05-30-2020, 08:43 | #3 (permalink) |
Freak Poster Join Date: Aug 2016
Member: 2617962 Status: Offline Thanks Meter: 6 | i have uninstalled best software, deleted manualy what left and after that installed again. the problem is mine smart card is shown as unknown smart card. it`s hardware identification is SCFILTER\CID_80318065b0831148c883009000 could you give me good drivers for it for 8.1 x64 or i should make a new installation of windows 10? thank |
05-30-2020, 10:09 | #4 (permalink) | |
You do not need re-install windows. Smart-Card itself do not need any drivers. Smart-Card reader drivers are here - https://www.infinity-box.com/support/ If you see some kind of message like "unknown device" after you connect dongle to PC it means (in most cases) that it's a hardware problem. Now connect dongle to PC and make this: - Connect dongle/box to PC - Run CardID software - https://www.infinity-box.com/support/?r=7 - Select Card-Reader - Click to "Read" button DO NOT send screenshot/video but copy/paste text from software window ! | |
05-31-2020, 10:48 | #5 (permalink) |
Member: 2617962 Status: Offline Thanks Meter: 6 | Card-Reader: Alcor Micro USB Smart Card Reader 0 ATR: 3B7D95000080318065B0831148C883009000 Card Manager: A000000018434D00 SerialNumber: 0106777D ROM: Integrated Circuit Fabricator: 4250 Integrated Circuit Type: 3272 OS: Identifier: 1291 Release Date: 6181 Release Level: 0700 EEPROM: Fabrication Date: 1103 Serial Number: 0106777D Batch Identifier: 1857 Module Fabricator: 1292 Module Packaging Date: 1271 IC Card Manufacturer: 2003 IC Em******* Date: 1271 Pre Personalizer: 2004 Pre Personalization Date: 1271 Pre Personalization Equipment Identifier: 00002222 Personalizer: 0000 Personalization Date: 0000 Personalization Equipment Identifier: 00000000 m_iopCard.Serial: 0106777D18571292 GP Version: 2.1.1 SCP Version: 1, Option: 5 |
05-31-2020, 11:09 | #6 (permalink) |
Member: 2617962 Status: Offline Thanks Meter: 6 | everything should be ok - good install , net framework, good driver for smart card reader + no updates for firmware and just showing the logo and that`s that. I gave you debug from the program you wanted and now give you that : https://drive.google.com/file/d/1NsD...ew?usp=sharing |
05-31-2020, 19:10 | #7 (permalink) | |
Drivers installed well. You DO NOT need to update dongle firmware | |
05-31-2020, 19:11 | #8 (permalink) | |
\program files\avast software\avast\aswidsagent.exe Disable AVAST, delete fault.bn file and run Infinity software. Result ? | |
06-01-2020, 10:57 | #9 (permalink) |
Member: 2617962 Status: Offline Thanks Meter: 6 | oh jesus. it`s working. If i try only to give secure access to exe file and enable AV will it work ? Please answer me good enough to my thread to flash one old nokia - you can find it easy. |
