03-24-2019, 16:20 | #93 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
BTW on support you can find new version and new drivers package. That package ONLY useful, if you NOT service other SPRD device, since some or most SW can stop work with them with those drivers. | |
03-25-2019, 06:41 | #94 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version released - https://www.infinity-box.com/support/?r=100066 |
03-25-2019, 08:56 | #97 (permalink) | |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | Quote:
Code: "...SPRD flash backups can be sent for processing via IOS FileUploader for adding new LangPacks on support..." DebeliaMark, BG | |
The Following User Says Thank You to debeliamark For This Useful Post: |
06-04-2019, 21:33 | #102 (permalink) |
No Life Poster Join Date: Oct 2010 Location: Bangladesh Age: 43
Member: 1430165 Status: Offline Sonork: 100.1594449 Thanks Meter: 480 | Ta 1102 frp reset done Nokia TA1102 FRP Reset Done Code: Operation : Reset Settings [ v1.16 ] 1. Make sure device is powered off. Power off, if need. Wait 20 seconds after 2. Insert USB cable in phone - > Info : Press and hold BOTH volume keys, if device boot fail at BROM stage! Waiting for device connection ... PTFN : MediaTek USB Port (COM40) MODE : BOOTROM PORT : 40 Waiting BOOT ack ... BROM : Skip ACK verify BROM : Init BROM BROM init passed! CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 TYPE : MODERN RAPHAEL BROM : DSLevel : DEV_KEY+DEV_ARB BROM : BOOTROM AGENT : Look for suitable BootChain in DA ... AGENT : DEFAULT AUTO AGENT : Found MT6771 AGENT : Nokia DownloadAgent ver.07220419 BEST2 BROM : Sending 1st DA ... BROM : DA sent BROM :Transfer control to DA ... DA : AGENT started! DA : SYNC DA : MODE : BROM DA : EXT_RAM NOT initialized! EMI : EXT_RAM CFG Passed! DA : BOOT to 2nd DA ... DA : 2ND stage confirmed! DA : SYNC with DA passed! DA : Receiving HW info SRAM: 0x00040000 [ 256.00 KB ] DRAM: 0xC0000000 [ 3.00 GB ] EMMC: 150100474436424D4201E83E9A43951F EMMC: VEN : SAMSUNG | OEM : 01 | DEV : GD6BMB EMMC: BOOT1 : 0x00400000 [ 4.00 MB ] BOOT2 : 0x00400000 [ 4.00 MB ] RPMB : 0x00400000 [ 4.00 MB ] USER : 0x747C00000 [ 29.12 GB ] CHIP : MT6771 , SBID : 0x8A00 , HWVR : 0xCA00 , SWVR : 0x0000 , EVOL : 0x0000 RNID : 2071F1C1EF480664316E87E354940F1 DA : USB : HIGH-SPEED Boot done! Format Ok : USERDATA Format Ok : RESET PROTECTION Done! Elapsed: 00:00:19 Reconnect Power/Cable! |
The Following User Says Thank You to ..::SADHAN::.. For This Useful Post: |
05-22-2020, 07:40 | #105 (permalink) |
Junior Member Join Date: Nov 2007
Member: 630100 Status: Offline Thanks Meter: 0 | Will not run on my computer Hi. I tried a few versions on Windows 10 64, but no version works. I tried it on two computers, I see the splash screen and then nothing Any ideas? |
