Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-25-2019, 15:45   #16 (permalink)
Member: 1043909
Thanks Meter: 52,047
Originally Posted by akeel2000 View Post
all qualcum option hide any help
What operation do you want to do exactly ?
Old 07-25-2019, 16:02   #17 (permalink)
Member: 2627757
Thanks Meter: 6
InfinityBox BEST2 setup not work
please help InfinityBox BEST2 setup not work
InfinityBox BEST setup is working
Old 07-25-2019, 16:24   #18 (permalink)
Crazy Poster
Member: 2382101
Thanks Meter: 156
NOKIA 5 TA-1053 FLASH WITH BEST2 NK2
Operation : Flash Firmware [FTM] [ v1.18 ]
Setting : UserData preserve : True
Setting : FRP Reset : False
Setting : Keep SVC : True
-> Old : Power Off Phone, wait 5-10 seconds, Insert USB cable
-> New : Power Off Phone, press and hold VOL_DOWN and POWER keys, until FASTBOOT screen appear
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Dev Model : D1A
HW version : 5.0
HW variant : FIH eMMC
HW RF_BAND : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38 _40
SW version : ND1-3320-0-00WW-A02
SW serialnm : D1AGAD1761901839
SW secured : YES
Bootloader type : SERVICE
Security Version : 0001
OP : Flash
OEM : oem dm-verity
Device : D1A ( ND1 )
BLType : SERVICE
SecVer : 01
Flash : partition : D1C-0-3320-gpt_both0.bin
Skip : aboot : D1C-0-3320-emmc_appsboot_service.zip
Skip : abootbak : D1C-0-3320-emmc_appsboot_service.zip
Flash : rpm : D1C-0-3320-rpm.mbn
Flash : rpmbak : D1C-0-3320-rpm.mbn
Flash : sbl1 : D1C-0-3320-sbl1.mbn
Flash : sbl1bak : D1C-0-3320-sbl1.mbn
Flash : tz : D1C-0-3320-tz.mbn
Flash : tzbak : D1C-0-3320-tz.mbn
Flash : hwcfg : D1C-0-3320-hwcfg.img
Flash : dsp : D1C-0-3320-adspso.bin
Flash : cmnlib : D1C-0-3320-cmnlib.mbn
Flash : cmnlibbak : D1C-0-3320-cmnlib.mbn
Flash : cmnlib64 : D1C-0-3320-cmnlib64.mbn
Flash : cmnlib64bak : D1C-0-3320-cmnlib64.mbn
Flash : devcfg : D1C-0-3320-devcfg.mbn
Flash : devcfgbak : D1C-0-3320-devcfg.mbn
Flash : keymaster : D1C-0-3320-keymaster.mbn
Flash : keymasterbak : D1C-0-3320-keymaster.mbn
Device reboot required!
OEM : oem dm-verity
BLType : SERVICE
SecVer : 01
Flash : splash : D1C-00WW-025-splash.img
Flash : ftmboot : D1C-0-3320-ftm.img
Flash : multi_splash : D1C-00WW-025-multi-splash.img
Flash : boot : ND1-0-3320-00WW-boot.img
Flash : system : ND1-0-3320-00WW-system.img
SPImage : Process system_0
SPImage : Process system_1
SPImage : Process system_2
SPImage : Process system_3
SPImage : Process system_4
SPImage : Process system_5
SPImage : Process system_6
SPImage : Process system_7
Flash : recovery : ND1-0-3320-00WW-recovery.img
Flash : persist : D1C-0-3320-0001-persist.img
SPImage : Process persist_0
Erase : cache
Flash : sutinfo : D1C-00WW-001-sutinfo.img
Flash : modem : D1C-0-3320-NON-HLOS.bin
Flash : hidden : D1C-0-0020-0001-hidden.img.ext4
Flash : cda : D1C-00WW-025-cda.img
Flash : systeminfo : fver
Flash : ftmlog : D1C-0-0020-0001-userdata-ftm.img.ext4
SPImage : Process ftmlog_0
Flash : default_nv : D1C-0-3320-NV-default.mbn
Flash : sec : D1C-0-3320-sec.dat
Flash : mdtp : D1C-0-3320-00WW-mdtp.img
Flash : aboot : D1C-0-3320-emmc_appsboot.mbn
Flash : abootbak : D1C-0-3320-emmc_appsboot.mbn
Flash : md5 : md5.dat
OP : Keep SVC
Flash : aboot : D1C-0-3320-emmc_appsboot_service.zip
Flash : abootbak : D1C-0-3320-emmc_appsboot_service.zip
Done!
Elapsed: 00:08:00
The Following User Says Thank You to omid.m For This Useful Post:
Old 07-25-2019, 16:39   #19 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,352
Hello
do you see any error if you open Best2 ?
More details please
Old 07-25-2019, 16:47   #20 (permalink)
Member: 2828575
His problems are the same
Old 07-25-2019, 19:00   #21 (permalink)
Kirumira's Avatar
Member: 96478
Sonork: 100.1674604
Thanks Meter: 1,352
What same problem sir? I Need more details about that problem
can you post details?
Old 07-25-2019, 19:16   #22 (permalink)
Member: 2812901
Thanks Meter: 405
Nokia Base (BL) ?
Can someone explain the meaning of (BL).
Old 07-25-2019, 19:20   #23 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,893
BootLoader - FastBoot.
The Following User Says Thank You to JayDi For This Useful Post:
Old 07-25-2019, 21:11   #24 (permalink)
Member: 2812901
Thanks Meter: 405
THANKS SIR !!! I have already read the software well and understand it.
But is that any other way to save username and password on INFINITY-BEST IOS without continue repeat it in every operation.
Because in CM2 once we put IOS username and password it already save on setting
WHAT ABOUT BEST ?
ONCE AGAIN, A VERY BIG THANKS FOR GOOD JOB YOU ARE DOING IN GSM INDUSTRY.
Old 07-25-2019, 21:27   #25 (permalink)
hitech care's Avatar
Member: 1834832
Thanks Meter: 1,257
Load : C:\Users\Programmer\Desktop\ND1-3320-0-00WW-A02.nb0
Project : ND1
Model : TA-1003
SW_ver : ND1-3320-0-00WW-A0
DSP_ID : 00WW_3_320
Platform : Q8
SecVer : 0x0001
Load Ok!
Setting : UserData preserve : False
Setting : FRP Reset : True
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Dev Model : D1A
HW version : 5.0
SW version : ND1-332E-0-00WW-B01
SW serialnm : D1AGAD2771200743
SW secured : YES
Bootloader type : RETAIL
Security Version : 0000
OP : Activate SVC
Device : D1A ( )
BLType : RETAIL
SecVer : 00
Info : Device is not supported yet!
Send log and report.log to support! Include device info also!
Reconnect Power/Cable!
Old 07-25-2019, 22:31   #26 (permalink)
JayDi's Avatar
Member: 462970
Project  : ND1
Model    : TA-1003
DSP_ID   : 00WW_3_320
Platform : Q8
SecVer   : 0x0001
Load Ok!
Wait for phone...
Connect Ok!
Device Found!
Initialize ...
Initialize Ok!
Dev Model   : D1A
HW version  : 5.0
HW RF_BAND  : G_850_900_1800_1900^W_1_2_5_8^L_1_3_5_7_8_20_28_38_40
SW secured  : YES
OP : Activate SVC
Device : D1A (  )
BLType : RETAIL
SecVer : 00
Need make correct bootloader repair. And use new version. Qcom repair also follow.
Old 07-26-2019, 00:55   #27 (permalink)
Member: 748456
Thanks Meter: 28
where the firmware for ta-1021 can be downloaded? I tried to access support, but all servers were down today in the evening. Temprorary or forever?
Old 07-26-2019, 01:32   #28 (permalink)
Member: 2812901
Thanks Meter: 405
Copy license from best to best2 .
Old 07-26-2019, 06:35   #29 (permalink)
ahmer5050's Avatar
Member: 2385819
Sonork: No More Used
Thanks Meter: 550
Very Good Update Infinity Team.
Old 07-26-2019, 07:06   #30 (permalink)
.::intel32::.'s Avatar
Member: 350719
Sonork: 100.1623850
Thanks Meter: 142
nokia QLM (ed) not activated please help me
The Following User Says Thank You to .::intel32::. For This Useful Post:
Page generated in 0.38996 seconds with 8 queries
