11-26-2012, 15:57 | #1 (permalink) |
Freak Poster Join Date: Apr 2008 Location: Pakistan
Member: 750024 Status: Offline Sonork: 100.1612548 Thanks Meter: 78 | Infinity Team Need help There is nokia 311 rm-714 Security code problem. flash by best bb5. After flash set is contact service. sir its set info . ========================================== Files Set for Flashing : MCU : rm714__03.90.mcusw PPM : A013CD59_rm714__03.90.ppm_maa CNT : DEF047F5_rm714__03.90.image_maa_059M454 Flashing phone now... Check files done... -> SWversion check skipped : Dead mode selected Dead Mode is Selected Waiting for USB device... --- Insert cable and charger or press phone's power button! --- Connection opened successfully Waiting for communication response... BootRom : 1st boot ok ASIC ID: 000000030000022600010007400C192103032108 CPU ID : RAPU v21 , Features : Dead-Test , USBRPL , FullUSB EM0 ID: 00001051 EM1 ID: 00001060 PUBLIC ID: 2C5B0000FFFB3C406B0559060CB2A1764FDC6304 ASIC MODE ID: 00 ROOT KEY HASH: 3AB5DB70B45D23F1ADEEBB5734160706 ROM ID: 2CAC45E23BC33C8B Use RAPUv21_2nd.fg , Rev : 3.0 Ver : 12.14.0 Processing RAWLOADER... FLIC : 00400020 Req : XSR 1.6 Use RAPUv21_XSR17_alg.fg , Rev : 3.0 Ver : 12.14.0 Processing PASUBTOC ... Processing ALG ... Boot Done! TIME : Boot time : 00:00:03 Reopening the connection... Waiting for response: 30 ADL: Check mode Select ASIC [C900] PAPUBkeys : A3E0AA6F2F86410BA6D666BACF6186EEFBC82D28 ADL: phone is in flash mode Backup enabled, will read all certificates... Reading NPC certificate... IMEI : 354619052656401 Reading CCC certificate... Reading HWC certificate... Reading R&D certificate... Reading VARIANT certificate... Reading PARTNERC certificate... Reading MDM_KEYS certificate... NPC Certificate saved... CCC Certificate saved... HWC Certificate saved... RPL saved : c:\InfinityBox\BEST\Backup\Cert\354619052656401_CR T.rpl === SW Version Check === - > REFLASHING === SW Version Check === ===Flashing [MCU]=== Erase : Processing rm714__03.90.mcusw Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing rm714__03.90.mcusw CMT: Writing Hash CERT [KEYS] CMT: Writing Hash CERT [PAPUBKEYS] CMT: Writing Hash CERT [DSP0] CMT: Writing Hash CERT [MCUSW] CMT: Writing Hash CERT [MCUSW1] CMT: Writing Hash CERT [GENIO_INIT] CMT: Writing Hash CERT [ISA+DYNSW] CMT: Writing Hash CERT [ADA] CMT: Writing Hash CERT [PRIMAPP] CMT: Writing Hash CERT [PASUBTOC] CMT: Writing Hash CERT [RAP3NAND] CMT: Writing Hash CERT [UPDAPP] CMT: Writing Hash CERT [ISA+EXTDRV] Total writen 286 blocks TIME : Write time : 00:00:04 MCU Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [PPM]=== Erase : Processing A013CD59_rm714__03.90.ppm_maa Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:00 Write : Processing A013CD59_rm714__03.90.ppm_maa Total writen 88 blocks TIME : Write time : 00:00:01 PPM Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ===Flashing [CNT]=== Erase : Processing DEF047F5_rm714__03.90.image_maa_059M454 Partitioning.... Partitioning Ok... Erasing.... Erasing Ok... TIME : Erase time : 00:00:02 Write : Processing DEF047F5_rm714__03.90.image_maa_059M454 Total writen 628 blocks TIME : Write time : 00:00:10 CNT Write done ADL: Request programm status NAND status : 00000000 / 00000000 / 00000000 ADL: Close_Session Content: 000300000000000000000000000000 ADL: Reboot Flashing done! Total flash time : 00:00:19 Reboot phone now... Reading Phone Info.... Connected phone - Nokia 311 Software Info: V 03.90 11-07-12 RM-714 (c) Nokia IMEI: 354619052656401 PPM version : V 03.90 11-07-12 RM-714 (c) Nokia MAA Product code: Checking... SimLock status : SimLock Damaged!!!!! Security status : Security is Ok Read Info Done! Processing After Flash Defaults... Error When resetting FullFactory ... Error When setting User Data defaults ... Error When setting Service defaults ... Error When setting Leave defaults ... Error When resetting Product Tune ... Error When resetting SW upgrade Default ... AfterFlash operations done ;D Done! Elapsed: 00:00:45 Connect phone on selected interface... Phone found! Series 40 Device detected! read info... - Ok Reading Phone Info.... Connected phone - Nokia 311 Software ver : V 03.90 11-07-12 RM-714 (c) Nokia IMEI : 354619052656401 DSP Ver : MCL_3.85 PPM : V 03.90 11-07-12 RM-714 (c) Nokia MAA CNT : Content: maa_059M454 V 03.90 11-07-12 RM-714 (c) Nokia Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 51 Tahvo : 00 Batery: 3894 mV CMT BT: 19e2-4702E12 LCDVer: TPO Lock info =========== IMEI : 354619052656401 IMEI spNet : 3A 45 16 09 25 56 46 00 IMEI svNet : 33 45 16 09 25 56 46 10 F3 Unable to read Lock table... CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SimLock Version : PA_SL phone detected User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Reading Phone Info.... Connected phone - Nokia 311 Software ver : V 03.90 11-07-12 RM-714 (c) Nokia IMEI : 354619052656401 DSP Ver : MCL_3.85 PPM : V 03.90 11-07-12 RM-714 (c) Nokia MAA CNT : Content: maa_059M454 V 03.90 11-07-12 RM-714 (c) Nokia Product SN : 0 Product code : Long Prod.SN : 0 Hardware info======= HWID : Retu : 51 Tahvo : 00 Batery: 3889 mV CMT BT: 19e2-4702E12 LCDVer: TPO Lock info =========== IMEI : 354619052656401 IMEI spNet : 3A 45 16 09 25 56 46 00 IMEI svNet : 33 45 16 09 25 56 46 10 F3 Unable to read Lock table... CRT308 Backup Created SDD key status : Damaged!!!!! CMLA Key status : Not Present SimLock status : Damaged!!!!! Security status : Ok PA_SimLock Version : PA_SL phone detected User Code : 12345 MMC pwd : no any record found UserDataExLevel : Full [PhoneBook, Calendar, PWD, SMS, Gallery] Done! Set phone in Normal mode... Restarting... Done! |
11-27-2012, 08:08 | #3 (permalink) |
Member: 750024 Status: Offline Sonork: 100.1612548 Thanks Meter: 78 | No bro its ok befor flash i check it .show only security code then smpile flash by best bb5 but after flash set is contact service. Bro its new frash set. its buy two days ago. ; please infinity team need help ; |
11-27-2012, 10:16 | #6 (permalink) |
Member: 750024 Status: Offline Sonork: 100.1612548 Thanks Meter: 78 | bro set is on then show only security code and not check software version i thank its problem But where is infinity team. =========================== |
