03-26-2016, 05:41 | #63 (permalink) |
Freak Poster Join Date: Jan 2011 Location: Pakistan .Peshawar
Member: 1501291 Status: Offline Sonork: 100.1622368 Thanks Meter: 24 | flashing problem in nokia 130 i flash a nokia 130 for launage at first it work when i flash then it become blanking and now i flash whith different version but still blanking help me what to do --- Insert USB cable now! --- Wait for phone... Phone found! [ 18 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : 0C648D427FBF3CFB4AF906D988D9CAD4 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : CRYSTAL.10.01.11.p2 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Crystal.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00E2 , [WINBOND] W25Q32BV [0] : FLASH_DIE : 00EF 0040 0016 0000 [0] : FLASH_LEN : 0x00400000 FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 SecureDecrypt : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001 SecureDecrypt : RM-1035_CUSTPACK_ROM_IC_MEA_MA_eMP_10.01.11_001 SecureDecrypt : RM-1035_JUMP_TABLE_IC_MEA_MA_eMP_10.01.11_001 OVRLP : 000069B900000001 PHPID : CRYSTAL.10.01.11.p2 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 3 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001 Write : RM-1035_CUSTPACK_ROM_IC_MEA_MA_eMP_10.01.11_001 Write : RM-1035_JUMP_TABLE_IC_MEA_MA_eMP_10.01.11_001 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1035_LANG_PACK_ROM_IC_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_CUSTPACK_ROM_IC_MEA_MA_eMP_10.01.11_001 [VERIFY] DONE : RM-1035_JUMP_TABLE_IC_MEA_MA_eMP_10.01.11_001 CODE_VERIFY : Ok Executing FFS FORMAT now... FAT_RANGE : 0x003A4000-0x003F3FFF , LEN : 0x00050000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE Rebooting phone now Flashing done! Total flash time : 00:00:16 Reboot phone Ok - > Hint : If phone shows Battery charge icon - press and hold PowerOn button 10 seconds |
03-26-2016, 16:49 | #64 (permalink) | |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Quote:
Try change in best.ini , under "server" section option "SChan" to 0. Save file and try donwload again. | |
03-26-2016, 16:51 | #67 (permalink) | |
You must now select COMPLETE FW. Next time, when you will want to CHANGE LANGUAGE ONLY - make sure about you select SAME FW version, as inside phone. If not sure - flash COMPLETE FW. | |
03-27-2016, 16:39 | #68 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version released - http://forum.gsmhosting.com/vbb/f641...-more-2070637/ |
09-27-2016, 10:00 | #75 (permalink) |
Freak Poster Join Date: Jul 2006 Location: W-no
Member: 310418 Status: Offline Thanks Meter: 13 | Hi guys, i instaled lumia driver on windows Xp , driver looks to be instaled , but on task on best software i cant check read info on wp10 section ... any sugestions ? |
