Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 03-25-2019, 07:32   #1 (permalink)
Member: 1043909
Thanks Meter: 52,078
Infinity-Box [BEST] NK2 v1.11 - More MTK and SPRD features activated
- Nokia SPRD tab
Activated Flash Dump feature
Support another signed base driver ( can be found on support for both x86 and x64 systems )
FlashEngine updated
- Nokia MTK SP tab changes
Flash Engine updated
MT6755 line has been broken in previous release, fixed
- Nokia MTK FP tab changes
PhoneBook extraction engine updated
Backup security feature released, allow store device security
Restore security feature released, allow restore device security backups
Backup now also made during "Identify"
During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set )
- Other
Minor bugfixes and changes
- Additional info
SPRD flash backups can be sent for processing via IOS FileUploader for adding new LangPacks on support.
ETA of processing - 48 hours, then files can be found on support. All other ways will be ignored.
NEW SPRD DRIVERS should be installed !
Download link
- How to upload files to support
Infinity-Box 14 years (2005 - 2019) updates and support as nobody else !
The Following 65 Users Say Thank You to YellowBoss For This Useful Post:
Old 03-25-2019, 07:49   #2 (permalink)
Member: 2145475
Thanks Meter: 42
Thanks Good Update ,,,,,,,,,,,,,,,,,
The Following User Says Thank You to azaanali For This Useful Post:
Old 03-25-2019, 07:58   #3 (permalink)
Ahsaan*'s Avatar
Member: 1726229
Sonork: 100.1615740
Thanks Meter: 197
Why i unable download flash file rm-1013 in 52 parts download limit 20 parts only downloaded ?????
Old 03-25-2019, 07:59   #4 (permalink)
Bond.Flasher's Avatar
Member: 2464063
Thanks Meter: 66
Good Update...Infinity-Box [BEST] always update
Old 03-25-2019, 08:05   #5 (permalink)
Member: 2123463
Sonork: 100.1652545
Thanks Meter: 22
Mention nokia spd based models plz
it will be really appreciated
The Following User Says Thank You to adduangel For This Useful Post:
Old 03-25-2019, 08:09   #6 (permalink)
Member: 2353177
Sonork: hamadali329
Thanks Meter: 7
good update good team ......
Old 03-25-2019, 08:23   #7 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 550
But Nokia 106 ta1114 SUPOORT ?
Please Add Data package Directory path
The Following User Says Thank You to rahihimkhan For This Useful Post:
Old 03-25-2019, 08:23   #8 (permalink)
Member: 2901958
Thanks Meter: 7
Mention the nokia spd models please.. thanks
Old 03-25-2019, 08:25   #9 (permalink)
duyphuong3000's Avatar
Member: 468656
Thanks Meter: 76
does Nokia SPRD can unlock by Best dongle sir?
Old 03-25-2019, 08:41   #10 (permalink)
Member: 649303
Thanks Meter: 28
good update plz add nokia ta-1114
Old 03-25-2019, 08:41   #11 (permalink)
Member: 2071984
Sonork: 100.1652043
Thanks Meter: 18
Infinity-Box [BEST] always fast update ....thanks
Old 03-25-2019, 08:43   #12 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 550
nokia ta1114 info done but Read firmware Option Not work in nokia mtk(FP) Tab
Operation : Identify [ v1.11 ]
1. Make sure device is powered off. Power off, if need. Wait 10 seconds after
2. Insert USB cable in phone
Waiting for device connection ...
PTFN : Nokia USB Serial Port (COM15)
MODE : NOKIA USB SERIAL
PORT : 15
BROM : Init BROM
BROM init passed!
CHIP : MT6261 , SBID : 0xCB01 , HWVR : 0x8000 , SWVR : 0x0001
BROM : SECCFG : 0x00000005
BROM : NOKIA USB SERIAL
BROM : 0x05 BL : 0x00
BROM : MEID : 134C54AB1563B819E7CF9E49A0DC3474
BROM : Run BootLoader ...
BOOT : Run BL ver. 01
BOOT : 0x05 BL : 0x01
BOOT : WD : 0005
BOOT : RTC : Setup ...
BOOT : RTC : 000E
BOOT : PRJ : NEMO61D.10.00.11.p2
BOOT : SWR : 10.00.11
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
SWVer : NEMO61D.10.00.11.p2
FLASH : 00C2 : 0025 : 0036 : 0000
PRDC : 059Z0X8
IMEI[1] : 354176103540993
IMEI[2] : 354176104540992
NCK : 20 digits
PROV : 24407000
Saved as : 35xxxxxxxxxxxxxxxxx.mtsec
Saved to : C:\InfinityBox\BEST2\Backup\
Old 03-25-2019, 08:53   #13 (permalink)
Sajjad_Hussain's Avatar
Member: 2601587
Thanks Meter: 169
Sir please update NaviBase for BEST2
The Following User Says Thank You to Sajjad_Hussain For This Useful Post:
Old 03-25-2019, 08:54   #14 (permalink)
>>Gsmmilon>>'s Avatar
Member: 2142580
Sonork: 100.1645446
Thanks Meter: 972
still not active nokia qlm
Old 03-25-2019, 09:13   #15 (permalink)
Member: 613449
Sonork: 100.1614074
Thanks Meter: 550
After may try Read firmware Option work
Operation : Read FirmWare [ v1.11 ]
PORT : 15
BROM : Init BROM
BROM init passed!
BOOT : WD : 0005
BOOT : RTC : 000E
BOOT : BDDS : 30
BOOT : PSRM : Init
BOOT : PSRM : 0003
Boot done!
CODE : 0x00370000
Reading Flash ...
TDSN : TA-1114
PRDC : 059Z0X8
PPM : IB
LANG :
[1] : Portuguese (Portugal)
[2] : French (France)
[3] : Spanish (Castilian/Spain)
[4] : English (United Kingdom)
BUILD : TA-1114_ROM_eMP_10.00.11
BUILD : TA-1114_LANG_PACK_ROM_IB_eMP_10.00.11_001
BUILD : TA-1114_CUSTPACK_ROM_IB_eMP_10.00.11_001
BUILD : TA-1114_JUMP_TABLE_IB_eMP_10.00.11_001
BUILD : TA-1114_VIVA_eMP_10.00.11
Make VPL definition
Save Path : F:\Infinity-Box\InfinityBox BEST\TA-1114\
Save Name : TA-1114_059Z0X8_10.00.11.vpl
Build Finished!
Done!
Elapsed: 00:02:27
Reconnect Power/Cable!
The Following 3 Users Say Thank You to rahihimkhan For This Useful Post:
Page generated in 0.39666 seconds with 7 queries
