02-20-2017, 08:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2004 Age: 49
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Lumia 950XL Unlock fail Please help Code: Card found: S/N : 223AB88B , v0122 Registered to: xxxxxxx Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok [WP8x] : Init TesMode [TSTM] : Use File : RM1085_1078.0050.10586.13169.207.44_enosw-wim-signed_638639.secwim === Base Phone Info Sw Version : 01078.00053.16236.35003 IMEI : 359763062039268 ProductCode : 059X7K9 Device catched in BOOT mode! Collect Info... === Nokia Flash App info : Protocol Version : 2.41 Protocol Implementation : 2.75 === Phone Initial info : Phone Model ID : Microsoft.MSM8994.P6211.2.1 === eMMC info : eMMC Vendor : Samsung eMMC CID : 0015 eMMC Size : 29820 MiB === Security Initial info : Security Status : 010100000101 Secure Boot : Enabled Secure eFUSE : Enabled JTAG : Disabled RDC Key : Not Present (Retail) UEFI SBoot : Enabled SecHW Key : Exists Device RootKey : 427D8FD5A7F227820D5B11BF8C6F7670C0A0622C === Other info : SD present : False SECWIM : RM1085_1078.0050.10586.13169.207.44_enosw-wim-signed_638639.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #2 , try "Unlock" again Error! Check previous error message for more info! SD Already Authentificated! Done! === Main info === SecLabel Version : Security setup library (wim) 21.1078.417.212 Sw Version : RM1085 1078.0050.10586.13169 638639 2016/05/13 //MAINLINE/ML_Octagon_RG0\r\n IMEI : 359763062039268 ProductCode : 059X7K9 ProductSN : B672CD0AU Module Code : 0206350 === HW info === Public ID : D045C5554B988FE48D2C92996435CD03FEAFC506 BT Addr. : 5CCA1AFA51E8 Wlan Mac : 5CCA1AFA7624 === Branding and security info === Conf key : 8000000000000000 Provider key : 3700100000000000 Country : Dominican Republic Operator : orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Making RPL backup... NPC : Read Ok , [648] IMEI : 359763062039268 CCC : Certificate not available HWC : Certificate not available RDC : Certificate not available NPC Certificate saved... RPL saved : C:\InfinityBox\BEST\Backup\Cert\359763062039268_CRT_2nd.rpl Done! WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Unknown result , something wrong with SDauth or Data #1 , try "Unlock" again! Error! Check previous error message for more info! Phone disconected! |
The Following User Says Thank You to Star75 For This Useful Post: |
02-21-2017, 16:01 | #2 (permalink) |
Member: 462970 Status: Offline Thanks Meter: 20,352 | Updatw phone FW to latest version with NVI update checked. Repeat unlock after. Make sure about you use SAME or NEWER ENO version for installed in phone FW. |
02-22-2017, 04:51 | #3 (permalink) | |
Member: 53198 Status: Offline Sonork: 100.1589499 Thanks Meter: 819 | Quote:
Code: Link to my account: http://user.infinity-best.com Login: swat001d Connecting to server... Credits: 0 === Main info === SecLabel Version : Security setup library (wim) 21.1078.417.212 Sw Version : RM1085 1078.0050.10586.13169 638639 2016/05/13 //MAINLINE/ML_Octagon_RG0\r\n IMEI : 359763062039268 ProductCode : 059X7K9 ProductSN : B672CD0AU Module Code : 0206350 === HW info === Public ID : D045C5554B988FE48D2C92996435CD03FEAFC506 BT Addr. : 5CCA1AFA51E8 Wlan Mac : 5CCA1AFA7624 === Branding and security info === Conf key : 8000000000000000 Provider key : 3700100000000000 Country : Dominican Republic Operator : orange Counters : Key 0 [3] , Fbus 0 [10] Blocks : 1 LOCK STATUS : ============================= BLK : 1 Lock1:Close ============================= LOCKS : Closed ============================= Code: SECWIM : RM1085_1078.0050.10586.13169.207.44_enosw-wim-signed_638639.secwim Sending WIM ... WIM Image sent! Trying init TestMode now... Connect phone on selected interface... Phone found! WP10/WP8x Lumia Phone detected Read info... Ok WP8 Unlock Started Connecting to server... Connected Authenticating... Authenticated Checking Client version... Client version is valid Processing Step #1 Processing Step #2 Processing Step #3 Processing Step #4 Disconnected Need SDAuth to finish ... Started Connecting to SX4 server... Connected SX4 enter .. SDAuth Ok! SX4 Disconnected Unknown result , something wrong with SDauth or Data #2 , try "Unlock" again Error! Check previous error message for more info! | |
