05-16-2014, 12:53 | #31 (permalink) | |
No Life Poster Join Date: May 2005 Location: Vietnam Age: 50
Member: 149256 Status: Offline Thanks Meter: 285 | Quote:
05-16-2014, 13:15 | #33 (permalink) |
No Life Poster Join Date: Jan 2014 Location: Pakistan Age: 26
Member: 2105681 Status: Offline Sonork: Stoped Using... Thanks Meter: 909 | infinity box best v1.89 released support mtk 6260 support world first infinity box best v1.89 released support mtk 6260 support world first download link http://www.infinity-best.com/downloa...BEST_v1.89.rar |
05-16-2014, 14:10 | #36 (permalink) | |
No Life Poster Join Date: Feb 2007 Location: COOLSAND CPU
Member: 452162 Status: Offline Sonork: 100.1592470 Thanks Meter: 440 | Quote:
Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or boot from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 126 ] Sync... Initial Boot Failed (Sync Error) Connect phone on selected interface... Connect phone on selected interface... | |
05-16-2014, 14:18 | #37 (permalink) | ||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
Nokia 108 - ONLY Nokia 108 donor can be used. Nokia 220 - ONLY Nokia 220 donor can be used. Other CPU can be flashed and will work. But only "Contact Service" in result. Quote:
For such cases need try : Disconnect other boxes , if they connected Reinsert battery. Press need operation. Connect phone. | ||
The Following User Says Thank You to Dzirt For This Useful Post: |
05-16-2014, 15:15 | #38 (permalink) | |
No boxes connected except my internet USB dongle. | |
05-17-2014, 05:20 | #43 (permalink) | |
Freak Poster Join Date: May 2012 Location: india \westbengal / katwa Age: 37
Member: 1762926 Status: Offline Sonork: 1619564 Thanks Meter: 83 | card found: S/N Quote:
Connect phone on selected interface... Core : v1.89 , BB5XG FlashEngine : v9.9 Selected FlashSettings : Manual Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm694__12.04.mcusw PPM : rm694__12.04.ppm_mh CNT : rm694__12.04.image_mh_059D187_059N3X8_278_02 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.46_M1S1 Speed accepted, use 6.500.000 FLASHID : EC001230 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355491055462701 IMEI 2 : 355491055462719 PCcode : 059N1T6 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355491055462701_XG 213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm694__12.04.mcusw Image : rm694__12.04.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:02 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x01980000 Erasing, wait ... Erase done, time : 00:00:50 Write , Start : 0x40280000 , Len : 0x01900000 Flashing , wait ... Region flash done, time : 00:00:38 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip CRC check passed , 0x7B07 ===Flashing [PPM]=== File : rm694__12.04.ppm_mh Image : package_mh.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41C00000 , Len : 0x00700000 Erasing, wait ... Erase done, time : 00:00:12 Write , Start : 0x41C00000 , Len : 0x005D9644 Flashing , wait ... Region flash done, time : 00:00:07 CRC check passed , 0x50D2 ===Flashing [CNT]=== File : rm694__12.04.image_mh_059D187_059N3X8_278_02 Image : rm694__12.04.image_mh_059D187_059N3X8_278_02.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42300000 , Len : 0x01B20000 Erasing, wait ... Erase done, time : 00:00:49 Write , Start : 0x42300000 , Len : 0x00F80000 Flashing , wait ... Region flash done, time : 00:00:21 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 Erasing, wait ... Erase done, time : 00:00:02 No write data, skip CRC check passed , 0x524B Flashing done! Total flash time : 00:03:06 Reboot phone now... Reading Phone Info.... Connected phone - X2-02 Software Info: V 12.04 20-05-13 RM-694 (c) Nokia IMEI: 355491055462701 PPM version : V 12.04 20-05-13 RM-694 (c) Nokia MH Product code: 059N1T6 Wait, when phone will be ready ... Checking... SimLock status : SimLock is Ok Security status : Security is Ok Read Info Done! Check and Upload User Certificates ... Total - 58 certs Certificates found, skip upload ... Battery voltage is enough for start AfterFlash operations done ;D Done! Connect phone on selected interface... Elapsed: 00:03:56 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Phone disconected! Connect phone on selected interface... | |
