02-19-2016, 07:17 | #46 (permalink) | |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Quote:
Try this as last hope- http://forum.gsmhosting.com/vbb/11620027-post17.html If still fails time to upgrade to at least windows 7. Br. Infinity Box Support Team. | |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
02-19-2016, 20:22 | #47 (permalink) |
Junior Member Join Date: Dec 2008
Member: 932353 Status: Offline Thanks Meter: 1 | [Fixed] navi error Hello Team. Tank you very much. Mi problem was fixed with this ".ini" file. Now, the log not says "...Create SC", it says "...Create USC"; and Download great. Here is a log's part of the firmware downloading: Code: SSChannel : Create USC SSChannel : USC Created! Selected Variant : RM-947 VAR LATAM-A1 AR CV SKD 4GB Firmware Version : 14.0.6 SSChannel : DC Ok with code 0x04 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-947 exist Prepare done, collect info ... |
The Following User Says Thank You to guillermo05 For This Useful Post: |
02-20-2016, 16:22 | #48 (permalink) |
Major Poster Join Date: Jan 2014 Location: kolkata
Member: 2097132 Status: Offline Thanks Meter: 6 | How to unlock Lumia 625 Rm-974 Check SimLock info Conf key : 8000000000000000 Provider key : 2343300190233141 Country : United Kingdom Operator : Orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 2 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close ============================= LOCKS : Closed ============================= Done! Clearing SimLock code data... Something goes wrong :| |
02-23-2016, 06:08 | #50 (permalink) |
Major Poster Join Date: Nov 2014 Location: lubuk linggau,palembang
Member: 2296111 Status: Offline Sonork: [email protected] Thanks Meter: 1 | gad lockkkkkkkkkkkkkkkkkkkkkkk |
02-28-2016, 12:14 | #51 (permalink) | ||
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
03-13-2016, 12:10 | #54 (permalink) | |
http://forum.gsmhosting.com/vbb/11620027-post17.html | |
03-14-2016, 14:32 | #57 (permalink) |
Freak Poster Join Date: Jul 2014 Location: Pakistan
Member: 2228960 Status: Offline Thanks Meter: 91 | LUMIA 920 FLASHING DONE infinity best dongle Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 1.18 Protocol Implementation : 2.2 === Phone Initial info : Phone RMxxx ID : RM-821 Phone Model ID : Nokia.MSM8960.P4301.3.2.1 Phone Model PC : 059R0J5 Phone IMEI : 354149053034488 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 29820 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 00E9427DF118D9E27D098D13BECB6C6C89CE59F4 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 66% Battery Level enough to flash FFU : RM821_3051.50009.1424.0002_RETAIL_im_mea1_317_02_4 40286_prd_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Image Sent, processing PostFlash Make Factory Set : Ok Restore RAMBkp : Ok PostFlash Finished Total flash time : 00:02:53 Rebooting Connect phone on selected interface... AON MOBILES |
03-18-2016, 21:31 | #58 (permalink) |
No Life Poster Join Date: May 2013 Location: worldwide
Member: 1948841 Status: Offline Sonork: yocomic Thanks Meter: 45 | lumia 635 dont ask for unlock code === Main info === SecLabel Version : Security LabelSW (wim) 14.1061.342.42 Sw Version : RM975 1061.0074.9651.12400 604673 2014/08/07 //romulus_engine/PRx_engine_integration\r\n IMEI : 353047065369799 ProductCode : 059V714 ProductSN : CMQ532798 Module Code : 0205734 === HW info === Public ID : 8EF0E032A5DA22F3962496C328BA46EA66ECE3CC BT Addr. : 4886E8E87EF8 Wlan Mac : 4886E8E9A24C === Branding and security info === Sec. Mode : Restricted Conf key : 8000000000000000 Provider key : 3101700000000000 Country : United States of America Operator : AT&T Counters : Key 0 [3] , Fbus 0 [10] Blocks : 6 LOCK STATUS : ============================= BLK : 1 Lock1:Close BLK : 2 Lock1:Close BLK : 3 Lock1:Close BLK : 4 Lock1:Close BLK : 5 Lock1:Close BLK : 6 Lock1:Close ============================= LOCKS : Closed ============================= Making RPL backup... NPC : Read Ok , [520] IMEI : 353047065369799 CCC : Read Ok , [352] HWC : Read Ok , [212] RDC : Certificate not available NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\353047065369799_CR T_2nd.rpl Done! Clearing SimLock code data... Something goes wrong :| |
03-23-2016, 12:27 | #60 (permalink) |
Banned Join Date: Mar 2016
Member: 2549314 Status: Offline Sonork: 100.1645446 Thanks Meter: 1 | please give Nokia Lumin 520 RM-914 Flash File Im Chak Torrent But No ADD This Model I Try My Best Show This LOG Connect phone on selected interface... SSChannel : Create SC SSChannel : SC Created! Selected Variant : RM-914 VAR EU IT VODAFONE Firmware Version : 3058.50000.1425.0013 SSChannel : DC Failed! Last edited by >>Gsmmilon>>2; 03-23-2016 at 12:32. |
