Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Infinity-Box > BB5 Easy Service Tool (BEST) Nokia Dongle
Old 07-17-2012, 16:21   #1 (permalink)
Member: 128745
Infinity Nokia BEST Version 1.48 released !!
Infinity Nokia BEST v1.48 Released
Whats New
- USB flashing improved
- BB5 USB loaders updated
- MSM72x flashing (Lumia 610) was broken on previous release, fixed
- Added ASIC check for BB5, from now not possible flash wrong firmware (e.g. RAP4 to BCM and others)
- Maemo/Meego flashing revised, work now on XP without problems
- Maemo (N900) error handling added (if will be errors, like CMT,APE, e.t.c. faults, BEST show reasons and way to fix them)
- RPL reading during flash improved for XG213
- MeeGo eMMC only flash improved
- MeeGo USB loader updated
- Service operations improved
- Improved XG213 RPL reading
- Added SelfTest option for Lumia series (battery/power/e.t.c diagnostic)
- Fixed hang during PM read/write on some models
- During Cam Check/Repair also will be done HW check (Detect HW fault, show reasons of error)
- For CNT reset added default SL tables for XG213 phones (replace/repair damaged tables, CS repair after bad reset)
- XG110/DCT4+ reset user code improved ( set to default 12345 without data lost / full reset)
- New Operator/Country info with new base (BB5/Infineon - Lock info)
- Security repair for N73 improved (res
tore ccc/hwc)
- SL3 simlock extraction improved
sl: Added support for new types
sl: Added new way of rpl validation during recovery
sl: Added support SL3/SL30 simlock extraction even from working , but SL damaged phones (!!!in SOME cases!!!)
sl: Added auto rpl complete in some damage cases
sl: Added support for locked phones (under test)
sl: Improved SL3 simlock extraction and pre-validation
sl: Rewriten SL30 simlock extraction
sl: Added SL30 simlock pre-validation
sl: SPR reading improved
sl: Revised support of override SL types (skip not SL3/SL30 phones)
As always, simlock present check for free, so, handjob lovers can find some more things now
- User data operations improved
- Added support for new-type XG213 phones (110,111,112 and same)
XGnew: Phonebook backup/extract/write
XGnew: LifeTimer edit
XGnew: Gallery backup
XGnew: SMS read/write/extract
- Improved s4pb format - full cross-writing between BB5 S40 , DCT4+ ARM (XG213) , DCT4+
- Improved SMS/Gallery/PhoneBook extraction from phones with partialy damaged FS
- Improved Phonebook/Gallery/e.t.c extraction for some S40/S60 models f
rom FullFlash
- Improved data extraction from fullflash from S40/S60/S^3 models
- Improved PhoneBook reading from BB5 S40 phones (C3 bug and some others fixes)
- Fixed freeze during extraction on some model (Note! some big-sized (512,1024mb flash - can take up to 10-20-40 minutes!)
- Low Format fixed for 8800 arte
- Other
- Maemo flashing from Normal (powered on state) mode fixed
- MeeGo/Maemo flash file info added (region, langs, PR version, e.t.c)
- Improved flashfiles check (Maemo/MeeGo/BB5/Lumia/Infineon)
- Fixed VPL parser (modem part clear and file checking for Lumia)
- RSA check improved (added new models)
- INI revised
- Some bugfixes
- New WP7 models added (L610c)
- Updated WP7 wipe files
- Updated stuff files (tune/rpl)
Software can be downloaded HERE
The Following 156 Users Say Thank You to Infinity-Box For This Useful Post:
..::Rana Bilal::.., .::kabir::., .::mastech::., 089999945, 234, A Salam, aashir, abd5alla, adebam, adnan_taeki, aduel, Advantage, aermacchi, afhaan, ahad_unlocker, ajaystarin, aljaded, all4one_99, alupihan, amc_khan, ameerl, americantel, anasshe, ari86ynr, asanfile, ashik.telecom, astana2007, atashius, benny Haraba, beoption, Bismillah_mob, bisubikash, blolyxx, budi cross, budi_mmp, carlos32, celumaster., cheong966, chuithailand, dancd, danishalnoor, davoodbakhtiari, deepgsm, diaa aldeen, dika_gsm_dz, djuce, drsty, dr_moosavi, eddyreal, Elioni, faisal.u7, Fantoz, FIRAT58, forid, foytong, ganjbek, gouda66666, GSM SNIPER, GSMCapitan, gsmfareed, GsmUniversal, halfa40gsm, hassanlou, hassan_k, Hatim2006, headszone1, hectorgomez007, hemal201, heresh, HI TECH SOLUTIO, husainsarfraz, hyber_99, h_1st, ISFAHAN_GSM1, jawad munir, Jesslin, JorgeVla, juned5501, karikari, kay_pencenk, KOCLOK, koushalvikas, krishna98452, le nghia, MALIKTARIQ, mansour_bos, mbiborna, md.babu, mobiledunia, mobile_zone1, mohamed bessa, mohamed183, mohamed3, mort83, muhyar h, myHWK, najim uddin, nanocell, nasirns, nksonu, NOMAN MEHMOOD, obioha, papa samba, parsiland, parvizakila, pateltahir, peruony, PHONEX_XX, prime_master786, princegsm, qpraba, rayfirst2010, rehan143, ReyTech, Rhyan777, risi_wb, Roman_BY, rorm, S H A K S, sabirsultan, sacha, sadiq123, sagez gsm1, samer.mob, SanjanMobile, santoshniroula, sarket, shadigsm, shahzaadbutt, Shakeel_pattoki, sheik.sd, singletch, SkyMobile05, soereos, some_info2010, ssshhh, Star Net, star.star, sweathasreekant, TECNICELL2007, the sorrow, toky06, umair.zego, umarnlw, Vanga, Vijendra Saini, ViperGSM, vuongkien79, wawan84, wehech, wgmmmx1, yawarniazi, yogeshpatel4790, ZAHID338, Zarip, ZOUBIR4K
Old 07-17-2012, 16:24   #2 (permalink)
adnan_taeki's Avatar
Member: 417778
Sonork: 100.1603326
Good update brother ...
Nice Work
Regards,
Adnan Khaver
Old 07-17-2012, 16:25   #3 (permalink)
@NAYEM121's Avatar
Member: 1134660
Sonork: 100.1593764
Thanks Infinity Nokia BEST team.
Old 07-17-2012, 16:26   #4 (permalink)
supportallgsm's Avatar
Member: 194074
Sonork: 100.1574944
Good update infinity team.
Old 07-17-2012, 16:26   #5 (permalink)
Member: 1296033
Sonork: 100.1615063
good update .......................................
thanks
Old 07-17-2012, 16:29   #6 (permalink)
gsm_links's Avatar
Member: 561947
Sonork: 100.1580399
good update.
Wbr
s n hasan
Old 07-17-2012, 16:38   #7 (permalink)
azerty_soft's Avatar
Member: 168313
Sonork: 100.1609490
The Following User Says Thank You to azerty_soft For This Useful Post:
Old 07-17-2012, 16:39   #8 (permalink)
husainsarfraz's Avatar
Member: 1478271
Sonork: 100.1608386
The Following User Says Thank You to husainsarfraz For This Useful Post:
Old 07-17-2012, 16:45   #9 (permalink)
Member: 359369
Good update thanks to infinity team
The Following User Says Thank You to mohamed3 For This Useful Post:
Old 07-17-2012, 16:48   #10 (permalink)
Member: 1777637
Sonork: 100.1616860:md
good job, kip it up. thaks best team
The Following User Says Thank You to juned5501 For This Useful Post:
Old 07-17-2012, 16:49   #11 (permalink)
sarket's Avatar
Member: 1572648
Sonork: 100.1594828
The Following 9 Users Say Thank You to sarket For This Useful Post:
Old 07-17-2012, 16:50   #12 (permalink)
Member: 614765
infinity
Old 07-17-2012, 16:55   #13 (permalink)
Member: 845667
You are the best......
Thanks
Old 07-17-2012, 16:58   #14 (permalink)
Member: 1725706
nice update just best dongel and infinty team
br:gsm-1.ir
The Following User Says Thank You to ISFAHAN_GSM1 For This Useful Post:
Old 07-17-2012, 16:59   #15 (permalink)
Member: 1725884
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 26 09-25-2012 02:41
DES key Driver black Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 6 07-19-2012 05:32
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 05-19-1999 17:41
Page generated in 0.39522 seconds with 11 queries
