12-25-2011, 09:32 | #16 (permalink) |
No Life Poster Join Date: Nov 2009 Location: Syberia Age: 34
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Download via NaviFrim latest 20 SW release and flash it again. You trying flash SW10, it old for now. Also - Try first do wipe via WIPE button. Press Connect/Info button. Insert usb cable into phone. When BEST read info - press WIPE button. Wait, till finish. After - reflash phone again. Better, if will be used Latest Firmware 20. |
12-25-2011, 17:50 | #20 (permalink) |
Insane Poster Join Date: Aug 2004 Location: MWANZA,TANZANIA Age: 44
Member: 76815 Status: Offline Thanks Meter: 7 | N900 unable to use this sim card in device Will this update be to repair UNABLE TO USE THIS SIM CARD IN DEVICE on N900????? If so what is the procedure. Thanks in advance. |
12-25-2011, 18:38 | #21 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | If phone NOT accepts any sim - CMT damaged - Downgraded ( just flash latest SW21 for N900 ) or HW error - Rehot RAPU CPU. If phone locked - need unlock it by operator code. |
12-26-2011, 06:53 | #25 (permalink) |
Cheater -Don't Deal with him- Join Date: May 2008 Location: at work
Member: 770863 Status: Offline Sonork: 100.1597188 Thanks Meter: 123 | Need Select MeeGo in generation Need select MCU file Need Select eMMC file Press Check Files Tick WIPE in Flash Settings Press Flash If phone connected - just wait till finish. If not - connect powered OFF phone. ( Power OFF it and wait near 20 seconds, after connect ) All is done, waiting till process finish. Estimated time is - 8-12 minutes for process |
The Following User Says Thank You to alhameed For This Useful Post: |
12-28-2011, 06:37 | #27 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: IT POINT Ankleshwar
Member: 756719 Status: Offline Thanks Meter: 80 | Quote:
here is the log.. Insert cable in to powered OFF phone! (Ignore if phone Connected) Waiting for NOLO... Connect in NOLO mode Ok! Phone Info : Type : RX-51 , HWRev : 2101 NOLO : 01/0E/14 SWVer: blank (CMT/RootFs erased or HW error) Read full info failed Processing APE Boot... File : RX-51_2009SE_20.2010.36-2.004_PR_COMBINED_004_ARM.bin Boot error #1 Try again few times. Check cable and battery Elapsed: 00:00:50 Connect phone on selected interface... plz help me what i m doing wrong... | |
12-28-2011, 09:35 | #28 (permalink) |
Member: 1157320 Status: Offline Thanks Meter: 6,192 | Hello. Why you select MeeGo in generation? N900 - Maemo. Hints when you move cursor to button will show you this. Select Maemo, repeat procedure again. |
Guide to Rolis Flasher! | davieb | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 10 | 01-29-2002 16:53 |
Unlocking & Repair Guide | guruguide | GSM Mobile Links | 1 | 12-13-2001 15:23 |
Free SMSc's and Flashing Guides | davieb | GSM Mobile Links | 0 | 12-05-2001 15:51 |
Idiots guide to unlocking Nokia 3210 V6.00 NSE - 8/9 (03-10-00) req. | belker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-23-2001 11:26 |
I mean pc guide for nokia 8210 | linda | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-18-2000 20:49 |
