04-12-2014, 04:39 | #1 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Kfe~Labs Co.- Age: 52
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Lumia 620 Flash Done.. But No problem for Flash With Best Dongle, Super Fast and safe Core : v1.86 , WP8x FlashEngine : v4.4 FFU : RM846_3046.0000.1329.2001_RETAIL_apac_vietnam_203_ 01_248975_prd_signed.ffu Checking FFU file, wait... FFU Revision ID : 2.0 FFU Model ID : Nokia.MSM8227.P5122 FFU RootKeyHash : 67131691EEDD1F38568C7FFAE284FB2621680FEA FFU Languages : Dutch (Netherlands) , English (UK) , English , Filipino (Philippines) , Finnish , French , German , Japanese , Korean , Russian , Chinese , Chinese(Taiwan) , Vietnamese , FFU ChipSectors : 15155200 FFU Header : 0x000C0000 FFU Payload : 0x47C60000 FFU FastVerify : Ok Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold : "Volume Down" + "Power On" 2. Insert USB cable 3. When cable connected and you feel short vibra - release buttons Device catched in BOOT mode! Boot Mode confirmed! Setting Preloder Collect Info... Setting Application Setting Secure Collect Info... === Nokia Flash App info : Protocol Version : 1.14 Protocol Implementation : 1.25 === Phone Initial info : Phone RMxxx ID : RM-846 Phone Model ID : Nokia.MSM8227.P5122.1.2 Phone Model PC : 059S2V3 Phone IMEI : 356715056197273 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 67131691EEDD1F38568C7FFAE284FB2621680FEA === Other info : SD present : True , 00F03A00 FFU : RM846_3046.0000.1329.2001_RETAIL_apac_vietnam_203_ 01_248975_prd_signed.ffu Checking... Device RootKey Match with FFU RootKey! Device ProductID Match with FFU ProductID! ProductID : Nokia.MSM8227.P5122 DevRKH : 67131691EEDD1F38568C7FFAE284FB2621680FEA All Ok, Continue flashing... FFU : RM846_3046.0000.1329.2001_RETAIL_apac_vietnam_203_ 01_248975_prd_signed.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Erase done Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Total flash time : 00:02:37 Rebooting Connect phone on selected interface... Phone found! WP8x Nokia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Wainting a Lower Version (with Spanish) southAmerica Ciao Auto |
04-23-2014, 01:27 | #3 (permalink) |
Member: 2140790 Status: Offline Sonork: 100.1679059 Thanks Meter: 212 | Hi Nokia Best Supp. What mean this TestLog, This Lumia 620 work bad after change touch. here log. I hear this problem is solved with a downgrade? so, is possible downgrade wp8 620? Connect phone on selected interface... Phone found! WP8x Nokia Phone detected Read info... Ok IMEI : 356715056197273 , Model : RM-846 Nokia Lumia 620 SelfTest to proceed : 25 PASSED | Digital microphone selftest PASSED | Audio controller self test PASSED | Accessory detection self test PASSED | Accelerometer self test PASSED | Magnetometer self test PASSED | Proximity self test PASSED | NFC interface test PASSED | NFC antenna test PASSED | WLAN interface test PASSED | PASSED | Battery temperature self test PASSED | System clock oscillator temperature self test PASSED | Current gauge self test PASSED | Display self test MINOR | Touch interface self test MINOR | Touch internal self test PASSED | Keyboard stuck self test PASSED | Camera interface test PASSED | Camera flash interface test PASSED | Camera flash test PASSED | Camera flash strobe test PASSED | Main camera Non volatile memory self test PASSED | Camera interface test for second camera PASSED | Secondary camera Non volatile memory self test PASSED | Battery alarm self test SelfTest done , Items Passed Ok : 23 , Items Passed With Error : 2 === SelfTest Error logging === Test : Touch interface self test = > Test Name : Touch interface self test = > Test Method : The test verifies data and control lines between MCM and touch controller. = > Detailed description : Touch driver identifies controller by reading of the test register via control interface. Interrupt is generated for INT line verification by setting the threshold low enough. = > Extednded info : Detailed result contains HwFails bitmask. Zero means all was ok, and fail codes are: - SELF_TEST_HW_FAIL_CONTROL 0x0001 (No communication with a device at all) - SELF_TEST_HW_FAIL_BIST 0x0004 (Component internal self test) - SELF_TEST_HW_FAIL_INTERRUPT 0x0010 (Interrupt line fails) Test : Touch internal self test = > Test Name : Touch internal self test = > Test Method : The test verifies internal functionality of touch module. = > Detailed description : Build-in selftest for touch sensor network verification is run where RAW values of the sensor network are read and they are verified to be within the specified limits. The touch screen should not be pressed during the selftest. = > Extednded info : Detailed result contains HwFails bitmask. Zero means all was ok, and fail codes are: - SELF_TEST_HW_FAIL_CONTROL 0x0001 (no communication with a device at all) - SELF_TEST_HW_FAIL_INTERRUPT 0x0010. === SelfTest Error logging === |
04-23-2014, 02:46 | #4 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello, yes, sure possible. Need download and flash SW 1030. After disable automatic update, because even FOTA kill touch again and need again downgrade. |
The Following User Says Thank You to Dzirt For This Useful Post: |
01-19-2015, 13:22 | #7 (permalink) |
Junior Member Join Date: Jun 2008 Location: pakistan
Member: 802048 Status: Offline Sonork: [email protected] Thanks Meter: 2 | sir i need lumia 620 driver plzzz help me??? |
