11-21-2013, 13:15 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: lahore
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | lumia 800 flashing problem. Bld : 12 Tms : 17.02.2012 / 12:40:05 ==== OSBL ==== Processing : RM801_12w46_prod_generic_nokia_osbl.esco nokia_osbl.mbn.cert , Hash : 0C203F23776466E755E9955A9F8F9A39A0888B8E WriteCert failed, LastErr : 22000300 Error while flashing, break - > Error on Flashing stage, Check Cable/Battery Phone disconected! Connect phone on selected interface... |
11-22-2013, 11:56 | #7 (permalink) |
Member: 504906 Status: Offline Sonork: 1604032 Thanks Meter: 141 | Sir i repair the fone by adance box,rlso repair the partition,also do this step, Put QUALCOMM OSBL back to your phone. Click SCAN Partition. then select Partition 0x48 - WP_OS Click Write Partition... And now select BOOT file from your original Nokia Lumia 800 Flash File. It will be the ESCO file which is about 300 to 400 MB in Size... The name is usually: RM803_12121_prod_281_06_boot.esco Anyway, use the file to write to WP_OS Partition. After write that partition, click "SP UNLOCK" so you are sure phone is unlocked. Now phone should power ON and load Windows already... No need to flash via USB. fone is now on all working,but no service,only tell me that this is software or hardware fault,(fone imei is ok) |
