09-21-2014, 15:15 | #17 (permalink) | |||
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Quote:
I see you found way Any phone WPx - enough insert RM by hands ( just type in RM textbox ) and if fw installed - it will appear in flash tab Quote:
Just use BEST for flashing MTK Nokia phones and you will never face any problem. Install usb drivers for your dongle. | |||
09-22-2014, 07:39 | #20 (permalink) |
Product Supporter Join Date: May 2010 Location: alwar, rajasthan (india)
Member: 1306196 Status: Offline Sonork: 100.1654602 Thanks Meter: 1,578 | I already install usb driver but same probleme. Before format dongle is working fine and after format dongle is not connected. Please help thanks in advance only driver problem |
09-23-2014, 18:48 | #22 (permalink) |
No Life Poster Join Date: May 2006 Location: Marrakech
Member: 282206 Status: Offline Thanks Meter: 102 | hello problem with this update in mtk first phone Core : v1.97 , MTKx FlashEngine : v5.0 Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 103 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 8D636CA39D1A42316F78BCD0875BC0CC BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.10.04.11.p2 === Backup Enabled Reading RPL backup... === Backup [ERROR] : DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 [ERROR] : Error While erase area!!! Flashing failed! Connect phone on selected interface... second phone Core : v1.97 , MTKx FlashEngine : v5.0 Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 103 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E8499514AE49D6B73FCE38D626412197 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 === Backup Enabled Reading RPL backup... === Backup [ERROR] : DA : FORMAT_BIN Processing Flash Pre-format with ver 1.95 all ok Connect phone on selected interface... Core : v1.95 , MTKx FlashEngine : v4.8 Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 103 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : E8499514AE49D6B73FCE38D626412197 BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.20.06.11.p4 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.20.06.11.p4 === Backup Enabled Reading RPL backup... IMEI : 355170060049402 RPL [Security] Saved to : 355170060049402.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:01 Reboot phone Ok Connect phone on selected interface... Core : v1.95 , MTKx FlashEngine : v4.8 Verify files ... MAUI : RM-944_ROM_eMP_12.06.11 VIVA : RM-944_VIVA_eMP_12.06.11 LANG : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 CUST : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 JMPT : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 103 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 625A BB_CPU_HW : CA01 BB_CPU_SW : 0001 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6250_S0001 BB_CPU_SN : 8D636CA39D1A42316F78BCD0875BC0CC BROM Protocol Version : 05 BROM Status : 1012 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x000E Project ID : Bree.10.04.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Bree.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x88 DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 SecureDecrypt : RM-944_ROM_eMP_12.06.11 SecureDecrypt : RM-944_VIVA_eMP_12.06.11 SecureDecrypt : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 SecureDecrypt : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 SecureDecrypt : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 OVRLP : 000069B900000001 PHPID : Bree.10.04.11.p2 === Backup Enabled Reading RPL backup... IMEI : 357270054214364 RPL [Security] Saved to : 357270054214364.mtsec === Backup OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok ERASE_MAUI_INFO : 0x0001B000 WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-944_ROM_eMP_12.06.11 Write : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 Write : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 Write : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 Write : RM-944_VIVA_eMP_12.06.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-944_ROM_eMP_12.06.11 [VERIFY] DONE : RM-944_LANG_PACK_ROM_IC_eMP_12.06.11 [VERIFY] DONE : RM-944_CUSTPACK_ROM_IC_MEA_MA_eMP_12.06.11 [VERIFY] DONE : RM-944_JUMP_TABLE_IC_MEA_MA_eMP_12.06.11 [VERIFY] DONE : RM-944_VIVA_eMP_12.06.11 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A6000-0x003F3FFF , LEN : 0x0004E000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:01:03 Reboot phone Ok |
09-24-2014, 03:04 | #23 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | abderrahmane bi , read : http://forum.gsmhosting.com/vbb/10566974-post10.html |
