05-06-2015, 20:11 | #1 (permalink) |
Freak Poster Join Date: Sep 2005 Location: earth Age: 46
Member: 182497 Status: Offline Thanks Meter: 5 | Lumia 620 pc wont recognize after flash error |
05-06-2015, 20:26 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Hello. Charge battery , download latest BEST version. Insert USB cable, insert battery. PC should detect phone. If still not - check USB cable, port and phone USB port. |
05-07-2015, 10:22 | #9 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | http://forum.gsmhosting.com/vbb/11034087-post2.html All explained already. |
05-07-2015, 10:49 | #10 (permalink) | |
Member: 182497 Status: Offline Thanks Meter: 5 | Quote:
05-07-2015, 12:53 | #12 (permalink) | |
Lumia WP8 Boot Repair Second Case : BootLoop , no connection , BSOD: Phone not connect to PC, shows Blue Screen or just vibrate. For repair need: 1. USB cable 2. Charged battery 3. Nokia X2 Emergency driver installed ( can be found on support area ) 4. For WinXp in most case need install driver manually 5. TestPoint procedure | |
05-07-2015, 17:05 | #14 (permalink) | |
Remember this next time that you see a case like mine. A phone can die just for flashing. In my case only vibrates and dont recognize in any pc, itīs not the battery, remove icīs, cableīs, ports, pc, etc. Like you said, its in the manual. Thanks for the help | |
05-07-2015, 17:32 | #15 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Just FYI - When I made repair in BEST - I've killed 10 different Lumias to different states. Even desolder eMMC's - just to check all, what want to know about them. Not faced such problems eve with 1% , even with 2,3,4. But anyway - happy to see about your problems solved. Will take a note about that. |
