Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 11-27-2018, 14:05   #61 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 14,696
Originally Posted by syed tuqeer View Post
@JayDi
Hello,
Will be good , if you add Read info after Flash (MTK FP) .
like BEST V1
Thanks....
Hello.
I not see real reason for that at all.
PhoNet interface will be activated, probably, but almost no one use it at all.
Old 11-27-2018, 14:25   #62 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by zahidullah View Post
before flashing i took the backup but now i flash its own original backup it still give the same error phone was new pack i had to change language
Check Operation.log and look better, what SW version were in phone before.
Old 11-27-2018, 15:31   #63 (permalink)
Crazy Poster
Member: 1681695
Thanks Meter: 7
For this update is there any charges .??
Like cm2
Old 11-27-2018, 17:05   #64 (permalink)
JayDi's Avatar
Member: 462970
Like cm2
BEST dongle, as well as activation to any Infinity products, does not require any annual fees.
The Following User Says Thank You to JayDi For This Useful Post:
Old 11-28-2018, 00:17   #65 (permalink)
helpo's Avatar
Member: 2175357
Sonork: QQ:2157039171
Thanks Meter: 375
Originally Posted by GabrielCh View Post
[CITA = JayDi; 13434969] 1. V1 y V2 líneas existe. Primero para Nokia Lumia legado y
2. necesidad de activación de un tiempo.
Si marca la lista de los modelos soportados y las características que usted encontrará de todo, ¿qué diferencia.
3. No tengo ni idea acerca de la "competencia" o cualquier otra cosa.
MEJOR fueron hechas por Infinity equipo en el año 2011. Es el apoyo de los pueblos, que lo hizo desde el principio. [/ Quote]
Hi, thanks for answering, I asked if this model was supported by Infinity BEST because it is not in the list, skip the model number. But I imagine that if it supports it and you confirm it.
OK, I'm on my way to activate the BEST on my Infinity Dongle then . When I asked you about the differences, I was not referring to the versions exactly, but to the support for the new versions, including the latest ones. I ask why (X) staff of GSMserver recommended me more to subscribe to Ntool than to acquire this BEST license or any other line of Infinity with NOKIA, I know that you are the first (pioneers) in this Software so I miss that answer, the first thing that I thought that you had left behind the support for this tool and the future ones, in a few words I wanted a recommendation from you.
The other question (simple curiosity), was that I was informed (but I do not know if it is true) is that the people of Infinity Dongle are in the process of enabling a tool that superior & better to Ntool competence and that they will integrate it into this Infinity Dongle line, I wanted to know if you knew any of this? Of course I imagine that they will incorporate it with the new future NOKIA models, NOT the old ones.
Excuse my english & Thanks ok.
This is the right place to compare tools. I think best tool. Is easier and cheaper than ntool. And both developers are known infinity verses laser. Both respectively teams
Old 11-29-2018, 19:58   #66 (permalink)
KrzychuG's Avatar
Member: 25996
Thanks Meter: 133
Is it possible to extract SMS from MTK based Nokias like 225? I have phone that's alive and need to get text messages from it.
Old 11-30-2018, 10:33   #67 (permalink)
JayDi's Avatar
Member: 462970
Possible, will activate in next release ( ETA near week )
If need faster - make dump with 2.29 and send me in PM.
The Following 2 Users Say Thank You to JayDi For This Useful Post:
Old 12-01-2018, 16:46   #68 (permalink)
Member: 15156
Thanks Meter: 31
hi imei repair option in nokia qlm tab not showing any solution?
Old 12-03-2018, 03:40   #69 (permalink)
Member: 2138272
Sonork: 100.1650629
Thanks Meter: 32
from where download nokia flash files. please help.
Old 12-03-2018, 11:08   #70 (permalink)
JayDi's Avatar
Member: 462970
From support area. Login to your Infinity Online Services account.
Will be activated in nearest update.
Old 12-04-2018, 13:51   #71 (permalink)
helpo's Avatar
Member: 2175357
Thanks Meter: 375
add arabic for nokia 105 ta1034
Card found : 0A88777E , v0122
Infinity-Box BEST Nokia [HMD] Module [NK2] v1.09
Open VPLfile : TA-1034_059Z103_30.04.11.vpl
Description : TA-1034 IC
DeviceType : TA-1034
ProductCode : 059Z103
SoftwareVer : 30.04.11
PPM LangPack :
[1] : Arabic (Saudi Arabia)
[2] : Portuguese (Portugal)
[3] : French (France)
[4] : English (United Kingdom)
Load Ok!
Operation : Write FirmWare [ v1.09 ]
Setting : UserData erase : True
Setting : LangPack Only : False
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM69)
MODE : NOKIA USB SERIAL
PORT : 69
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000007
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : D9AFE760B802BD8BBE476F9F6AB4EA3E
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : N103.30.04.11.p1
BOOT : SWR : 30.04.11
AGENT : Look for suitable BootChain in DA ...
AGENT : DEFAULT AUTO
AGENT : Found MT6261
AGENT : N103.30.04.11.p1
BOOT : Sending 1st DA ...
BOOT : DA sent
BOOT : Transfer control to DA ...
DA : Agent : v03.02 on BBID : 0x8E
NOR: 00EF : 0070 : 0016 : 0000
NOR: [Winbond] SF_W25Q32JV
NOR:
TSIZE : 0x00400000 [ 4.00 MB ]
PSIZE : 0x00400000 [ 4.00 MB ]
STYPE : 0x00000000
FLOTP : DA_NOR_OTP_EXIST
STATUS : OK
BSTYLE : SF_FLASH_BOOT
Boot done!
VPL SoftwareVersion : 30.04.11 [TA-1034]
DEV SoftwareVersion : 30.04.11
SWInfo compare result : SAME
Load FlashSet :
MROM : TA-1034_ROM_eMP_30.04.11
LANG : TA-1034_LANG_PACK_ROM_IC_eMP_30.04.11_001
CUST : TA-1034_CUSTPACK_ROM_IC_eMP_30.04.11_001
JUMP : TA-1034_JUMP_TABLE_IC_eMP_30.04.11_001
VIVA : TA-1034_VIVA_eMP_30.04.11
Prepare FlashSet :
DCR : TA-1034_ROM_eMP_30.04.11
DCR : TA-1034_LANG_PACK_ROM_IC_eMP_30.04.11_001
DCR : TA-1034_CUSTPACK_ROM_IC_eMP_30.04.11_001
DCR : TA-1034_JUMP_TABLE_IC_eMP_30.04.11_001
DCR : TA-1034_VIVA_eMP_30.04.11
Prepare Target
SDS : OK : 0x003F8000 : 0x00008000
FFS Format Ok!
Erase Target Flash
Erase done!
Write Target Flash
Write : TA-1034_ROM_eMP_30.04.11
Write : TA-1034_LANG_PACK_ROM_IC_eMP_30.04.11_001
Write : TA-1034_CUSTPACK_ROM_IC_eMP_30.04.11_001
Write : TA-1034_JUMP_TABLE_IC_eMP_30.04.11_001
Write : TA-1034_VIVA_eMP_30.04.11
Write done, waiting target response ...
Write flash done!
Verify Target FlashContent
Verify : TA-1034_ROM_eMP_30.04.11
Verify : TA-1034_LANG_PACK_ROM_IC_eMP_30.04.11_001
Verify : TA-1034_CUSTPACK_ROM_IC_eMP_30.04.11_001
Verify : TA-1034_JUMP_TABLE_IC_eMP_30.04.11_001
Verify : TA-1034_VIVA_eMP_30.04.11
Done!
Elapsed: 00:01:03
The Following 4 Users Say Thank You to helpo For This Useful Post:
Old 12-19-2018, 12:48   #72 (permalink)
Member: 2503159
Thanks Meter: 7
TA 1032 FRP done. Cheers team
Operation : Reset Settings [ v1.09 ]
1. Make sure device is powered off. Power off, if need. Wait 20 seconds after
- > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage!
PTFN : MediaTek PreLoader USB VCOM (Android) (COM13)
MODE : PRELOADER PORT
PORT : 13
Waiting BOOT ack ...
PRELOADER : ACK confirmed!
BROM : Init BROM
BROM init passed!
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000
TYPE : LEGACY MTK
BROM : DSLevel : DEV_KEY+DEV_CRT
BROM : PRELOADER PORT
AGENT : Found MT6735
AGENT : Nokia_All_InOne_DA_v02.2018.1809
Fail to disable Dog!
BROM : Sending 1st DA ...
BROM : DA sent
BROM :Transfer control to DA ...
DA : AGENT started!
NAND : DEVICE NOT FOUND
eMMC : OK
eMMC : 13014E51324A39365210057720000081
DAInf: 4 : 2 : 155
DA : DRAM ready!
DA : BOOT to 2nd DA ...
DA : Receiving HW info
EMMC: 13014E51324A39365210057720004481
EMMC: VEN : MICRON | OEM : 4E01 | DEV : Q2J96R
EMMC:
BOOT1 : 0x00400000 [ 4.00 MB ]
BOOT2 : 0x00400000 [ 4.00 MB ]
RPMB : 0x00400000 [ 4.00 MB ]
USER : 0x3AB400000 [ 14.68 GB ]
SRAM: 0x00020000 [ 128.00 KB ]
DRAM: 0x80000000 [ 2.00 GB ]
CHIP : MT6735 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : E371C4F4CED4ACE64CEB0D316A7A005
STATUS : BLANK FLASH
BSTYLE : EMMC FLASH BOOT
DA : USB : HIGH-SPEED
Boot done!
Format Ok : USERDATA
Format Ok : CACHE
Format Ok : RESET PROTECTION
Done!
Elapsed: 00:00:40
Reconnect Power/Cable!
The Following 2 Users Say Thank You to krish9a25 For This Useful Post:
Old 12-22-2018, 15:05   #73 (permalink)
Fragga's Avatar
Member: 1507693
Thanks Meter: 109
Thumbs up NOKIA 3.1 FRP Done
PTFN : MediaTek USB Port (COM66)
MODE : BOOTROM
PORT : 66
BROM : Skip ACK verify
BROM : Init BROM
BROM init passed!
CHIP : MT6755 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0001
TYPE : MODERN RAPHAEL
BROM : BOOTROM
AGENT : Found MT6755
BROM : DA sent
DA : AGENT started!
DA : SYNC
DA : MODE : BROM
DA : EXT_RAM NOT initialized!
EMI : EXT_RAM CFG Passed!
DA : 2ND stage confirmed!
DA : SYNC with DA passed!
SRAM: 0x00040000 [ 256.00 KB ]
EMMC: 150100514536334D4203E2E696545501
EMMC: VEN : SAMSUNG | OEM : 01 | DEV : QE63MB
EMMC:
USER : 0x3A3E00000 [ 14.56 GB ]
CHIP : MT6750 , SBID : 0x8A00 , HWVR : 0xCB00 , SWVR : 0x0000 , EVOL : 0x0000
RNID : B38DA720FAB3949E7892C0DD62C37444
DA : USB : FULL-SPEED
DA : USB : Change Port Speed
PTFN : MediaTek DA USB VCOM (Android) (COM93)
PORT : 93
Boot done!
Format Ok : PRIVACY
Done!
Elapsed: 00:00:16
The Following 3 Users Say Thank You to Fragga For This Useful Post:
Old 12-31-2018, 10:38   #74 (permalink)
Member: 2496790
Thanks Meter: 5
nokia 3310 3G
hi what about flashing ta-1036 and flash files ? do you how a solution ?
Old 01-05-2019, 13:39   #75 (permalink)
Member: 2289628
Thanks Meter: 15
Nokia 1
I want to know that can I use below indicator firmware use on all Nokia 1 models ?
TA-1047
TA-1060
TA-1056
TA-1079
TA-1066
Page generated in 0.47575 seconds with 7 queries
