Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 03-25-2019, 12:16   #31 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,935
Originally Posted by Rizwan ch08 View Post
Good update plz add Nokia 210 Ta 1139
If you have device on hands - PM me , we can try something.
Old 03-25-2019, 12:17   #32 (permalink)
JayDi's Avatar
Member: 462970
Originally Posted by duyphuong3000 View Post
does Nokia SPRD can unlock by Best dongle sir?
Unfortunately, only UserLocks now. SP lock is paired to device security and device key.
Old 03-25-2019, 12:38   #33 (permalink)
rahihimkhan's Avatar
Member: 613449
Sonork: 100.1614074
Thanks Meter: 550
Originally Posted by JayDi View Post
In settings you can setup data package path.
Auto data package path setting add in InfinityBox BEST2 like InfinityBox BEST
Auto File Add Whan Selete Rm Or Ta
The Following User Says Thank You to rahihimkhan For This Useful Post:
Old 03-25-2019, 12:48   #34 (permalink)
Member: 1043909
Thanks Meter: 52,096
Originally Posted by Ahsaan* View Post
Why i unable download flash file rm-1013 in 52 parts download limit 20 parts only downloaded ?????
Don't use download accelerator software and you will be able to download file well.
Old 03-25-2019, 13:07   #35 (permalink)
Member: 1114326
Thanks Meter: 2
Can anybody confirm success identify/reset code operation on Windows 7 32bit??? because i alvays haw this error:
Operation : Identify [ v1.11 ]
1. Power off device, remove battery
2. Insert cable, press and hold BootKey ( # )
3. Insert battery in device!
Wait for device ...
Device Connected!
BootVersion : SPRD SECURE BOOT Block version
ERROR : FDL Start Failed!
Error : Loader send failed!
Unsupported device!
Reconnect Power/Cable!
I try on v1.10 with old and new sprd drivers, also try on new 1.11 ver and new nokia sprd drivers from support and always error from log.
Old 03-25-2019, 13:10   #36 (permalink)
hassan riach's Avatar
Member: 366329
Sonork: Essaouira
Thanks Meter: 1,156
Good Update...Infinity-Box
Old 03-25-2019, 13:29   #37 (permalink)
JayDi's Avatar
Member: 462970
Wait for device ...
Device Connected!
Unsupported device!
That may happen also, if you have some other SW installed on your Win7 x86, which may lead to errors due connection or security problems.
If you have chance to test on CLEAN win - then you can try again.
If there any problems exists - fail logs should be already on forum in more, than one or two.
Old 03-25-2019, 13:40   #38 (permalink)
Member: 1114326
Thanks Meter: 2
Yes, I know I should check on clean windows 7 but I did not have time to do it. That's why I decided to first ask here on the forum. Thank you for your response.
Old 03-25-2019, 14:18   #39 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 11,378
Thanks for this other Big Update
Old 03-25-2019, 14:31   #40 (permalink)
babarmughal's Avatar
Member: 2609063
Thanks Meter: 53
Dear JayDi... QLM option still hide... can you fix it please ?
Old 03-25-2019, 14:56   #41 (permalink)
JayDi's Avatar
Member: 462970
We activate QLM tab with 8810 support, in next versions it will follow.
The Following 6 Users Say Thank You to JayDi For This Useful Post:
Old 03-25-2019, 15:25   #42 (permalink)
Crazy Poster
Member: 1914849
Thanks Meter: 12
reset counter nck
During backup security RPL will be cleaned and prepared ( all counters reset and default mtk settings/options set )
please how to reset counter nck need help
Old 03-25-2019, 15:33   #43 (permalink)
Crazy Poster
Member: 1914849
Thanks Meter: 12
--- Insert USB cable now! ---
Wait for phone...
Phone found! [ 7 ]
Sync...
Sync Ok, read regs...
Inital regs read done
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BB_CPU_NM : [MediaTek] MT6261_S0001
BB_CPU_SN : 71AD35D6E11DAF9F2050F36E2082B3DD
BROM Protocol Version : 05
BROM Status : 0000
Comm Status : 0000
EXBL Status : Alive [ USB Load Active ]
Switch to BL done
BL Version : 01
Setting...
Setting done , result code 0x8000
Project ID : KESA61A.10.00.11.p2
BROM/BL stage done
Seek and prepare DownloadAgent
DownloadAgent matching HW Found!
DA verify and select done
Sending DA to target ...
DA_eMP_Dubai.fg
DA_VERIFY : AA
DA_JUMP : AAAAAAAA
DA_AUTH : Fail!
DA Run failed!
Connect phone on selected interface...
not accepterd restore in best 2.29
Old 03-25-2019, 16:02   #44 (permalink)
JayDi's Avatar
Member: 462970
Wait for phone...
Phone found! [ 7 ]
Sync...
Boot Info :
BB_CPU_ID : 6261
BB_CPU_HW : CB01
BB_CPU_SW : 0001
BB_CPU_SB : 8000
BROM Status : 0000
Comm Status : 0000
Switch to BL done
BL Version : 01
Setting...
BROM/BL stage done
DA_eMP_Dubai.fg
DA_VERIFY : AA
DA_JUMP   : AAAAAAAA
DA_AUTH   : Fail!
DA Run failed!
What if you read again from beginning.
We talk about NK2 module ( BEST2 )
Install it, copy license and do what you need.
Old 03-25-2019, 16:38   #45 (permalink)
Member: 2552533
Thanks Meter: 64
thnx for new update keep it up team
Page generated in 0.39950 seconds with 7 queries
