08-20-2016, 17:47 | #17 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Lagos, Nigeria
Member: 1918881 Status: Offline Thanks Meter: 44 | Got same problem here.. but solved! Change Pc, Update driver then flash successful Waiting for phone... Dead mode is selected , no phone in normal mode found 1. Press and hold "Volume Down" 2. Insert USB cable 3. Hold button until phone will be detected Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.34 Protocol Implementation : 2.59 === Phone Initial info : Phone Model ID : Nokia.MSM8926.P6204.1.1 === eMMC info : eMMC Vendor : Toshiba eMMC CID : 0011 eMMC Size : 7456 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 831BE6B18E7006372069545885A80F786C33D064 === Other info : SD present : False Full Check skipped , will be checked by ImageSignature Battery Level : 31% RPMB Provision Status Code : 0x0101 Device RAM size : 1024 MiB Device not have ATRP Backup to RAM Ok! FFU : RM1072_02164.00000.15066.26001_RETAIL_prod_signed_ 1052_01D0D7_000-DE_MV.ffu Flashing FFU Sending FFU Header CertData Header sent , accepted Perform Data Partition Erase Error : 06 : Data Partition Not Found! Seems as damaged Will Fix partitions by flash whole image Sending FFU Header CertData Header sent , accepted Skip Data Partition Erase Sending FFU Payload Data... Finishing flashing Flashing done! Green Light Image Sent, processing PostFlash FinalConfig : abnormal status, error code : 0xFF7B0000 Make Factory Set : Ok Restore RAMBkp : Ok Update NVI from Image Ok , NVI will be updated on first boot! PostFlash Finished Total flash time : 00:05:35 Rebooting Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok Phone disconected! Connect phone on selected interface... |
