03-12-2016, 10:14 | #1 (permalink) |
No Life Poster Join Date: Apr 2014 Location: tripoli,libya Age: 36
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Initial Register Read Failed (HW/Connection Error) nokia 225 i try to flash but the phone did not boot the battery is full charge ? Code: Connect phone on selected interface... Core : v2.19 , MTKx FlashEngine : v9.7 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Device boot not done Check Drivers Try again Boot Error Flashing failed! Connect phone on selected interface... Core : v2.19 , MTKx FlashEngine : v9.7 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 62 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.19 , MTKx FlashEngine : v9.7 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 62 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.19 , MTKx FlashEngine : v9.7 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 62 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... Core : v2.19 , MTKx FlashEngine : v9.7 Verify files ... MAUI : RM-1011_ROM_eMP_20.10.11 VIVA : RM-1011_VIVA_eMP_20.10.11 LANG : RM-1011_LANG_PACK_ROM_IC_eMP_20.10.11_002 CUST : RM-1011_CUSTPACK_ROM_IC_MEA_SY_eMP_20.10.11_002 JMPT : RM-1011_JUMP_TABLE_IC_MEA_SY_eMP_20.10.11_002 - > MODE : FullFlash Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 62 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Connect phone on selected interface... Boot Error Flashing failed! Connect phone on selected interface... |
03-12-2016, 10:56 | #2 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | Code: Dead Mode is Selected Waiting for USB device... 1. Phone should be Off! 2. Battery must be charged and inserted! ( if not used external power ) - > If phone can't switch to BL - use battery or flash from Local mode! --- Insert USB cable now! --- Wait for phone... Phone found! [ 36 ] Sync... Sync Ok, read regs... Initial Register Read Failed (HW/Connection Error) Connect phone on selected interface... Connect phone on selected interface... this is the first phone with best not my first time i buy it last week i just want to erase user code but the same in flash and user code remove > |
03-12-2016, 11:45 | #4 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | i also check drivers ok reboot pc oh try in another pc i have tow one xp , other 7 and check another shop also not take what cause the problem Last edited by helpo; 03-12-2016 at 11:52. |
03-12-2016, 14:14 | #6 (permalink) |
Member: 2175357 Status: Offline Sonork: QQ:2157039171 Thanks Meter: 453 | thanks for reply the phone not in my hand another time thanks > but the battery is ok and check it with a new phone |
03-12-2016, 15:04 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | If you tested with OK battery - then it HW. In most cases it CPU solder fault or water damage. |
The Following 3 Users Say Thank You to JayDi For This Useful Post: |
