Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 05-17-2017, 15:48   #46 (permalink)
Member: 2523799
Thanks Meter: 2
Nokia RM-1133 Format flash problam
i face this error on nokia 1133 and nokia 108
Old 05-18-2017, 14:11   #47 (permalink)
JayDi's Avatar
Member: 462970
Thanks Meter: 15,404
Originally Posted by Jiminay2000 View Post
I killed all suspicious processes but still the same (Best closes after press Flash button).
Seems as something left on driver level and that is sniffer.
The Following User Says Thank You to JayDi For This Useful Post:
Old 05-18-2017, 14:12   #48 (permalink)
JayDi's Avatar
Member: 462970
Reisntall USB drivers, use good short cable without any hub or etc.
Old 05-23-2017, 18:34   #49 (permalink)
Member: 207561
Thanks Meter: 717
Nokia 216 rm-1187 flash after full flash Contact servies..
whats rong?
Old 05-24-2017, 11:25   #50 (permalink)
JayDi's Avatar
Member: 462970
whats rong?
Read. Read. Read first post :
MTKx Legacy/HMD models:
  Those phones may have 2 version of firmware (old and new sec)
   Nokia 150 (it has legacy and hmd version)
   Nokia 105, Nokia 130, Nokia 216, Nokia 222, Nokia 230: probably two versions are available
  CS problem after flashing may be a result of flashing different   version. Just reflash to another one ( SW10: LEGACY, SW11 and newer: HMD   )
Old 06-02-2017, 09:01   #51 (permalink)
Member: 1922334
Sonork: ali
Thanks Meter: 6
all my frinds N okia 230 V14.000
https://drive.google.com/drive/folde...XVuRlkyNXdmWkE
The Following User Says Thank You to M Sabeer jami For This Useful Post:
Old 06-07-2017, 11:14   #52 (permalink)
nahidroman's Avatar
Member: 2443283
Thanks Meter: 507
Nokia 520 rm-914 flash done
Waiting for phone...
Dead mode is selected , no phone in normal mode found
1. Press and hold "Volume Down"
2. Insert USB cable
3. Hold button until phone will be detected
Device catched in BOOT mode!
Boot Mode confirmed!
Setting Preloder
Collect Info...
Setting Application
Setting Secure
Collect Info...
=== Nokia Flash App info :
Protocol Version : 1.12
Protocol Implementation : 1.23
=== Phone Initial info :
Phone RMxxx ID : RM-914
Phone Model ID : Nokia.MSM8227.P6036.1.2
Phone Model PC : 059S3T5
Phone IMEI : 358352054651214
=== eMMC info :
eMMC Vendor : Samsung
eMMC CID : 0015
eMMC Size : 7456 MiB
=== Security Initial info :
Security Status : 010100000101
Secure Boot : Enabled
Secure eFUSE : Enabled
JTAG : Disabled
RDC Key : Not Present (Retail)
UEFI SBoot : Enabled
SecHW Key : Exists
Device RootKey : F771E62AF89994064F77CD3BC16829503BDF9A3D
=== Other info :
SD present : False
Full Check skipped , will be checked by ImageSignature
Battery Level : 57%
RPMB Provision Status Code : 0x0101
Device RAM size : 512 MiB
Device not have ATRP
Backup to RAM Ok!
FFU : RM914_3058.50000.1425.0006_RETAIL_eu_euro1_327_06_ 452364_prd_signed.ffu
Flashing FFU
Sending FFU Header CertData
Header sent , accepted
Perform Data Partition Erase
Erase done
Sending FFU Payload Data...
Finishing flashing
Flashing done!
Green Light
Image Sent, processing PostFlash
FinalConfig : abnormal status, error code : 0xFF7F0000
Make Factory Set : Ok
Restore RAMBkp : Ok
Update NVI from Image
Ok , NVI will be updated on first boot!
PostFlash Finished
Total flash time : 00:04:33
Rebooting
Connect phone on selected interface...
Phone found!
WP10/WP8x Lumia Phone detected
Read info... Ok
Phone disconected!
The Following 3 Users Say Thank You to nahidroman For This Useful Post:
Old 07-20-2017, 08:01   #53 (permalink)
Member: 614128
Thanks Meter: 2
SSChannel : Create SC
SSChannel : Failed to get info!
ErroInfo : Unknown response received from SRV
Old 07-20-2017, 08:43   #54 (permalink)
JayDi's Avatar
Member: 462970
Almost all Nokia MTK firmwares removed from server. Use support or thracker. Also you can read FW from alive MTK phones and make Factory-Like one.
Old 07-24-2017, 11:31   #55 (permalink)
Member: 2740028
Thanks Meter: 2
!QUESTION:
I install the "InfinityBox_install_BEST_v2.29.7z" on my computer. Afterwards, whenever I try to open the software it only stuck in "Run as Administrator>YES" but no Nokia BEST operation window appears.. I also watched step-by-step tutorials in youtube on how to install this software but nothing happens.. (
Can anyone help me? please? I want to flash my Nokia 230 Dual SIM(RM-1172) because I forgot the security code.
What do I need to do to make it work?
TIA
The Following 2 Users Say Thank You to NightMode For This Useful Post:
Old 07-24-2017, 18:44   #56 (permalink)
JayDi's Avatar
Member: 462970
Good news : b2x up their server ( on MS base )
Hope very soon we will get navi with MTK back. As soon, as it start working - will be new update.
The Following 5 Users Say Thank You to JayDi For This Useful Post:
Old 07-30-2017, 00:43   #57 (permalink)
zubairok's Avatar
Member: 294200
Sonork: 100.1586184
Thanks Meter: 644
waiting for this good update .....
Old 08-08-2017, 05:03   #58 (permalink)
Member: 2745238
Question Run in windows
How to run in windows ???? please!!!
Old 08-08-2017, 15:59   #59 (permalink)
JayDi's Avatar
Member: 462970
No way.
Install FreeBSD on yor PC, install KDE2 and patch it.
Then you can run BES under FreeBSD.
Old 08-29-2017, 17:53   #60 (permalink)
Member: 1613469
Thanks Meter: 119
Originally Posted by YellowBoss View Post
Infinity Nokia [BEST] v2.29 - MTK Nokia Firmware Reader/Maker and more
- MTKx Flash Engine updated
Automatic "Repair Mode" enable, if device have damaged ROM
Infinity ( Factory-Like ) FW flashing support
- xCNT tool updated
MediaTek tab activated
Allow make firmware for MTK phones from read dump
Supported lines:
Nokia 108: RM-944, RM-945, RM-1124
Nokia 220: RM-969, RM-970, RM-971, RM-1125
Nokia 225: RM-1011, RM-1012, RM-1043
Nokia 130: RM-1035, RM-1036, RM-1037, RM-1122
Nokia 215: RM-1110, RM-1111, RM-1112
Nokia 105: RM-1133, RM-1134, RM-1135
Nokia 222: RM-1136, RM-1137
Nokia 230: RM-1172, RM-1173
Nokia 216: RM-1187, RM-1188
Nokia 150: RM-1189, RM-1190
Result FW is like factory one, which contain all need part to complete reflash or langpack change.
Older models below Nokia 105 are supported as backward compatibility. Almost not required to use.
Main use:
1. Make firmwares for HMD phones which are NOT available YET!
2. MTKx Legacy/HMD models problem solution: read FW from HMD devices (sw11 and newer)
Optional use: Make firmwares with required LANGPACK which are NOT available YET!
- Service operations revised
MTKx: FlahIC detection on flash read improved for some devices
MTKx: Dump reading more faster now
NXP: HW revision verification has made problems for some rare X+ and XL+ models, fixed
- Other
Some bugfixes and improvements at all
Lumia/Nokia:
MS will CLOSE WHOLE Windows Mobile support at June 2017.
What will be with servers with firmwares - no one knows, but MS politic is simple - close and forget!
If you have chance, free drive space and good inet: DOWNLOAD ALL NEED FIRMWARES!
There will be NO newer versions anymore other than existing ones.
Download link #1 - Download link #2 - Download link #3
Upload file to Support - Download files via Torrent
Infinity-Box 12 years (2005 - 2017) updates and support as nobody else - News
Twitter - Facebook - Telegram
WP8 Unlock Started
Connecting to server...
Connection faled: Socket Error # 10060
Connection timed out.
Disconnected
Error! Check previous error message for more info!
Credits: 170
Page generated in 0.39358 seconds with 8 queries
