03-25-2019, 12:07 | #35 (permalink) |
Junior Member Join Date: Sep 2009
Member: 1114326 Status: Offline Thanks Meter: 2 | Can anybody confirm success identify/reset code operation on Windows 7 32bit??? because i alvays haw this error: Operation : Identify [ v1.11 ] 1. Power off device, remove battery 2. Insert cable, press and hold BootKey ( # ) 3. Insert battery in device! Wait for device ... Device Connected! BootVersion : SPRD SECURE BOOT Block version ERROR : FDL Start Failed! Error : Loader send failed! Unsupported device! Reconnect Power/Cable! I try on v1.10 with old and new sprd drivers, also try on new 1.11 ver and new nokia sprd drivers from support and always error from log. |
03-25-2019, 12:29 | #37 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
If you have chance to test on CLEAN win - then you can try again. If there any problems exists - fail logs should be already on forum in more, than one or two. | |
03-25-2019, 12:40 | #38 (permalink) | |
Member: 1114326 Status: Offline Thanks Meter: 2 | Quote:
Yes, I know I should check on clean windows 7 but I did not have time to do it. That's why I decided to first ask here on the forum. Thank you for your response. | |
03-25-2019, 14:25 | #42 (permalink) |
Freak Poster Join Date: Apr 2013 Location: morocco
Member: 1914849 Status: Offline Thanks Meter: 40 | reset counter nck During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set ) please how to reset counter nck need help . |
03-25-2019, 14:33 | #43 (permalink) |
Member: 1914849 Status: Offline Thanks Meter: 40 | --- Insert USB cable now! --- Wait for phone... Phone found! [ 7 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6261 BB_CPU_HW : CB01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6261_S0001 BB_CPU_SN : 71AD35D6E11DAF9F2050F36E2082B3DD BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : KESA61A.10.00.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Dubai.fg DA_VERIFY : AA DA_JUMP : AAAAAAAA DA_AUTH : Fail! DA Run failed! Connect phone on selected interface... Connect phone on selected interface... not accepterd restore in best 2.29 |
03-25-2019, 15:02 | #44 (permalink) | ||
We talk about NK2 module ( BEST2 ) Install it, copy license and do what you need. | ||
