02-28-2017, 17:26 | #108 (permalink) |
No Life Poster Join Date: Aug 2015 Location: Bangladesh Age: 30
Member: 2443283 Status: Offline Thanks Meter: 518 | NOKIA 215 Flashing Failed Wait for phone... Phone found! [ 60 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : FF1D41B24E41D1906D07489F7F67046A BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL failed! (CMD not accepted, 0xAA) Check Power / Cable! BootLoader Init Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... NEED HELP JOYDI |
02-28-2017, 18:28 | #109 (permalink) | |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
Drivers not installed correcly(driver to flash phone!!) | |
03-01-2017, 17:58 | #110 (permalink) |
Member: 2443283 Status: Offline Thanks Meter: 518 | NEED FIX SOLUTION wgmmmx1 Connect phone on selected interface... Core : v2.25 , BB5XG FlashEngine : v10.3 Selected FlashSettings : FullFlash Check FlashFiles, Please, wait... Files Set for Flashing : MCU : rm862__04.51.mcusw PPM : rm862__04.51.ppm_ea CNT : rm862__04.51.image_ea_059Q097 Flashing phone now... [Gen] Rules accepted for : XGOLD Generation Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... -> If Windows say "Unrecognized device" / Operation not start -> Or if Phone start charge - just reinsert battery -> If flashing freeze - reinsert cable/battery and try again --- Press phone's power button or insert usb cable! --- Connection opened successfully IF Boot Init : 0xF0 IF Resp Len : 0x0A IF xCPUID : XGOLD 213 [XMM2130 QUANTUM] IF Resp Data : 1FB300020303010100FF Sending EBL Loader ... EBL Loader Ok, 01 EBL Loader ready, AA Sending EBL ... EBL sent Ok EBL : Quantum_Bootloader_10.55_M1S1 Speed accepted, use 6.500.000 FLASHID : 89008289 FLIC conf set, RST set Boot done! Check keys... Check done. Image can be flashed Backup enabled, will read all certificates Reading CCC Reading HWC Reading NPC IMEI 1 : 355507055060243 IMEI 2 : 355507055060250 PCcode : 059Q0D4 NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\355507055060243_2n d_XG213_CRT.rpl Settings : EDM [0x8] , Block Mode , Fast CRC , Verify ===Flashing [MCU]=== File : rm862__04.51.mcusw Image : rm862__04.51.mcusw_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 5 region(s) Processing Region 1/5 Erase , Start : 0x40000000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40000000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 2/5 Erase , Start : 0x40040000 , Len : 0x00020000 Erasing, wait ... Erase done, time : 00:00:00 Write , Start : 0x40040000 , Len : 0x00020000 Flashing , wait ... Region flash done, time : 00:00:00 Processing Region 3/5 Erase , Start : 0x40060000 , Len : 0x00100000 Erasing, wait ... Erase done, time : 00:00:05 Write , Start : 0x40060000 , Len : 0x00100000 Flashing , wait ... Region flash done, time : 00:00:01 Processing Region 4/5 Erase , Start : 0x40280000 , Len : 0x017C0000 Erasing, wait ... Erase done, time : 00:02:18 Write , Start : 0x40280000 , Len : 0x017C0000 Flashing , wait ... Region flash done, time : 00:00:27 Processing Region 5/5 Erase , Start : 0x43E20000 , Len : 0x00040000 Erasing, wait ... Erase done, time : 00:00:00 No write data, skip [Minor Error] : CRC returned by phone is wrong! [CHK] : 01003014 ===Flashing [PPM]=== File : rm862__04.51.ppm_ea Image : package_ea.ppm_ebl_psi.fls Sec-pack found, sending ... Sec-pack sent Found 1 region(s) Processing Region 1/1 Erase , Start : 0x41A40000 , Len : 0x00640000 Erasing, wait ... Erase done, time : 00:00:27 Write , Start : 0x41A40000 , Len : 0x004BB910 Flashing , wait ... Region flash done, time : 00:00:05 CRC check passed , 0x3A66 ===Flashing [CNT]=== File : rm862__04.51.image_ea_059Q097 Image : package_ea_059Q097.image.fls Sec-pack found, sending ... Sec-pack sent Found 2 region(s) Processing Region 1/2 Erase , Start : 0x42080000 , Len : 0x01DA0000 Erasing, wait ... Erase done, time : 00:01:16 Write , Start : 0x42080000 , Len : 0x00F20000 Flashing , wait ... Region flash done, time : 00:00:18 Processing Region 2/2 Erase , Start : 0x43E60000 , Len : 0x000E0000 [ERR_hReqFlashEraseStart] : 8201410040000000 Error... -> Check cable, flashfile, try again from this file Connect phone on selected interface... Elapsed: 00:05:46 Connect phone on selected interface... |
03-02-2017, 08:24 | #112 (permalink) | |
Member: 2443283 Status: Offline Thanks Meter: 518 | Quote:
Sent from my MI 5 using Tapatalk | |
The Following User Says Thank You to nahidroman For This Useful Post: |
03-22-2017, 09:51 | #117 (permalink) |
Member: 1043909 Status: Offline Thanks Meter: 60,926 | New version released - http://forum.gsmhosting.com/vbb/f641...anges-2206843/ |
