05-09-2017, 08:08 | #34 (permalink) |
No Life Poster Join Date: Feb 2008
Member: 711273 Status: Offline Thanks Meter: 81 | HI, DEAR SIR, HOW TO ENTER TEST MODE Microsoft 650 Phone not in service mode! Set phone to Test mode first! Phone require ENO for enter in TEST mode!!! You can download ENO file in NaviManager tab! SSChannel : Create SC SSChannel : Failed to get info! ErroInfo : Unknown response received from SRV PLEASE SAY HOW TO DO |
05-09-2017, 08:26 | #35 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Nokia 216 after flash with higher version phone show contact service :( phone was working good Software ver : 11.00.11 00-00-00 RM-1187 flash with 12.00.11 but show contact service Code: Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 11.00.11 00-00-00 RM-1187 IMEI 1 : 354884087283742 IMEI 2 : 354884087283759 XappVer : 000008F2 Ape Ver : NEMO G 59cb152c/0 (59cb152c+0) T Mon Jul 1 02:50:44 2013 U 69b804d5 PPM : IJ CNT : SUEZ.11.00.11.p1 Product SN : FACBF44AU Product code : 059X807 Base Prd.code: 059X9H2 Module code : 0207175 Hardware info======= HWID : 1101 LCDVer: TPO Lock info =========== IMEI : 354884087283742 IMEI spNet : 3A 45 88 04 78 82 73 24 Conf key : 800000000004000B Provider key : 2440700000000000 Country : Finland Operator : NOKIA (Open) Lock info: Block 1 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 2 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 3 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 4 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 5 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 6 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; Block 7 L1:Open; L2:Open; L3:Open; L4:Open; L5:Open; SimLock status : Ok Security status : Ok Done! Core : v2.29 , MTKx FlashEngine : v14.0 Verify files ... MAUI : RM-1187_SUEZ_ROM_eMP_12.00.11 VIVA : RM-1187_SUEZ_VIVA_eMP_12.00.11 LANG : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 CUST : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 JMPT : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 - > MODE : FullFlash Software Info: 11.00.11 00-00-00 RM-1187 IMEI: 354884087283742 PPM version : IJ Product code: 059X807 Rebooting phone to FlashMode... Wait for phone... Phone found! [ 61 ] Sync... Sync Ok, read regs... Inital regs read done Boot Info : BB_CPU_ID : 6260 BB_CPU_HW : CB00 BB_CPU_SW : 0000 BB_CPU_SB : 8000 BB_CPU_NM : [MediaTek] MT6260_S0001 BB_CPU_SN : F9650D5B1E82277FC95D6F99B0C572F6 BROM Protocol Version : 05 BROM Status : 0000 Comm Status : 0000 EXBL Status : Alive [ USB Load Active ] Switch to BL done BL Version : 01 Setting... Setting done , result code 0x8000 Project ID : SUEZ.11.00.11.p1 BROM/BL stage done Seek and prepare DownloadAgent DownloadAgent matching HW Found! DA verify and select done Sending DA to target ... DA_eMP_Suez.fg DA_VERIFY : 00 DA_JUMP : 00040000 DA_AUTH : Passed! DA_INFO : 0xC0 , Ver : 3.2 , BBID : 0x8B DA_CSTAT : 0x5A SOC_VERIFY : 0xC1 BOOT_STYLE : SF_FLASH_BOOT NOR Flash IC initialized [0] : FLASH_VEN : 0x00F8 , [WINBOND] W25Q128FW [0] : FLASH_DIE : 00EF 0060 0018 0000 [0] : FLASH_LEN : 0x01000000 FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 SecureDecrypt : RM-1187_SUEZ_ROM_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_VIVA_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 SecureDecrypt : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 Executing FFS FORMAT now... FAT_RANGE : 0x00CE0000-0x00FF3FFF , LEN : 0x00314000 DA_RET : DA_IN_PROGRESS DA_RET : FORMAT_DONE OVRLP : 000069B900000001 PHPID : SUEZ.11.00.11.p1 OVRLP : 00004DF900000001 DA : FORMAT_BIN Processing Flash Pre-format FILES : 5 SAFE_BLOCK : 04 FORMAT_BIN : Ok WRITE_STYLE : DEF : 0x01 (SEQ) Write : RM-1187_SUEZ_ROM_eMP_12.00.11 Write : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 Write : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 Write : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 Write : RM-1187_SUEZ_VIVA_eMP_12.00.11 CODE_DNLOAD : Ok [VERIFY] DONE : RM-1187_SUEZ_ROM_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_LANG_PACK_ROM_IJ_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_CUSTPACK_ROM_IJ_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_JUMP_TABLE_IJ_eMP_12.00.11 [VERIFY] DONE : RM-1187_SUEZ_VIVA_eMP_12.00.11 CODE_VERIFY : Ok Flashing done! Total flash time : 00:02:54 Reboot phone Ok ReadInfo can't be done! Re-insert battery and power up phone manually Connect phone on selected interface... Phone found! MTKx Nokia Phone detected Read info... Ok Reading Phone Info.... Software ver : 12.00.11 00-00-00 RM-1187 IMEI 1 : 123456789012345 IMEI 2 : 123456789012345 XappVer : 000008F2 Ape Ver : NEMO G 4122fe8d/1 (00000000+0) T Thu Dec 29 01:31:09 2016 U d61db836 PPM : IJ CNT : SUEZ.12.00.11.p1 Product SN : FACBF44AU Product code : 059X807 Base Prd.code: 059X9H2 Module code : 0207175 Hardware info======= HWID : 1101 LCDVer: TPO Lock info =========== IMEI : 123456789012345 IMEI spNet : 0A 00 00 00 00 00 00 00 Conf key : 0000000000040000 Provider key : 0000000000000000 Country : Unknown Operator : Unknown Lock info: SimLock status : Ok Security status : Damaged!!!!! Done! http://forum.gsmhosting.com/vbb/f641...21/index3.html how to fix now |
05-09-2017, 11:22 | #36 (permalink) | |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Quote:
The Following User Says Thank You to masoudsoftwrae For This Useful Post: |
05-10-2017, 10:38 | #38 (permalink) |
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Hello, in naviManager show version "10.01.11" Code: Connect phone on selected interface... SSChannel : Create SC SSChannel : SC Created! ProductID HWCode : RM-1187 Selected Variant : RM-1187 NDT MEA IJ BLACK URDU PK Firmware Version : 10.01.11 Platform Version : S30+ SSChannel : DC Ok with code 0x06 Switch to IDM now ... IDM initializing, wait... Checking access to Products folder... Folder for RM-1187 exist Prepare done, collect info |
