00.11 AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6261 AGENT : KESA61A.10.00.11.p2 BOOT : Sending 1st DA ... BOOT : DA sent BOOT : Transfer control to DA ... DA : Agent : v03.02 on BBID : 0x8E NOR: 00C2 : 0025 : 0037 : 0000 NOR: [MX] MX25U6435E NOR: TSIZE : 0x00800000 [ 8.00 MB ] PSIZE : 0x00800000 [ 8.00 MB ] STYPE : 0x00000000 FLOTP : DA_NOR_OTP_EXIST STATUS : OK BSTYLE : SF_FLASH_BOOT Boot done! VPL SoftwareVersion : 11.02.11 [TA-1017] DEV SoftwareVersion : 10.00.11 SWInfo compare result : DEVICE SW ( Minor version ) is LOWER, than in VPL! Load FlashSet : MROM : TA-1017_ROM_eMP_11.02.11 LANG : TA-1017_LANG_PACK_ROM_IF_eMP_11.02.11_001 CUST : TA-1017_CUSTPACK_ROM_IF_MEA_BW_eMP_11.02.11_001 JUMP : TA-1017_JUMP_TABLE_IF_MEA_BW_eMP_11.02.11_001 VIVA : TA-1017_VIVA_eMP_11.02.11 Prepare FlashSet : DCR : TA-1017_ROM_eMP_11.02.11 DCR : TA-1017_LANG_PACK_ROM_IF_eMP_11.02.11_001 DCR : TA-1017_CUSTPACK_ROM_IF_MEA_BW_eMP_11.02.11_001 DCR : TA-1017_JUMP_TABLE_IF_MEA_BW_eMP_11.02.11_001 DCR : TA-1017_VIVA_eMP_11.02.11 Prepare Target SDS : OK : 0x007F8000 : 0x00008000 FFS Format Ok! Erase Target Flash Erase done! Write Target Flash Write : TA-1017_ROM_eMP_11.02.11 Write : TA-1017_LANG_PACK_ROM_IF_eMP_11.02.11_001 Write : TA-1017_CUSTPACK_ROM_IF_MEA_BW_eMP_11.02.11_001 Write : TA-1017_JUMP_TABLE_IF_MEA_BW_eMP_11.02.11_001 Write : TA-1017_VIVA_eMP_11.02.11 Flash_Write ERROR : DA_CBR_NOT_FOUND Error : Flashing failed! Make sure device HW is in normal condition, check battery and cable! Reconnect Power/Cable! |
We always see in you the best and the more good work |
Any solution for CONTACT SERVICE .... thanks for great update |
Please help my beat nk2 don't detect Qualcomm phones .how do I install drivers. |
Driver Please my infinity best nk2 is not detecting Qualcomm phones. How do I go about it. I have installed the driver from support and no solution. |
15:00:11 version after flash RM-1134 Contact service any solution please I try with 13:00:11 and 10. But sam problem Yellow boss please help link please Sent from my SM-G615F using Tapatalk |
Great works good team thnx |
